EUP-240S210SV
EUP-240S210SV
    INVENTRONICS(英飞特)
EUP-240S210SV 数据手册
EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Features  Ultra High Efficiency (Up to 93.5%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Dip-switch  Non-dimming Control  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  5 Years Warranty Description The EUP-240SxxxSV series is a 240W, constant-current, AOC IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) 90~305 Vac/ 114~343Vdc 240W 127~250 Vdc 90~305 Vac/ 850-1500mA 1050-1500mA 1050 mA 80~229Vdc 240W 127~250 Vdc 500-1050mA 700-1050mA 700 mA Model Number (4) 93.5% 0.99 0.96 EUP-240S105SV 93.5% 0.99 0.96 EUP-240S150SV 1000-2100mA 1400-2100mA 1400 mA 90~305 Vac/ 57~171Vdc 240W 127~250 Vdc 93.5% 0.99 0.96 EUP-240S210SV 2000-4200mA 2800-4200mA 4200 mA 90~305 Vac/ 29 ~ 86Vdc 240W 127~250 Vdc 92.5% 0.99 0.96 EUP-240S420SV 3400-6700mA 4600-6700mA 6700 mA 90~305 Vac/ 18 ~ 52Vdc 240W 127~250 Vdc 92.0% 0.99 0.96 EUP-240S670SV (5) (5) Notes: (1) Output current range with constant power at 240W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE, KS and BIS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS,except EUP-240S105SV (5) SELV Output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Notes 127~250 Vdc IEC60598-1; 240Vac/ 60Hz 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.5 A - - 1.3 A - - 3.20 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 500 mA 850 mA 1000 mA 2000 mA 3400 mA - 1050 mA 1500 mA 2100 mA 4200 mA 6700 mA 700 mA 1050 mA 1400 mA 2800 mA 4600 mA - 1050 mA 1500 mA 2100 mA 4200 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUP-240S105SV EUP-240S150SV EUP-240S210SV EUP-240S420SV EUP-240S670SV - - 390 V 270 V 200 V 110 V 70 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - Input AC Current 2 Inrush Current(I t) PF 2 Notes Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25C cold start, duration=960 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (144-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUP-240S105SV EUP-240S150SV EUP-240S210SV EUP-240S420SV EUP-240S670SV Output Current Setting Range with Constant Power EUP-240S105SV EUP-240S150SV EUP-240S210SV EUP-240S420SV EUP-240S670SV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Turn-on Delay Time Temperature Coefficient of Ioset 100% load 100% load. 20 MHz BW 100% load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C General Specifications Parameter Min. Typ. Max. 88.5% 87.5% 90.5% 89.5% - 88.5% 87.5% 90.5% 89.5% - 88.5% 87.0% 90.5% 89.0% - 87.5% 85.5% 89.5% 87.5% - 87.0% 85.0% 89.0% 87.0% - 91.5% 90.0% 93.5% 92.0% - 91.5% 90.0% 93.5% 92.0% - 91.5% 90.0% 93.5% 92.0% - 90.5% 88.5% 92.5% 90.5% - 90.0% 88.0% 92.0% 90.0% - 92.0% 90.5% 94.0% 92.5% - 92.0% 90.5% 94.0% 92.5% - 92.0% 90.5% 94.0% 92.5% - 91.0% 89.0% 93.0% 91.0% - 90.5% 88.5% 92.5% 90.5% - MTBF - 241,000 Hours - Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Lifetime - 84,000 Hours - Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Efficiency at 120 Vac input: EUP-240S105SV Io= 700 mA Io=1050 mA EUP-240S150SV Io=1050 mA Io=1500 mA EUP-240S210SV Io=1400 mA Io=2100 mA EUP-240S420SV Io=2800 mA Io=4200 mA EUP-240S670SV Io=4600 mA Io=6700 mA Efficiency at 220 Vac input: EUP-240S105SV Io= 700 mA Io=1050 mA EUP-240S150SV Io=1050 mA Io=1500 mA EUP-240S210SV Io=1400 mA Io=2100 mA EUP-240S420SV Io=2800 mA Io=4200 mA EUP-240S670SV Io=4600 mA Io=6700 mA Efficiency at 277 Vac input: EUP-240S105SV Io= 700 mA Io=1050 mA EUP-240S150SV Io=1050 mA Io=1500 mA EUP-240S210SV Io=1400 mA Io=2100 mA EUP-240S420SV Io=2800 mA Io=4200 mA EUP-240S670SV Io=4600 mA Io=6700 mA Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C General Specifications (Continued) Parameter Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Min. Typ. Max. -40°C - +90°C -40°C - +75C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 9.17 × 2.66 × 1.56 233 × 67.5 × 39.7 8.35 × 2.66 × 1.56 212 × 67.5 × 39.7 Net Weight - Notes 1200 g - Note: All specifications are typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT: level 3, criteria A EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Derating Lifetime vs. Case Temperature Inrush Current Waveform 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Efficiency vs. Load EUP-240S105SV(lo=700mA) EUP-240S105SV(lo=1050mA) EUP-240S150SV(lo=1050mA) EUP-240S150SV(lo=1500mA) EUP-240S210SV(lo=1400mA) EUP-240S210SV(lo=2100mA) 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C EUP-240S420SV(lo=2800mA) EUP-240S420SV(lo=4200mA) EUP-240S670SV(lo=4600mA) EUP-240S670SV(lo=6700mA) Power Factor 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Output Current vs. Dip Switch Setting  EUP-240S105SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1050mA 114V 228V ON ON ON OFF 1000mA 120V 240V ON ON OFF ON 950mA 127V 253V ON ON OFF OFF 900mA 134V 267V ON OFF ON ON 850mA 141V 282V ON OFF ON OFF 800mA 150V 300V ON OFF OFF ON 750mA 160V 320V ON OFF OFF OFF 700mA 172V 343V OFF ON ON ON 650mA 185V 343V OFF ON ON OFF 600mA 200V 343V OFF ON OFF ON 550mA 218V 343V OFF ON OFF OFF 500mA 240V 343V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV  240W AOC IP67 Driver Rev. C EUP-240S150SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1500mA 80V 160V ON ON ON OFF 1450mA 83V 165V ON ON OFF ON 1400mA 86V 171V ON ON OFF OFF 1350mA 89V 178V ON OFF ON ON 1300mA 93V 185V ON OFF ON OFF 1250mA 96V 192V ON OFF OFF ON 1200mA 100V 200V ON OFF OFF OFF 1150mA 105V 209V OFF ON ON ON 1100mA 109V 218V OFF ON ON OFF 1050mA 115V 229V OFF ON OFF ON 1000mA 120V 229V OFF ON OFF OFF 950mA 127V 229V OFF OFF ON ON 900mA 134V 229V OFF OFF ON OFF 850mA 142V 229V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV  240W AOC IP67 Driver Rev. C EUP-240S210SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2100mA 57V 114V ON ON ON OFF 2000mA 60V 120V ON ON OFF ON 1900mA 63V 126V ON ON OFF OFF 1800mA 67V 133V ON OFF ON ON 1700mA 71V 141V ON OFF ON OFF 1600mA 75V 150V ON OFF OFF ON 1500mA 80V 160V ON OFF OFF OFF 1400mA 86V 171V OFF ON ON ON 1300mA 92V 171V OFF ON ON OFF 1200mA 100V 171V OFF ON OFF ON 1100mA 109V 171V OFF ON OFF OFF 1000mA 120V 171V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV  240W AOC IP67 Driver Rev. C EUP-240S420SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 4200mA 29V 57V ON ON ON OFF 4000mA 30V 60V ON ON OFF ON 3800mA 32V 63V ON ON OFF OFF 3600mA 34V 66.5V ON OFF ON ON 3400mA 36V 70.5V ON OFF ON OFF 3200mA 38V 75V ON OFF OFF ON 3000mA 40V 80V ON OFF OFF OFF 2800mA 43V 86V OFF ON ON ON 2600mA 46V 86V OFF ON ON OFF 2400mA 50V 86V OFF ON OFF ON 2200mA 55V 86V OFF ON OFF OFF 2000mA 60V 86V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 12 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV  240W AOC IP67 Driver Rev. C EUP-240S670SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 6700mA 18V 36V ON ON ON OFF 6400mA 19V 37.5V ON ON OFF ON 6100mA 20V 39.5V ON ON OFF OFF 5800mA 21V 41.5V ON OFF ON ON 5500mA 22V 43.5V ON OFF ON OFF 5200mA 23V 46V ON OFF OFF ON 4900mA 25V 49V ON OFF OFF OFF 4600mA 26V 52V OFF ON ON ON 4300mA 28V 52V OFF ON ON OFF 4000mA 30V 52V OFF ON OFF ON 3700mA 33V 52V OFF ON OFF OFF 3400mA 35V 52V Notes: 1. 2. Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. Dip switch must be set in the setting range as specified to insure the driver operates as expected. Endcap covering dip switch must be tight to insure IP67 rating. Mechanical Outline INPUT (VDE H05RN-F 3C*1.0mm 2 OUTPUT (VDE H05RN-F 2C*1.0mm 2 7.2 ) AC/L(BROWN) AC/N (BLUE) GND(YELLOW/GREEN) Tc 6.8) V+(BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 13 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 14 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-240SxxxSV 240W AOC IP67 Driver Rev. C Revision History Change Date Rev. 2017-11-02 A 2018-04-27 B 2018-07-16 C Description of Change Item From To Datasheets Release / / Description / Updated Mechanical Outline / Updated EAC / 新增 15 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUP-240S210SV 价格&库存
很抱歉,暂时无法提供与“EUP-240S210SV”相匹配的价格&库存,您可以联系我们找货
