EUM-200S150DT
EUM-200S150DT
    INVENTRONICS(英飞特)
EUM-200S150DT 数据手册
EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Features  Compact Metal Case with Excellent Thermal Performance  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 1-5V/1-10V/10V PWM/3-Timer-Modes Dimmable  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUM-200SxxxDx series is a 200W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 90-305Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast and roadway, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 105-1500mA 1050-1500mA 1050 mA 127~300 Vdc 90~305 Vac/ 180-2800mA 1800-2800mA 2100 mA 127~300 Vdc 90~305 Vac/ 350-5600mA 3500-5600mA 4200 mA 127~300 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac Model Number (5) (6) 95~286 Vdc 200 W 93.5% 0.99 0.96 EUM-200S105Dx 67~190 Vdc 200 W 93.0% 0.99 0.96 EUM-200S150Dx 36~111 Vdc 200 W 92.5% 0.99 0.96 EUM-200S280Dx 18 ~ 57 Vdc 200 W 92.0% 0.99 0.96 EUM-200S560Dx (4) (4) Notes: (1) Output current range with constant power at 200W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models; x = B are BIS models. (6) All the models are certificated to KS, except EUM-200S105Dx. 1 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A I-V Operation Area EUM-200S105Dx 300 (70,286) 250 (455,286) (700,286) (10%Ioset,200/Ioset) (Ioset,200/Ioset) 10 % 65 200 EUM-200S150Dx 0% ad Lo 150 Lo ad (1050,190) (1050,124) 100 (Ioset,95) (105,95) 50 Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 (1050,95) 200 400 600 800 1000 1200 Output Current (mA) Note: 700mA Ioset 1050mA EUM-200S280Dx EUM-200S560Dx Input Specifications Parameter Min. Typ. Max. Notes Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 2.00 A Measured at 100% load and 120 Vac input. - - 1.05 A Measured at 100% load and 220 Vac input. Leakage Current Input AC Current 2 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. - - 4.20 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 180 mA 350 mA - 1050 mA 1500 mA 2800 mA 5600 mA 700 mA 1050 mA 1800 mA 3500 mA - 1050 mA 1500 mA 2800 mA 5600 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUM-200S105Dx EUM-200S150Dx EUM-200S280Dx EUM-200S560Dx - - 320 V 210 V 120 V 65 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/°C - 2 Inrush Current(I t) PF 2 Notes At 220Vac input, 25°C cold start, duration=848 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 65%-100% Load (130-200W) At 220-240Vac, 50-60Hz, 75%-100% Load (150-200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUM-200S105Dx EUM-200S150Dx EUM-200S280Dx EUM-200S560Dx Output Current Setting Range with Constant Power EUM-200S105Dx EUM-200S150Dx EUM-200S280Dx EUM-200S560Dx Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 120-277Vac input, 65%-100% Load Case temperature = 0°C ~Tc max 3 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A General Specifications Parameter Min. Typ. Max. 88.5% 89.0% 90.5% 91.0% - 88.5% 88.5% 90.5% 90.5% - 87.0% 87.0% 89.0% 89.0% - 87.5% 87.0% 89.5% 89.0% - 91.5% 91.5% 93.5% 93.5% - 91.0% 91.0% 93.0% 93.0% - 90.5% 90.0% 92.5% 92.0% - 90.0% 89.5% 92.0% 91.5% - 92.0% 92.0% 94.0% 94.0% - 91.5% 91.5% 93.5% 93.5% - 91.0% 90.5% 93.0% 92.5% - 90.5% 90.0% 92.5% 92.0% - MTBF - 267,000 Hours - Lifetime - 100,000 Hours - -40°C - +90°C -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 120 Vac input: EUM-200S105Dx Io= 700 mA Io=1050 mA EUM-200S150Dx Io=1050 mA Io=1500 mA EUM-200S280Dx Io=1800 mA Io=2800 mA EUM-200S560Dx Io=3500 mA Io=5600 mA Efficiency at 220 Vac input: EUM-200S105Dx Io= 700 mA Io=1050 mA EUM-200S150Dx Io=1050 mA Io=1500 mA EUM-200S280Dx Io=1800 mA Io=2800 mA EUM-200S560Dx Io=3500 mA Io=5600 mA Efficiency at 277 Vac input: EUM-200S105Dx Io= 700 mA Io=1050 mA EUM-200S150Dx Io=1050 mA Io=1500 mA EUM-200S280Dx Io=1800 mA Io=2800 mA EUM-200S560Dx Io=3500 mA Io=5600 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 780 g Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.40 × 2.36 × 1.44 188 × 60 × 36.5 6.73 × 2.36 × 1.44 171 × 60 × 36.5 - Notes - 4 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1800 mA ≤ Ioset ≤ 2800 mA 3500 mA ≤ Ioset ≤ 5600 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 180 mA ≤ Ioset < 1800 mA 350 mA ≤ Ioset < 3500 mA EUM-200S105Dx EUM-200S150Dx EUM-200S280Dx EUM-200S560Dx 10%Ioset - Ioset EUM-200S105Dx EUM-200S150Dx EUM-200S280Dx EUM-200S560Dx 70 mA 105 mA 180 mA 350 mA - Ioset 0.25 V - 4.75 V Dimming mode set to 1-5V in PC interface. 1V - 9V Default 1-10V dimming mode with positive logic. PWM_in High Level - 10V - PWM_in Low Level - 0V - 200 Hz - 2 KHz 0% - 100% Dimming Output Range Recommended Dimming Range for 1-5V Recommended Dimming Range for 1-10V PWM_in Frequency Range PWM_in Duty Cycle Safety &EMC Compliance Safety Category Standard UL/CUL UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KS KS C 7655 BIS IS 15885(Part2/Sec13) EAC ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 NOM NOM-058-SCFI EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 5 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Safety &EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 6 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUM-200S105Dx(Io=700mA) EUM-200S105Dx(Io=1050mA) 7 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A EUM-200S150Dx(Io=1050mA) EUM-200S150Dx(Io=1500mA) EUM-200S280Dx(Io=1800mA) EUM-200S280Dx(Io=2800mA) EUM-200S560Dx(Io=3500mA) EUM-200S560Dx(Io=5600mA) 8 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  1-5V Dimming The recommended implementation of the dimming control is provided below. 9 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-5V voltage source signal or passive components like zener. 3. When 1-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  1-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic 10 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx 200W Programmable IP66/IP67 Driver Rev. A Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like 3.  zener. When 1-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current. 10V PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 11 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUM-200SxxxDx   200W Programmable IP66/IP67 Driver Rev. A Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-200S150DT 价格&库存
很抱歉,暂时无法提供与“EUM-200S150DT”相匹配的价格&库存,您可以联系我们找货
EUM-200S150DT
    EUM-200S150DT
      EUM-200S150DT
