EUC-040S105DVM0004
EUC-040S105DVM0004
    INVENTRONICS(英飞特)
EUC-040S105DVM0004 数据手册
EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Features  Low THD, 10% Max up to 240 Vac  Compact Metal Case with Excellent Thermal Performance  Isolated 0-10V Dimmable  Input Surge Protection: 4kV line-line, 6kV line-earth  High Reliability & Long Lifetime: 93,000 hrs. at 75C Case Temperature  Suitable for Independent Use and Class I Luminaires  Input UVP and Input OVP  Waterproof(IP67)  5 Years Warranty Description The EUC-040SxxxDVM000x series is a 40W, constant-current IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including low bay, tunnel and street. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Output Current 500 mA 700 mA 860 mA 1050 mA Input Voltage Range(1) 90 ~ 305 Vac 127 ~ 250 Vdc 90 ~ 305 Vac 127 ~ 250 Vdc 90 ~ 305 Vac 127 ~ 250 Vdc 90 ~ 305 Vac 127 ~ 250 Vdc Output Voltage Range Max. Output Power Typical Power Factor Efficiency 120Vac 220Vac (2) 40 ~ 80 Vdc 40 W 87% 0.99 0.96 EUC-040S070DVM0004 32 ~ 57 Vdc 40 W 86% 0.99 0.96 EUC-040S070DVM 23 ~ 47 Vdc 40 W 86% 0.99 0.96 EUC-040S105DVM0004 21 ~ 38 Vdc 40 W 85% 0.99 0.96 EUC-040S105DVM Model Number Notes: (1) Certified input voltage range: 120-240Vac/127-250Vdc. (2) Measured at 100% load and 220 Vac input. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 0.55 A Measured at 100% load and 120 Vac input. - - 0.30 A Measured at 100% load and 220 Vac input. 127 ~ 250 Vdc IEC60598-1; 240Vac/ 60Hz Input AC Current 1 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. - - 0.01 A s 0.90 - - THD - - 15% THD - - 10% Min. Typ. Max. -8%lo - 8%lo Total Output Current Ripple (pkavg) - 50%lo 75%lo At 100% load condition Output Current Overshoot / Undershoot - 5%Io 10%Io At 100% load condition No Load Output Voltage EUC-040S070DVM0004 EUC-040S070DVM EUC-040S105DVM0004 EUC-040S105DVM - - 100V 100V 80V 80V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s - 1.0 s 1.5 s - 0.06%/C - 2 Inrush Current(I t) Power Factor 2 Notes At 220Vac input, 25C cold start, duration= 36 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 120-240Vac, 50~60Hz, 75%-100%load (30~40W) 200-240Vac, 50~60Hz, 75%-100%load (30~40W) Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at 100% load Measured at 120Vac input, 75%-100% load Measured at 220Vac input, 75%-100% load Case temperature = 0C ~Tc max Note: All specifications are tested by Cree XLamp XP-G and typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Notes Efficiency at 120 Vac input: EUC-040S070DVM0004 EUC-040S070DVM EUC-040S105DVM0004 EUC-040S105DVM 84.0% 83.0% 83.0% 82.0% 85.0% 84.0% 84.0% 83.0% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) Efficiency at 220 Vac input: EUC-040S070DVM0004 EUC-040S070DVM EUC-040S105DVM0004 EUC-040S105DVM 86.0% 85.0% 85.0% 84.0% 87.0% 86.0% 86.0% 85.0% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 2 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. Max. 86.0% 85.0% 85.0% 84.0% 87.0% 86.0% 86.0% 85.0% - MTBF - 598,000 Hours - Lifetime - 93,000 Hours - -40 C - +90 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40 C - +85 C Humidity: 5% RH to 100% RH. Efficiency at 277 Vac input: EUC-040S070DVM0004 EUC-040S070DVM EUC-040S105DVM0004 EUC-040S105DVM Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 75C case temperature; See lifetime vs. Tc curve for the details With mounting ear 4.13 x 2.52 x 1.26 105 x 64 x 32 3.46 x 2.52 x 1.26 88 x 64 x 32 Net Weight - 375 g - Note: All specifications are tested by Cree XLamp XP-G and typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the 0~10V Input Pin -20 V - +20 V Source Current on 0~10V Input Pin 0 μA 200 μA 250 μA 10%Iomax - 100%Iomax 0V - 10 V Dimming Output Range Recommended Dimming Input Range Notes Safety & EMC Compliance Safety Category CE Standard EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test 3 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Safety & EMC Compliance (Continued) EMI Standards Notes EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 4 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Lifetime vs. Case Temperature Inrush Current Waveform 5 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Efficiency vs. Load EUC-040S070DVM(Io=700mA) EUC-040S070DVM0004(Io=500mA) EUC-040S105DVM(Io=1050mA) EUC-040S105DVM0004(Io=860mA) Power Factor 6 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Turn off the output when the input voltage falls below 83±10V. And the driver will restart when the input voltage exceeds 88±10V. Input Over Voltage Protection Input Protection Voltage 330 Vac 340 Vac 350 Vac Turn off the output when the input voltage exceeds protection voltage. Recovery Voltage 300 Vac 320 Vac 340 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. - - 380 Vac Max. of Input Over Voltage  Input Over Voltage Protection Diagram Io Recovery Protection 340 Vac 320 Vac Vin 7 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Dimming  0-10V Dimming The recommended implementation is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do not connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim+ should be open. Mechanical Outline INPUT (VDE H05RN-F 3*1.0mm2 7.2) DIMMING WIRE (VDE H05RN-F 2*0.5mm 2 6.3) +VV Tc ︵ ︵ N W E OU RL BB PURPLE GRAY ︶ ︶ AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) OUTPUT (VDE H05RN-F 2*1.0mm 2 6.8) PROJ: Unspecified tolerance:±1 8 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 9 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-040SxxxDVM000x 40W Constant Current IP67 Driver Rev. C Revision History Description of Change Change Date Rev. 2016-12-30 A 2017-08-29 2018-03-23 Item B C From To Datasheet Release / / Features / Updated Input Voltage Range(Vac) 108 ~ 305 Vac 90 ~ 305 Vac Dimming Specifications - Absolute Maximum Voltage on the 0~10V Input Pin Min.=0V Min.=-20V Derating Curve / Added Dimming - 0-10V Dimming - Implementation 1: DC / Input Corrected Dimming - 0-10V Dimming - Implementation 2: External Resistor / Deleted Description / Updated MTBF 732,000 Hours 598,000 Hours Safety & EMC Compliance - Safety Category CCC / Added 10 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-040S105DVM0004 价格&库存
很抱歉,暂时无法提供与“EUC-040S105DVM0004”相匹配的价格&库存,您可以联系我们找货
EUC-040S105DVM0004
