EUD-150S350DVA
EUD-150S350DVA
    INVENTRONICS(英飞特)
    EUD-150S350DVA
EUD-150S350DVA 数据手册
EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Features  Ultra High Efficiency (Up to 94%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/3-Timer-Modes Dimmable (DVA models) DALI Dimming Control (BVA models)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation ( DVA models)  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  7 Years Warranty Description The EUD-150SxxxDVA(BVA) series is a 150W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, tunnel and roadway, etc. It provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range (1) Current Range Input Voltage Range(2) Output Max. Typical Power Factor Voltage Output Efficiency 120Vac 220Vac Range Power (3) 90~305Vac 75~214Vdc 100~250Vdc 90~305Vac 140-2100mA 1400-2100mA 1400 mA 38~107Vdc 100~250Vdc 90~305Vac 245-3500mA 2450-3500mA 3150 mA 22 ~ 61Vdc 100~250Vdc 90~305Vac 385-5600mA 3850-5600mA 4200 mA 14 ~ 39Vdc 100~250Vdc 70-1050mA 700-1050mA 700 mA Model Number (5) 150 W 94.0% 0.99 0.96 EUD-150S105DVA(BVA) 150 W 94.0% 0.99 0.96 EUD-150S210DVA(BVA)(4) 150 W 93.5% 0.99 0.96 EUD-150S350DVA(BVA)(4) 150 W 92.5% 0.99 0.96 EUD-150S560DVA(BVA)(4) Notes: (1) Output current range with constant power at 150W. (2) Certified voltage range: 100-240Vac or 100-250Vdc, (except KS,CCC and PSE) . (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) All the models are certificated to Global-mark, except EUD-150S105DVA(BVA). 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C I-V Operating Area EUD-150S105DVA(BVA) EUD-150S210DVA(BVA) EUD-150S350DVA(BVA) EUD-150S560DVA(BVA) Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.87 A Measured at 100%load and 100 Vac input. - - 0.85 A Measured at 100%load and 220 Vac input. - - 1.90 A s 0.90 - - THD - - 20% THD - - 10% 100-250 Vdc IEC60598-1; 240Vac/ 60Hz , grounding effectively Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25℃ cold start, duration=872μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (90-150W) At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150W) 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 140 mA 245 mA 385 mA - 1050mA 2100mA 3500mA 5600mA 700 mA 1400 mA 2450 mA 3850 mA - 1050mA 2100mA 3500mA 5600mA - 5%Iomax 10%Iomax - 2%Iomax - 100%load Startup Overshoot Current - - 10%Iomax 100%load No Load Output Voltage EUD-150S105DVA(BVA) EUD-150S210DVA(BVA) EUD-150S350DVA(BVA) EUD-150S560DVA(BVA) - - 240 V 120 V 80 V 50 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA - - 400 mA Output Current Tolerance Output Current Setting(Ioset) Range EUD-150S105DVA(BVA) EUD-150S210DVA(BVA) EUD-150S350DVA(BVA) EUD-150S560DVA(BVA) Output Current Setting Range with Constant Power EUD-150S105DVA(BVA) EUD-150S210DVA(BVA) EUD-150S350DVA(BVA) EUD-150S560DVA(BVA) Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Turn-on Delay Time Temperature Coefficient of Ioset 12V Auxiliary Output Transient Peak Current Notes 100%load 100%load, 20 MHz BW 100%load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“(DVA models) Return terminal is “OTP−“(BVA models) 400mA peak for a maximum duration of300 ms in a 2s period during which time the ave rage should not exceed 200mA. Note: All specifications are typical at 25C unless otherwise stated. 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C General Specifications Parameter Min. Typ. Max. 89.5% 88.0% 91.5% 90.0% - 89.5% 87.5% 91.5% 89.5% - 88.5% 87.5% 90.5% 89.5% - 88.0% 86.0% 90.0% 88.0% - 92.0% 90.5% 94.0% 92.5% - 92.0% 89.5% 94.0% 91.5% - 91.5% 89.0% 93.5% 91.0% - 90.5% 88.5% 92.5% 90.5% - 92.0% 90.5% 94.0% 92.5% - 92.5% 90.0% 94.5% 92.0% - 91.5% 89.0% 93.5% 91.0% - 90.5% 89.0% 92.5% 91.0% - Standby power - - 0.5 W MTBF - 228,000 Hours - Lifetime - 100,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-150S105DVA(BVA) Io= 700mA Io=1050mA EUD-150S210DVA(BVA) Io=1400mA Io=2100mA EUD-150S350DVA (BVA) Io=2450mA Io=3500mA EUD-150S560DVA(BVA) Io=3850mA Io=5600mA Efficiency at 220 Vac input: EUD-150S105DVA(BVA) Io= 700mA Io=1050mA EUD-150S210DVA(BVA) Io=1400mA Io=2100mA EUD-150S350DVA(BVA) Io=2450mA Io=3500mA EUD-150S560DVA(BVA) Io=3850mA Io=5600mA Efficiency at 277 Vac input: EUD-150S105DVA(BVA) Io= 700mA Io=1050mA EUD-150S210DVA(BVA) Io=1400mA Io=2100mA EUD-150S350DVA(BVA) Io=2450mA Io=3500mA EUD-150S560DVA(BVA) Io=3850mA Io=5600mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 1150 g Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 8.86 × 2.66 × 1.56 225 × 67.5 × 39.7 8.03 × 2.66 × 1.56 204 × 67.5 × 39.7 - Notes - 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz PWM_in Duty Cycle 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - DA,DA High Level 9.5V 16V 22.5V DA,DA Low Level -6.5V 0V 6.5V DA,DA Current 0mA - 2mA Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Recommended Dimming Input Range Hysteresis DVA Models PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis BVA Models EUD-150S105DVA(BVA) Dimming EUD-150S210DVA(BVA) Output EUD-150S350DVA(BVA) Range EUD-150S560DVA(BVA) Notes Vdim(+) = 0 V Default 0-10V dimming mode. Dimming mode interface. 10%Ioset - Ioset 70mA 140mA 245mA 385mA - Ioset set to PWM in PC 700mA ≤ Ioset ≤ 1050mA 1400mA ≤ Ioset ≤ 2100mA 2450mA ≤ Ioset ≤ 3500mA 3850mA ≤ Ioset ≤ 5600mA 70mA ≤ Ioset < 700mA 140mA ≤ Ioset < 1400mA 245mA ≤ Ioset < 2450mA 385mA ≤ Ioset < 3850mA Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category ENEC & TUV & CE CB Standard EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Safety &EMC Compliance (Continued) Safety Category Standard CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KS Global Mark KS C 7655 AS/NZS 61347.1, AS/NZS 61347.2.13 EMI Standards EN 55015/GB 17743(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 (2) kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment DALI Standards DALI Notes IEC62386-101,102 & part of 207 (3) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. (3) Optional Commands Implemented: 242 (query short circuit), 243 (query open circuit) 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUD-150S105DVA(BVA)(Io=700mA) EUD-150S105DVA(BVA)(Io=1050mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C EUD-150S210DVA(BVA)(Io=1400mA) EUD-150S210DVA(BVA)(Io=2100mA) EUD-150S350DVA(BVA)(Io=2450mA) EUD-150S350DVA(BVA)(Io=3500mA) EUD-150S560DVA(BVA)(Io=3850mA) EUD-150S560DVA(BVA)(Io=5600mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset ≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Dimming  0-10V Dimming (Only DVA models) The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming (Only DVA models) The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-150SxxxDVA(BVA) 150W Programmable IP67 Driver Rev. C Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming (Only DVA models) Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-150S350DVA 价格&库存
很抱歉,暂时无法提供与“EUD-150S350DVA”相匹配的价格&库存,您可以联系我们找货
