EUP-096S210SV
EUP-096S210SV
    INVENTRONICS(英飞特)
EUP-096S210SV 数据手册
EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Features  High Efficiency (Up to 93%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Dip-switch  Non-dimming Control  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  5 Years Warranty Description The EUP-096SxxxSV series is a 96W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including street, tunnel and bay. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 350-700mA 450-700mA 550 mA 700-1050mA 700-1050mA 700 mA 850-1500mA 1050-1500mA 1050 mA 1000-2100mA 1400-2100mA 2100 mA 2100-3500mA 2625-3500mA 2800 mA Input Voltage Range(2) Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 127~250 Vdc Model Number 74~213Vdc 96 W 93.0% 0.99 0.96 EUP-096S070SV 48~137Vdc 96 W 93.0% 0.99 0.96 EUP-096S105SV 32~91Vdc 96 W 92.5% 0.99 0.96 EUP-096S150SV(4) 24 ~ 69Vdc 96 W 92.0% 0.99 0.96 EUP-096S210SV 14 ~ 36Vdc 96 W 91.5% 0.99 0.96 EUP-096S350SV (4) (4) Notes: (1) Output current range with constant power at 96W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE, KS and BIS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.10 A - - 0.65 A Input AC Current Notes 127~250 Vdc IEC60598-1; 240Vac/ 60Hz,  Measured at input. Measured at input. 100% load and 120 Vac 100% load and 220 Vac 1 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Input Specifications (Continued) Parameter Min. Typ. Max. - - 1.30 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (72-96W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 350 mA 700 mA 850 mA 1000 mA 2100 mA - 700 mA 1050 mA 1500 mA 2100 mA 3500 mA 450 mA 700 mA 1050 mA 1400 mA 2625 mA - 700 mA 1050 mA 1500 mA 2100 mA 3500 mA - 5%Iomax 10%Iomax 100% load. 20 MHz BW Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUP-096S070SV EUP-096S105SV EUP-096S150SV EUP-096S210SV EUP-096S350SV - - 250 V 160 V 110 V 85 V 42 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 2 Inrush Current(I t) PF 2 Notes At 220Vac input, 25C cold start, duration=640μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (58-96W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUP-096S070SV EUP-096S105SV EUP-096S150SV EUP-096S210SV EUP-096S350SV Output Current Setting Range with Constant Power EUP-096S070SV EUP-096S105SV EUP-096S150SV EUP-096S210SV EUP-096S350SV Total Output Current Ripple (pk-pk) Turn-on Delay Time Temperature Coefficient of Ioset 100% load 100% load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. 2 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D General Specifications Parameter Min. Typ. Max. 88.5% 87.5% 90.5% 89.5% - 88.5% 87.0% 90.5% 89.0% - 88.0% 86.5% 90.0% 88.5% - 87.5% 86.5% 89.5% 88.5% - 87.5% 86.0% 89.5% 88.0% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.5% 93.0% 91.5% - 90.5% 89.0% 92.5% 91.0% - 90.0% 89.0% 92.0% 91.0% - 89.5% 88.5% 91.5% 90.5% - 91.0% 90.0% 93.0% 92.0% - 91.5% 90.0% 93.5% 92.0% - 90.5% 89.0% 92.5% 91.0% - 90.0% 89.0% 92.0% 91.0% - 90.0% 89.0% 92.0% 91.0% - MTBF - 355,000 Hours - Lifetime - 77,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Efficiency at 120 Vac input: EUP-096S070SV Io= 450 mA Io= 700 mA EUP-096S105SV Io= 700 mA Io=1050 mA EUP-096S150SV Io=1050 mA Io=1500 mA EUP-096S210SV Io=1400 mA Io=2100 mA EUP-096S350SV Io=2625 mA Io=3500 mA Efficiency at 220 Vac input: EUP-096S070SV Io= 450 mA Io= 700 mA EUP-096S105SV Io= 700 mA Io=1050 mA EUP-096S150SV Io=1050 mA Io=1500 mA EUP-096S210SV Io=1400 mA Io=2100 mA EUP-096S350SV Io=2625 mA Io=3500 mA Efficiency at 277 Vac input: EUP-096S070SV Io= 450 mA Io= 700 mA EUP-096S105SV Io= 700 mA Io=1050 mA EUP-096S150SV Io=1050 mA Io=1500 mA EUP-096S210SV Io=1400 mA Io=2100 mA EUP-096S350SV Io=2625 mA Io=3500mA Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Case temperature for 5 years warranty 3 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D General Specifications (Continued) Parameter Storage Temperature Min. Typ. Max. -40°C - +85°C Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes Humidity: 5%RH to 100%RH With mounting ear 7.17 × 2.37 × 1.44 182 × 60 × 36.5 6.34 × 2.37 × 1.44 161 × 60 × 36.5 Net Weight - 750 g - Note: All specifications are typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 4 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Derating Lifetime vs. Case Temperature Inrush Current Waveform 5 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Efficiency vs. Load EUP-096S070SV(Io=450mA) EUP-096S070SV(Io=700mA) EUP-096S105SV(Io=700mA) EUP-096S105SV(Io=1050mA) EUP-096S150SV(Io=1050mA) EUP-096S150SV(Io=1500mA) 6 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D EUP-096S210SV(Io=1400mA) EUP-096S210SV(Io=2100mA) EUP-096S350SV(Io=2625mA) EUP-096S350SV(Io=3500mA) Power Factor 7 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Total Harmonic Distortion T Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Output Current vs. Dip Switch Setting  EUP-096S070SV Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. OFF ON ON ON 700mA 74V 137V OFF ON ON OFF 650mA 74V 148V OFF ON OFF ON 600mA 80V 160V OFF ON OFF OFF 550mA 87V 174V OFF OFF ON ON 500mA 96V 192V OFF OFF ON OFF 450mA 107V 213V OFF OFF OFF ON 400mA 120V 213V OFF OFF OFF OFF 350mA 137V 213V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 8 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV  96W AOC IP67 Driver Rev. D EUP-096S105SV Output Current Setting (Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1050mA 48V 91V ON ON ON OFF 1000mA 48V 96V ON ON OFF ON 950mA 51V 101V ON ON OFF OFF 900mA 53V 106V ON OFF ON ON 850mA 57V 113V ON OFF ON OFF 800mA 60V 120V ON OFF OFF ON 750mA 64V 128V ON OFF OFF OFF 700mA 69V 137V Notes / Output Current Setting with Constant Power. EUP-096S150SV Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1500mA 32V 64V ON ON ON OFF 1450mA 33V 66V ON ON OFF ON 1400mA 35V 68.5V ON ON OFF OFF 1350mA 36V 71V ON OFF ON ON 1300mA 37V 74V ON OFF ON OFF 1250mA 39V 77V ON OFF OFF ON 1200mA 40V 80V ON OFF OFF OFF 1150mA 42V 83.5V OFF ON ON ON 1100mA 44V 87V OFF ON ON OFF 1050mA 46V 91V OFF ON OFF ON 1000mA 48V 91V OFF ON OFF OFF 950mA 51V 91V OFF OFF ON ON 900mA 54V 91V OFF OFF ON OFF 850mA 57V 91V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 9 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV  96W AOC IP67 Driver Rev. D EUP-096S210SV Output Current Setting (Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2100mA 24V 45.5V ON ON ON OFF 2000mA 24V 48V ON ON OFF ON 1900mA 26V 50.5V ON ON OFF OFF 1800mA 27V 53V ON OFF ON ON 1700mA 29V 56.5V ON OFF ON OFF 1600mA 30V 60V ON OFF OFF ON 1500mA 32V 64V ON OFF OFF OFF 1400mA 35V 69V OFF ON ON ON 1300mA 37V 69V OFF ON ON OFF 1200mA 40V 69V OFF ON OFF ON 1100mA 44V 69V OFF ON OFF OFF 1000mA 48V 69V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. EUP-096S350SV Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 3500mA 14V 27.5V ON ON ON OFF 3325mA 15V 28.5V ON ON OFF ON 3150mA 16V 30.5V ON ON OFF OFF 2975mA 16V 32V ON OFF ON ON 2800mA 17V 34V ON OFF ON OFF 2625mA 18V 36V ON OFF OFF ON 2450mA 20V 36V ON OFF OFF OFF 2275mA 21V 36V OFF ON ON ON 2100mA 23V 36V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. Notes: 1. Dip switch must be set in the setting range as specified to insure the driver operates as expected. 2. Endcap covering dip switch must be tight to insure IP67 rating. 10 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Mechanical Outline INPUT (VDE H05RN-F 3*1.0mm2 7.2) OUTPUT (VDE H05RN-F 2*1.0mm2 6.8) V+(BROWN) V-(BLUE) AC/L(BROWN) AC/N(BLUE) GND(YELLOW/GREEN) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 11 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-096SxxxSV 96W AOC IP67 Driver Rev. D Revision History Change Date Rev. 2016-08-09 A 2017-11-29 2018-04-20 2018-07-16 B Description of Change Item From To Datasheets Release / / Features / Updated Models EUP-096S150SV Added Input Specifications PF/THD Updated Output Current Setting(Ioset) Range EUP-096S150SV Added Output Current Setting Range with EUP-096S150SV Constant Power Added No Load Output Voltage EUP-096S150SV Added Temperature Coefficient of Ioset Max 0.03%/C Typ 0.03%/C Efficiency at 120 Vac input EUP-096S150SV Added Efficiency at 220 Vac input EUP-096S150SV Added Efficiency at 277 Vac input EUP-096S150SV Added General Specifications Operating Case Temperature Updated for Warranty Tc_w Safety &EMC Compliance / Updated Efficiency vs. Load EUP-096S150SV Added Output Current vs. Dip Switch Setting EUP-096S150SV Added Description / Updated Mechanical Outline / Updated EAC / Added C D 12 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUP-096S210SV 价格&库存
很抱歉,暂时无法提供与“EUP-096S210SV”相匹配的价格&库存,您可以联系我们找货
