EUM-240S150LT
EUM-240S150LT
    INVENTRONICS(英飞特)
EUM-240S150LT 数据手册
EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Features  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with NFC  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  INV Digital Dimming, UART Based Communication Protocol Compliant with T/CSA-051  Dim-to-Off with Standby Power ≤ 0.5 W   Always-on Auxiliary Power: 12Vdc, 250mA, 3W (Transient Peak Power up to 10W) Integrated Power Monitoring with High Accuracy up to ±1%  Output Lumen Compensation  End-of-Life Indicator  Thermal Sensing and Protection for LED Module  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IUVP, IOVP, OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for use in a Class I, Division 2 Hazardous (Classified) Location  7 Years Warranty Description The EUM-240SxxxLx series is a 240W, constant-current, NFC programmable and IP66/IP67 rated LED driver that operates from 90-305Vac input with excellent power factor. Created for smart lighting and health monitoring applications, this family provides integrated AC power monitoring with an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol that complies with T/CSA051. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 105-1500mA 1050-1500mA 1050 mA 127~300 Vdc 90~305 Vac/ 215-3500mA 2150-3500mA 2150 mA 127~300 Vdc 90~305 Vac/ 420-6700mA 4200-6700mA 4900 mA 127~300 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Typical Max. Typical Output Efficiency Power Factor Power (3) 120Vac 220Vac Model Number (5) 115~343Vdc 240 W 94.0% 0.99 0.96 EUM-240S105Lx 80~229 Vdc 240 W 93.5% 0.99 0.96 EUM-240S150Lx 35~111 Vdc 240 W 93.0% 0.99 0.96 EUM-240S350Lx (4) 18 ~ 57 Vdc 240 W 92.5% 0.99 0.96 EUM-240S670Lx (4) Notes: (1) Output current range with constant power at 240W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models; x = B are BIS models. 1 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A I-V Operation Area EUM-240S105Lx EUM-240S150Lx EUM-240S350Lx EUM-240S670Lx Input Specifications Parameter Min. Typ. Max. Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/60Hz - - 0.70 mA IEC60598-1; 240Vac/60Hz,  - - 2.54 A Measured at 100% load and 120 Vac input. - - 1.34 A Measured at 100% load and 220 Vac input. - - 4.39 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 2 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 220Vac input, 25C cold start, duration=1.74 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 215 mA 420 mA - 1050 mA 1500 mA 3500 mA 6700 mA 700 mA 1050 mA 2150 mA 4200 mA - 1050 mA 1500 mA 3500 mA 6700 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUM-240S105Lx EUM-240S150Lx EUM-240S350Lx EUM-240S670Lx - - 400 V 290 V 120 V 75 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA PF Notes At 100-277Vac, 50-60Hz, 65%-100%load (156-240W) At 220-240Vac, 50-60Hz, 75%-100%load (180-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUM-240S105Lx EUM-240S150Lx EUM-240S350Lx EUM-240S670Lx Output Current Setting Range with Constant Power EUM-240S105Lx EUM-240S150Lx EUM-240S350Lx EUM-240S670Lx Total Output Current Ripple (pk-pk) 3 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 120-277Vac input,65%-100% Load Case temperature = 0C~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 250mA. 850mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 250mA. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A General Specifications Parameter Min. Typ. Max. 89.0% 89.0% 91.0% 91.0% - 88.5% 88.5% 90.5% 90.5% - 88.0% 87.5% 90.0% 89.5% - 87.5% 86.5% 89.5% 88.5% - 92.0% 92.0% 94.0% 94.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 90.5% 93.0% 92.5% - 90.5% 90.0% 92.5% 92.0% - 92.5% 92.5% 94.5% 94.5% - 92.0% 91.5% 94.0% 93.5% - 91.5% 90.5% 93.5% 92.5% - 91.0% 90.0% 93.0% 92.0% - -1% - 1% Standby Power - - 0.5 W MTBF - 201,000 Hours - Lifetime - 101,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 7 years warranty Humidity: 10% RH to 95% RH; Storage Temperature -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 120 Vac input: EUM-240S105Lx Io= 700 mA Io=1050 mA EUM-240S150Lx Io=1050 mA Io=1500 mA EUM-240S350Lx Io=2150 mA Io=3500 mA EUM-240S670Lx Io=4200 mA Io=6700 mA Efficiency at 220 Vac input: EUM-240S105Lx Io= 700 mA Io=1050 mA EUM-240S150Lx Io=1050 mA Io=1500 mA EUM-240S350Lx Io=2150 mA Io=3500 mA EUM-240S670Lx Io=4200 mA Io=6700 mA Efficiency at 277 Vac input: EUM-240S105Lx Io= 700 mA Io=1050 mA EUM-240S150Lx Io=1050 mA Io=1500 mA EUM-240S350Lx Io=2150 mA Io=3500 mA EUM-240S670Lx Io=4200 mA Io=6700 mA Power Monitoring Accuracy 4 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input and 100%Load Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A General Specifications (Continued) Parameter Min. Typ. Max. Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Notes With mounting ear 8.58 × 2.66 × 1.52 218 × 67.5 × 38.5 7.91 × 2.66 × 1.52 201 × 67.5 × 38.5 - 1050 g - Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA Dimming Specifications EUM-240S105Lx EUM-240S150Lx EUM-240S350Lx EUM-240S670Lx 10%Ioset - Ioset EUM-240S105Lx EUM-240S150Lx EUM-240S350Lx EUM-240S670Lx 70 mA 105 mA 215 mA 420 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis 5 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 2150 mA ≤ Ioset ≤ 3500 mA 4200 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 215 mA ≤ Ioset < 2150 mA 420 mA ≤ Ioset < 4200 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Safety &EMC Compliance Safety Category Standard UL/CUL UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 BIS IS 15885(Part2/Sec13) KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 6 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Derating Lifetime vs. Case Temperature Inrush Current Waveform 7 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Efficiency vs. Load EUM-240S105Lx(Io=700mA) EUM-240S105Lx(Io=1050mA) EUM-240S150Lx(Io=1050mA) EUM-240S150Lx(Io=1500mA) EUM-240S350Lx(Io=2150mA) EUM-240S350Lx(Io=3500mA) 8 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A EUM-240S670Lx(Io=4200mA) EUM-240S670Lx(Io=6700mA) Power Factor Total Harmonic Distortion 9 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Protection Functions Parameter External Thermal Protection Min. Typ. Max. Notes R1 (Start derating) - 1.67 kΩ - The output current starts to decrease linearly when the actual NTC resistance value is lower than R1, until R2 is reached. R2 (Stop derating) - 1.27 kΩ - When the actual NTC resistance value is lower than R2, the output current will stay at the programmed Protection Current Floor. 10%Ioset 20%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 20%) Iomin 20%Ioset 100%Ioset 10%Ioset ≤ Iomin (default setting is 20%) Protection Current Floor Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP) Input Under Voltage Protection Input Under Voltage Recovery Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 70 Vac 80 Vac 90 Vac Turn off the output when the input voltage falls below protection voltage. 75 Vac 85 Vac 95 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive stabilized input over voltage conditions up to 350Vac for a total of 8 hours. Note: (1) The recommended NTC type is 10kΩ NTC, Murata NCP18XH103J03RB.  Input Under Voltage Protection Diagram 10 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx  240W NFC Driver with INV Digital Dimming Rev. A Input Over Voltage Protection Diagram Io Recovery Protection 320 Vac 310 Vac Vin Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic Implementation 2: Negative logic 11 / 16 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-240S150LT 价格&库存
很抱歉,暂时无法提供与“EUM-240S150LT”相匹配的价格&库存,您可以联系我们找货
EUM-240S150LT
    EUM-240S150LT
