EUD-320S670DV
EUD-320S670DV
    INVENTRONICS(英飞特)
EUD-320S670DV 数据手册
EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Features  Ultra High Efficiency (Up to 94%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  7 Years Warranty Description The series is a 320W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, aquaculture and sports, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 105-1500mA 1050-1500mA 1400 mA 154-2200mA 1540-2200mA 2100 mA 224-3200mA 2240-3200mA 2800 mA 322-4600mA 3220-4600mA 4200 mA 469-6700mA 4690-6700mA 6700 mA Input Voltage Range(2) 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~250 Vdc Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number 107~305Vdc 320 W 94.0% 0.99 0.96 EUD-320S150DV 73~208Vdc 320 W 93.5% 0.99 0.96 EUD-320S220DV 50~143Vdc 320 W 93.5% 0.99 0.96 EUD-320S320DV 35~100Vdc 320 W 93.5% 0.99 0.96 EUD-320S460DV 24 ~ 68Vdc 320 W 93.5% 0.99 0.96 EUD-320S670DV (4) (4) Notes: (1) Output current range with constant power at 320W (2) Certified Voltage range 100-240Vac or 127-250Vdc (except CCC, PSE, KC and KCC) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E I-V Operating Area EUD-320S150DV EUD-320S220DV EUD-320S320DV EUD-320S460DV 60 10 0% % Lo Lo ad ad EUD-320S670DV 78 (469,68) (2814,68) (4690,68) 65 (Ioset,320/Ioset) (10%Ioset,320/Ioset) 52 10 60 Lo % oa (6700,47.5) d ad 39 0% L 26 (Ioset,24) (670,24) 13 (6700,28.5) (6700,24) Good Performance Area Allowed Operating Area Programmed Operating Area 1350 5400 0 0 2700 4050 6750 8100 Output Current (mA) Note: 4690mA Ioset 6700mA 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 3.30 A Measured at 100% load and 120 Vac input. - - 1.80 A Measured at 100% load and 220 Vac input. - - 1.90 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (240-320W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 105 mA 154 mA 224 mA 322 mA 469 mA - 1500 mA 2200 mA 3200 mA 4600 mA 6700 mA 1050 mA 1540 mA 2240 mA 3220 mA 4690 mA - 1500 mA 2200 mA 3200 mA 4600 mA 6700 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-320S150DV EUD-320S220DV EUD-320S320DV EUD-320S460DV EUD-320S670DV - - 350 V 240 V 160 V 115 V 78 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% 127-250Vdc IEC60598-1; 240Vac/ 60Hz, grounding effectively Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25℃ cold start, duration=3.52 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (192-320W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-320S150DV EUD-320S220DV EUD-320S320DV EUD-320S460DV EUD-320S670DV Output Current Setting Range with Constant Power EUD-320S150DV EUD-320S220DV EUD-320S320DV EUD-320S460DV EUD-320S670DV Total Output Current Ripple (pk-pk) At 100% load condition At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-320S150DV Io=1050mA Io=1500mA EUD-320S220DV Io=1540mA Io=2200mA EUD-320S320DV Io=2240mA Io=3200mA EUD-320S460DV Io=3220mA Io=4600mA EUD-320S670DV Io=4690mA Io=6700mA Efficiency at 220 Vac input: EUD-320S150DV Io=1050mA Io=1500mA EUD-320S220DV Io=1540mA Io=2200mA EUD-320S320DV Io=2240mA Io=3200mA EUD-320S460DV Io=3220mA Io=4600mA EUD-320S670DV Io=4690mA Io=6700mA Min. Typ. Max. 89.5% 88.0% 91.5% 90.0% - 89.5% 88.5% 91.5% 90.5% - 89.5% 87.5% 91.5% 89.5% - 89.0% 87.5% 91.0% 89.5% - 89.0% 87.5% 91.0% 89.5% - 92.0% 90.5% 94.0% 92.5% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.5% 93.5% 91.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 92.0% 90.5% 94.0% 92.5% - 92.0% 90.0% 94.0% 92.0% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.0% 93.5% 92.0% - Standby power - - 0.5 W MTBF - 237,000 Hours - Lifetime - 97,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-320S150DV Io=1050mA Io=1500mA EUD-320S220DV Io=1540mA Io=2200mA EUD-320S320DV Io=2240mA Io=3200mA EUD-320S460DV Io=3220mA Io=4600mA EUD-320S670DV Io=4690mA Io=6700mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.88 × 3.86 × 1.75 251 × 98 × 44.8 8.86 × 3.86 × 1.75 225 × 98 × 44.8 - Notes 1875 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA EUD-320S150DV EUD-320S220DV EUD-320S320DV EUD-320S460DV EUD-320S670DV 10%Ioset - Ioset EUD-320S150DV EUD-320S220DV EUD-320S320DV EUD-320S460DV EUD-320S670DV 105mA 154mA 224mA 322mA 469mA - Ioset Notes Vdim(+) = 0 V 1050mA ≤ Ioset ≤ 1500mA 1540mA ≤ Ioset ≤ 2200mA 2240mA ≤ Ioset ≤ 3200mA 3220mA ≤ Ioset ≤ 4600mA 4690mA ≤ Ioset ≤ 6700mA 105mA ≤ Ioset < 1050mA 154mA ≤ Ioset < 1540mA 224mA ≤ Ioset < 2240mA 322mA ≤ Ioset < 3220mA 469mA ≤ Ioset < 4690mA 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category Standard ENEC & TUV & CE EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 CB CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KC K 61347-1, K 61347-2-13 Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test & Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Safety &EMC Compliance (Continued) EMS Standards Notes (2) EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Inrush Current Waveform Efficiency vs. Load EUD-320S150DV(Io=1050mA) EUD-320S150DV(Io=1500mA) EUD-320S220DV(Io=1540mA) EUD-320S220DV(Io=2200mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E EUD-320S320DV(Io=2240mA) EUD-320S320DV(Io=3200mA) EUD-320S460DV(Io=3220mA) EUD-320S460DV(Io=4600mA) EUD-320S670DV(Io=4690mA) EUD-320S670DV(Io=6700mA) 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV 320W Programmable IP67 Driver Rev. E Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming Implementation 2: Positive logic Implementation 3: Negative logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-320SxxxDV   320W Programmable IP67 Driver Rev. E Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-320S670DV 价格&库存
很抱歉,暂时无法提供与“EUD-320S670DV”相匹配的价格&库存,您可以联系我们找货
