ESD-320S220DT
ESD-320S220DT
    INVENTRONICS(英飞特)
ESD-320S220DT 数据手册
ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Features  Ultra High Efficiency (Up to 94.5%)  Full Power at Wide Output Current Range (Constant Power)  0-10V/PWM/Timer Dimmable (3 Timer Modes)  Dim-to-Off with Standby Power ≤1.5W  Output Lumen Compensation  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The ESD-320SxxxDT series is a 320W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 105-1500mA 1050-1500mA 1400 mA 154-2200mA 1540-2200mA 2100 mA 217-3100mA 2170-3100mA 2800 mA 308-4400mA 3080-4400mA 4200 mA 434-6200mA 4340-6200mA 4900 mA Input Voltage Range(2) 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc 249~528Vac 352~500Vdc Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Output Voltage Range Model Number 107~305Vdc 320 W 94.0% 0.96 0.95 ESD-320S150DT 73~208Vdc 320 W 94.5% 0.96 0.95 ESD-320S220DT 52~148Vdc 320 W 94.0% 0.96 0.95 ESD-320S310DT 37~104Vdc 320 W 94.0% 0.96 0.95 ESD-320S440DT 26 ~74Vdc 320 W 93.5% 0.96 0.95 ESD-320S620DT (4) Notes: (1) Output current range with constant power at 320W (2) Certified voltage range: 277-480Vac or 352-500Vdc (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G I-V Operating Area ESD-320S150DT ESD-320S220DT ESD-320S310DT ESD-320S440DT 10 % 60 0% L oa Lo d ad ESD-320S620DT 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Input Specifications Parameter Min. Typ. Max. 249 Vac - 528 Vac 47 Hz - 63 Hz - - 0.75 MIU - - 0.70 mA - - 1.5 A Measured at 100% load and 277 Vac input. - - 0.8 A Measured at 100% load and 480 Vac input. - - 3.87 A s 0.90 - - - - 20% At 277-480Vac, 50-60Hz, 60%-100% Load (192-320W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 105 mA 154 mA 217 mA 308 mA 434 mA - 1500 mA 2200 mA 3100 mA 4400 mA 6200 mA 1050 mA 1540 mA 2170 mA 3080 mA 4340 mA - 1500 mA 2200 mA 3100 mA 4400 mA 6200 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESD-320S150DT ESD-320S220DT ESD-320S310DT ESD-320S440DT ESD-320S620DT - - 329V 223V 158V 121V 84V Input Voltage Input Frequency Leakage Current Input AC Current 2 Inrush Current(I t) PF THD 2 Notes 352-500Vdc UL8750; 480Vac/ 60Hz; Grounding effectively. IIEC60598-1; 480Vac/ 60Hz; Grounding effectively. At 480Vac input, 25C Cold Start, Duration=1.77 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-320S150DT ESD-320S220DT ESD-320S310DT ESD-320S440DT ESD-320S620DT Output Current Setting Range with Constant Power ESD-320S150DT ESD-320S220DT ESD-320S310DT ESD-320S440DT ESD-320S620DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 100% load 100% load, 20 MHz BW 100% load. Only this component of ripple is associated with visible flicker. 100% load 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Output Specifications (Continued) Parameter Min. Typ. Max. Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - 0.5 s 0.75 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Notes Measured at 100% load Measured at 277Vac and 480Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 277 Vac input: ESD-320S150DT Io=1050mA Io=1500mA ESD-320S220DT Io=1540mA Io=2200mA ESD-320S310DT Io=2170mA Io=3100mA ESD-320S440DT Io=3080mA Io=4400mA ESD-320S620DT Io=4340mA Io=6200mA Efficiency at 347 Vac input: ESD-320S150DT Io=1050mA Io=1500mA ESD-320S220DT Io=1540mA Io=2200mA ESD-320S310DT Io=2170mA Io=3100mA ESD-320S440DT Io=3080mA Io=4400mA ESD-320S620DT Io=4340mA Io=6200mA Min. Typ. Max. 90.5% 89.5% 92.5% 91.5% - 91.0% 90.0% 93.0% 92.0% - 90.5% 90.0% 92.5% 92.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 91.5% 90.5% 93.5% 92.5% - 92.0% 91.0% 94.0% 93.0% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.5% 93.5% 92.5% - 91.0% 90.0% 93.0% 92.0% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G General Specifications (Continued) Parameter Efficiency at 480 Vac input: ESD-320S150DT Io=1050mA Io=1500mA ESD-320S220DT Io=1540mA Io=2200mA ESD-320S310DT Io=2170mA Io=3100mA ESD-320S440DT Io=3080mA Io=4400mA ESD-320S620DT Io=4340mA Io=6200mA Standby power Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - 92.0% 91.0% 94.0% 93.0% - 91.5% 90.5% 93.5% 92.5% - - - 1.5 W Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details MTBF - 200,000 Hours - Lifetime - 120,000 Hours - -40°C - +87C -40°C - +75C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight With mounting ear 10.28× 3.86 × 1.76 261 × 98 × 44.8 9.21 × 3.86 × 1.76 234 × 98 × 44.8 - 1935g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA ESD-320S150DT ESD-320S220DT ESD-320S310DT ESD-320S440DT ESD-320S620DT 10%Ioset - Ioset ESD-320S150DT ESD-320S220DT ESD-320S310DT ESD-320S440DT ESD-320S620DT 105 mA 154 mA 217 mA 308 mA 434 mA - Ioset Notes Vdim(+) = 0 V 1050mA ≤ Ioset ≤ 1500mA 1540mA ≤ Ioset ≤ 2200mA 2170mA ≤ Ioset ≤ 3100mA 3080mA ≤ Ioset ≤ 4400mA 4340mA ≤ Ioset ≤ 6200mA 105mA ≤ Ioset < 1050mA 154mA ≤ Ioset < 1540mA 217mA ≤ Ioset < 2170mA 308mA ≤ Ioset < 3080mA 434mA ≤ Ioset < 4340mA 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.4 V 0.55V 0.7 V Dim on Voltage 0.6 V 0.75 V 0.9 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 EAC IEC 61347-1, IEC 61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Inrush Current Waveform Efficiency vs. Load ESD-320S150DT(Io=1050mA) ESD-320S150DT(Io=1500mA) ESD-320S220DT(Io=1540mA) ESD-320S220DT(Io=2200mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G ESD-320S310DT(Io=2170mA) ESD-320S310DT(Io=3100mA) ESD-320S440DT(Io=3080mA) ESD-320S440DT(Io=4400mA) ESD-320S620DT(Io=4340mA) ESD-320S620DT(Io=6200mA) 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-320SxxxDT 320W Programmable IP67 Driver Rev. G 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-320S220DT 价格&库存
很抱歉,暂时无法提供与“ESD-320S220DT”相匹配的价格&库存,您可以联系我们找货
ESD-320S220DT
