EUD-600S420BV
EUD-600S420BV
    INVENTRONICS(英飞特)
EUD-600S420BV 数据手册
EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Features  Ultra High Efficiency (Up to 95%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  DALI/Timer Dimmable (3 Timer Modes)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  7 Years Warranty Description The EUD-600SxxxBV series is a 600W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, sports and horticultural, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range (1) Current Range 0.224-2.80A 2.24–2.80A 2.8 A 0.336-4.20A 3.36–4.20A 4.2 A 0.448-5.60A 4.48–5.60A 5.6 A 0.592-7.40A 5.92–7.40A 7.0 A 0.784-9.80A 7.84–9.80A 9.8 A Input Voltage Range(2) 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number 108 ~ 268Vdc 600 W 95.0% 0.99 0.96 EUD-600S280BV 72 ~ 178Vdc 600 W 94.5% 0.99 0.96 EUD-600S420BV 54 ~ 134Vdc 600 W 94.5% 0.99 0.96 EUD-600S560BV 41 ~ 101Vdc 600 W 94.0% 0.99 0.96 EUD-600S740BV 31 ~ 76Vdc 600 W 94.0% 0.99 0.96 EUD-600S980BV (4) (4) Notes: (1) Output current range with constant power at 600W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C I-V Operating Area EUD-600S280BV EUD-600S420BV EUD-600S560BV EUD-600S740BV EUD-600S980BV 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 6.0 A Measured at full load and 120 Vac input. - - 3.5 A Measured at full load and 220 Vac input. - - 4.70 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (450- 600W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 224 mA 336 mA 448 mA 592 mA 784 mA - 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 2240 mA 3360 mA 4480 mA 5920 mA 7840 mA - 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-600S280BV EUD-600S420BV EUD-600S560BV EUD-600S740BV EUD-600S980BV - 290 V 190 V 150 V 118 V 87 V 295 V 200 V 155 V 120 V 95 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Input AC Current 2 Inrush Current(I t) PF 2 Notes 127-250 Vdc IEC60598-1; 240Vac/ 60Hz, grounding effectively At 220Vac input, 25℃ cold start, duration=7.64 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (360 - 600W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-600S280BV EUD-600S420BV EUD-600S560BV EUD-600S740BV EUD-600S980BV Output Current Setting Range with Constant Power EUD-600S280BV EUD-600S420BV EUD-600S560BV EUD-600S740BV EUD-600S980BV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s Measured at 120Vac input, 60%-100% Load. - - 0.5 s Measured at 220Vac input, 60%-100% Load. - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes Case temperature = 0C ~Tc max Return terminal is “OTP−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-600S280BV Io= 2240 mA Io= 2800 mA EUD-600S420BV Io= 3360 mA Io= 4200 mA EUD-600S560BV Io= 4480 mA Io= 5600 mA EUD-600S740BV Io= 5920 mA Io= 7400 mA EUD-600S980BV Io= 7840 mA Io= 9800 mA Efficiency at 220 Vac input: EUD-600S280BV Io= 2240 mA Io= 2800 mA EUD-600S420BV Io= 3360 mA Io= 4200 mA EUD-600S560BV Io= 4480 mA Io= 5600 mA EUD-600S740BV Io= 5920 mA Io= 7400 mA EUD-600S980BV Io= 7840 mA Io= 9800 mA Min. Typ. Max. 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 90.0% 89.5% 92.0% 91.5% - 89.5% 89.0% 91.5% 91.0% - 90.0% 89.5% 92.0% 91.5% - 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.5% 94.0% 93.5% - 92.0% 91.0% 94.0% 93.0% - Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C General Specifications (Continued) Parameter Min. Typ. Max. 93.0% 92.5% 95.0% 94.5% - 93.0% 92.0% 95.0% 94.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 91.5% 94.5% 93.5% - 92.5% 91.5% 94.5% 93.5% - Standby power - - 0.5 W MTBF - 200,000 Hours - Lifetime - 108,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-600S280BV Io= 2240 mA Io= 2800 mA EUD-600S420BV Io= 3360 mA Io= 4200 mA EUD-600S560BV Io= 4480 mA Io= 5600 mA EUD-600S740BV Io= 5920 mA Io= 7400 mA EUD-600S980BV Io= 7840 mA Io= 9800 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3515 g Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 10.83× 5.67 × 1.91 275 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 - Notes - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. DA, DA High Level 9.5V 16V 22.5V DA, DA Low Level -6.5V 0V 6.5V DA, DA Current 0mA - 2mA Notes 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Dimming Specifications (Continued) Parameter Dimming Output Range Min. Typ. Max. EUD-600S280BV EUD-600S420BV EUD-600S560BV EUD-600S740BV EUD-600S980BV 10%Ioset - Ioset EUD-600S280BV EUD-600S420BV EUD-600S560BV EUD-600S740BV EUD-600S980BV 224 mA 336 mA 448 mA 592 mA 784 mA - Ioset Notes 2240mA ≤ Ioset ≤ 2800mA 3360mA ≤ Ioset ≤ 4200mA 4480mA ≤ Ioset ≤ 5600mA 5920mA ≤ Ioset ≤ 7400mA 7840mA ≤ Ioset ≤ 9800mA 224mA ≤ Ioset < 2240mA 336mA ≤ Ioset < 3360mA 448mA ≤ Ioset < 4480mA 592mA ≤ Ioset < 5920mA 784mA ≤ Ioset < 7840mA Note: All specifications are typical at 25 C unless stated otherwise. Standards Compliance Safety Category CE Standard EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment DALI Standards DALI (2) Notes IEC62386-101,102 & part of 207 (3) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. (3) Optional Commands Implemented: 242 (query short circuit), 243 (query open circuit) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Derating Lifetime vs. Case Temperature Inrush Current Waveform 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Efficiency vs. Load EUD-600S280BV(Io=2240mA) EUD-600S280BV(Io=2800mA) EUD-600S420BV(Io=3360mA) EUD-600S420BV(Io=4200mA) EUD-600S560BV(Io=4480mA) EUD-600S560BV(Io=5600mA) 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C EUD-600S740BV(Io=5920mA) EUD-600S740BV(Io=7400mA) EUD-600S980BV(Io=7840mA) EUD-600S980BV(Io=9800mA) Power Factor 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset ≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  DALI Dimming The recommended implementation of the dimming control is provided below. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxBV 600W Programmable IP67 Driver with DALI Rev.C Implementation: DALI Dimming   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-600S420BV 价格&库存
很抱歉,暂时无法提供与“EUD-600S420BV”相匹配的价格&库存,您可以联系我们找货
