EUG-096S350DV
EUG-096S350DV
    INVENTRONICS(英飞特)
EUG-096S350DV 数据手册
EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Features • Ultra High Efficiency (Up to 93.0%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6kV line-line, 10kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) • SELV Output • Suitable for Independent Use • 7 Years Warranty Description The EUG-096SxxxDV series is a 96W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 45-700mA 450-700mA 530 mA Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) 90 ~ 305 Vac 74~213Vdc 96 W 100 ~ 250 Vdc 90 ~ 305 Vac 48~137Vdc 96 W 100 ~ 250 Vdc 90 ~ 305 Vac 140-2100mA 1400-2100mA 2100 mA 24 ~ 69Vdc 96 W 100 ~ 250 Vdc 90 ~ 305 Vac 245-3500mA 2450-3500mA 2800 mA 14 ~ 39Vdc 96 W 100 ~ 250 Vdc 70-1050mA 700-1050mA 700 mA Model Number 92.0% 0.99 0.96 EUG-096S070DV 93.0% 0.99 0.96 EUG-096S105DV 92.0% 0.99 0.96 EUG-096S210DV (4) 91.0% 0.99 0.96 EUG-096S350DV (4) Notes: (1) Output current range with constant power at 96W (2) Certified input voltage range: 100-240Vac or 100-250Vdc (except CCC, PSE, KS and BIS). (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E I-V Operation Area EUG-096S105DV % 60 Output Voltage(V) EUG-096S070DV ad Lo EUG-096S210DV EUG-096S350DV Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.32 A Measured at full load and 100 Vac input. - - 0.60 A Measured at full load and 220 Vac input. - - 1.65 A s 0.9 - - THD - - 20% THD - - 10% Input AC Current 2 Inrush Current(I t) PF 2 Notes 100-250Vdc IEC60598-1; 240Vac/ 60Hz At 220Vac input, 25℃ cold start, duration=760 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (58-96W) At 220-240Vac, 50-60Hz, 75%-100% Load (72-96W) 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 45 mA 70 mA 140 mA 245 mA - 700 mA 1050 mA 2100 mA 3500 mA 450 mA 700 mA 1400 mA 2450 mA - 700 mA 1050 mA 2100 mA 3500 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-096S070DV EUG-096S105DV EUG-096S210DV EUG-096S350DV - - 280 V 180 V 90 V 50 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Output Current Tolerance Output Current Setting(Ioset) Range EUG-096S070DV EUG-096S105DV EUG-096S210DV EUG-096S350DV Output Current Setting Range with Constant Power EUG-096S070DV EUG-096S105DV EUG-096S210DV EUG-096S350DV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset Notes At full load condition Measured at full load Measured at 120Vac input, 60%-100% Load. Measured at 220Vac input, 60%-100% Load. Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUG-096S070DV Io= 450mA Io= 700mA EUG-096S105DV Io= 700mA Io=1050mA EUG-096S210DV Io=1400mA Io=2100mA EUG-096S350DV Io=2450mA Io=3500mA Min. Typ. Max. 87.0% 86.0% 90.0% 89.0% - 88.5% 87.0% 91.5% 90.0% - 87.0% 87.0% 90.0% 90.0% - 86.0% 85.5% 89.0% 88.5% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E General Specifications (Continued) Parameter Min. Typ. Max. 90.0% 89.0% 92.0% 91.0% - 91.0% 89.0% 93.0% 91.0% - 89.5% 90.0% 91.5% 92.0% - 89.0% 88.0% 91.0% 90.0% - 90.5% 89.0% 92.5% 91.0% - 91.5% 89.5% 93.5% 91.5% - 90.0% 90.5% 92.0% 92.5% - 89.5% 88.5% 91.5% 90.5% - MTBF - 339,000 Hours - Lifetime - 98,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 220 Vac input: EUG-096S070DV Io= 450mA Io= 700mA EUG-096S105DV Io= 700mA Io=1050mA EUG-096S210DV Io=1400mA Io=2100mA EUG-096S350DV Io=2450mA Io=3500mA Efficiency at 277 Vac input: EUG-096S070DV Io= 450mA Io= 700mA EUG-096S105DV Io= 700mA Io=1050mA EUG-096S210DV Io=1400mA Io=2100mA EUG-096S350DV Io=2450mA Io=3500mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.92 × 2.66 × 1.44 201 × 67.5 × 36.5 6.85 × 2.66 × 1.44 174 × 67.5 × 36.5 - 890 g Notes - Note: All specifications are typical at 25°C unless otherwise stated. 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. Notes -20 V - 20 V 200 uA 300 uA 450 uA Vdim(+) = 0 V 450mA ≤ Ioset ≤ 700mA 700mA ≤ Ioset ≤ 1050mA 1400mA ≤ Ioset ≤ 2100mA 2450mA ≤ Ioset ≤ 3500mA 45mA ≤ Ioset < 450mA 70mA ≤ Ioset < 700mA 140mA ≤ Ioset < 1400mA 245mA ≤ Ioset < 2450mA EUG-096S070DV EUG-096S105DV EUG-096S210DV EUG-096S350DV 10%Ioset - Ioset EUG-096S070DV EUG-096S105DV EUG-096S210DV EUG-096S350DV 45mA 70mA 140mA 245mA - Ioset Recommended Dimming Range for 0-5V 0V - 5V Dimming mode set to 0-5V in PC interface. Recommended Dimming Range for 0-10V 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Dimming Output Range PWM_in Duty Cycle Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25°C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test (2) 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Safety & EMC Compliance (Continued) Safety Category Standard EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Efficiency vs. Load EUG-096S070DV(Io=450mA) EUG-096S070DV(Io=700mA) EUG-096S105DV(Io=700mA) EUG-096S105DV(Io=1050mA) EUG-096S210DV(Io=1400mA) EUG-096S210DV(Io=2100mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E EUG-096S350DV(Io=2450mA) EUG-096S350DV(Io=3500mA) Power Factor Total Harmonic Distortion 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV  96W Programmable IP67 Driver Rev. E 0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Set the timing curve by pulling the sliders. 11 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Programming Connection Diagram Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 (Programmer) datasheet for details. Mechanical Outline IN P U T (V D E H 0 5 R N -F 3 *1 .0 m m 2 7 .2 ) D IM M IN G W IR E (V D E 3 *0 .5 m m 2 B L A C K /W H IT E PU RPLE GRAY Tc A C /L (B R O W N ) A C /N (B L U E ) GND (Y E L L O W /G R E E N ) 6 .3 ) V + (B R O W N ) V - (B L U E ) O U T P U T (V D E H 0 5 R N -F 2 * 1 .0 m m 2 6 .8 ) P R O J: U n s p e c ifie d to le ra n c e :± 1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 12 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-096SxxxDV 96W Programmable IP67 Driver Rev. E Revision History Description of Change Change Date Rev. 2015-07-08 A 2016-02-29 2017-07-27 2017-10-26 2018-01-31 Item B C D E From To Datasheets Release / / TUV, BIS / Added EUG-096S070DV / Added Net Weight / Updated Safety & EMC Compliance KS Added Mechanical Outline / Updated Models Notes Updated Input Specifications PF/THD Updated Output Specifications Temperature Coefficient of Ioset Updated General Specifications Dimensions Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features 7 Years Warranty Added Operating Case Temperature for / Warranty Tc_w Updated Description / Updated General Specifications Lifetime Updated General Specifications Operating Case Temperature for Warranty Updated Tc_w Lifetime vs. Case Temperature / Updated 13 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-096S350DV 价格&库存
很抱歉,暂时无法提供与“EUG-096S350DV”相匹配的价格&库存,您可以联系我们找货
