EUR-240S420DT
EUR-240S420DT
    INVENTRONICS(英飞特)
    240W, 120-277Vac, 4.2A. Round LED driver module
EUR-240S420DT 数据手册
EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Features  Inventronics patented metal case (Patent NO.: 201530552645.1)  High Efficiency (Up to 93%)  Full Power at Wide Output Current Range (Constant Power)   Adjustable Output Current (AOC) with Potentiometer (ST models) Adjustable Output Current (AOC) with Programmability (DT models) 0-10V/PWM Dimmable (Only DT models)  Input Surge Protection: 4kV line-line, 4kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP65) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The EUR-240SxxxDT(ST) series is a 240W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is designed in round shape and specially created for bay lighting. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range (2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 2800-4200mA 2800-4200mA 4000mA 127~300 Vdc 90~305 Vac/ 445-6700mA 4450-6700mA 5000mA 127~300 Vdc 90~305 Vac/ 4450-6700mA 4450-6700mA 5000mA 127~300 Vdc 280-4200mA 2800-4200mA 4000mA Output Voltage Range Power Factor Max. Typical Model Number Output Efficiency (4) 120Vac 220Vac Power (3) 29 ~ 86Vdc 240W 93.0% 0.99 0.96 EUR-240S420DT 29 ~ 86Vdc 240W 93.0% 0.99 0.96 EUR-240S420ST 18 ~ 54Vdc 240W 92.5% 0.99 0.96 EUR-240S670DT 18 ~ 54Vdc 240W 92.5% 0.99 0.96 EUR-240S670ST Notes: (1) Output current range with constant power at 240W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS). (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D I-V Operation Area EUR-240S420DT EUR-240S420ST 96 96 (1960,86) (2800,86) 80 (10%Ioset,240/Ioset) 10 64 0% Lo % 70 ad (4200,57) Lo 48 ad Output Voltage(V) (2800,86) 80 (Ioset,240/Ioset) (4200,40) 32 (4200,29) (Ioset,29) (420,29) Output Voltage(V) (280,86) 16 100% 64 (4200,57) 48 70% 32 Load (4200,40) (4200,29) (2800,29) (Ioset,29) 16 Programmed Operating Area Good Performance Area Allowed Operating Area Good Performance Area 0 Allowed Operating Area 0 0 800 1600 2400 3200 4000 4800 2300 2700 3100 3500 3900 Output Current (mA) Output Current (mA) Note: 2800mA≤Ioset≤4200mA Note: 2800mA≤Ioset≤4200mA EUR-240S670DT 4300 4700 EUR-240S670ST 60 60 (445,54) (3115,54) (4450,54) 50 (4450,54) 50 10 (10%Ioset,240/Ioset) 40 0% Lo ad (6700,36) Lo ad 30 (6700,25) 20 (670,18) (6700,18) (Ioset,18) Output Voltage(V) (Ioset,240/Ioset) % 70 Output Voltage(V) Load (2800,60) 10 100% 40 (6700,36) 30 20 Load (4450,38) 70 % Load (6700,25) (4450,18) (6700,18) 10 Good Performance Area Allowed Operating Area Programmed Operating Area Good Performance Area 0 Allowed Operating Area 0 0 1250 2500 3750 5000 6250 7500 3800 4400 5000 5600 6200 Output Current (mA) Output Current (mA) Note: 4450mA≤Ioset≤6700mA Note: 4450mA≤Ioset≤6700mA 6800 7400 Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 3.10 A Measured at full load and 100 Vac input. - - 1.40 A Measured at full load and 220 Vac input. - - 2.70 A s 127~300 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) 2 At 220Vac input, 25C cold start, duration=2.36 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 280 mA 2800 mA 445 mA 4450 mA - 4200 mA 4200 mA 6700 mA 6700 mA 2800 mA 2800 mA 4450 mA 4450 mA - 4200 mA 4200 mA 6700 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUR-240S420DT/ST EUR-240S670DT/ST - - 95 V 65 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA PF Notes At 100-277Vac, 50-60Hz, 70%-100% Load (168-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUR-240S420DT EUR-240S420ST EUR-240S670DT EUR-240S670ST Output Current Setting Range with Constant Power EUR-240S420DT EUR-240S420ST EUR-240S670DT EUR-240S670ST Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition. 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Turn-on Delay Time Temperature Coefficient of Ioset At full load condition Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D General Specifications Parameter Min. Typ. Max. 88.5% 87.0% 90.5% 89.0% - 88.0% 86.5% 90.0% 88.5% - 91.0% 89.5% 93.0% 91.5% - 90.5% 89.0% 92.5% 91.0% - 91.5% 89.5% 93.5% 91.5% - 91.0% 89.0% 93.0% 91.0% - MTBF - 438,000 Hours - Lifetime - 65,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +85°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUR-240S420DT/ST Io=2800 mA Io=4200 mA EUR-240S670DT/ST Io=4450 mA Io=6700 mA Efficiency at 220 Vac input: EUR-240S420DT/ST Io=2800 mA Io=4200 mA EUR-240S670DT/ST Io=4450 mA Io=6700 mA Efficiency at 277 Vac input: EUR-240S420DT/ST Io=2800 mA Io=4200 mA EUR-240S670DT/ST Io=4450 mA Io=6700 mA Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Dimensions ∅7.48 x 3.13 ∅190 x 79.6 Inches (∅ × H) Millimeters (∅ × H) Net Weight - 2280 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin EUR-240S420DT Dimming EUR-240S670DT Output EUR-240S420DT Range EUR-240S670DT Min. Typ. Max. Notes -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset 280 mA 445 mA - Ioset Vdim(+) = 0 V 2800 mA ≤ Ioset ≤ 4200 mA 4450 mA ≤ Ioset ≤ 6700 mA 280 mA ≤ Ioset < 2800 mA 445 mA ≤ Ioset < 4450 mA 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Dimming Specifications (Continued) Parameter Min. Typ. Max. Notes Recommended Dimming Input Range 0V - 10 V PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. PWM_in Duty Cycle Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 4kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Derating Lifetime vs. Case Temperature Inrush Current Waveform 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Efficiency vs. Load EUR-240S420DT/ST(Io=2800mA) EUR-240S420DT/ST(Io=4200mA) EUR-240S670DT/ST(Io=4450mA) EUR-240S670DT/ST(Io=6700mA) Power Factor 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L Vac N V-(BLU) Inventronics LED Driver Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) 0 (1)-10V Dimmer Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST)  240W AOC Driver for High Bay Rev. D PWM Dimming V+(RED) L Vac N V-(BLU) Inventronics LED Driver Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) PWM Signal Implementation 2: Positive logic V+(RED) L Vac N V-(BLU) Inventronics LED Driver Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) PWM Signal Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Programming Connection Diagram (Only DT models) Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 Multi-Programmer datasheet for details. Installations Part Number Suffix -0000 -0001 Product Type Center Wire Feed Outside Wire Feed Product Appearance 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Installations (Continued) Installation Type A Caution: 1. Complete visual inspection prior to assembly to insure driver is received in proper condition. 2. Thread length for mounting accessory (hook, ring, etc.) should be 16-22mm. After mounting accessory OUTLINE DRAWING (hook, ring, etc.) is installed anMECHANICAL M4 set screw should be secured in the open location on the driver collar. A 3. Maximum weight of combined luminaire/driver assembly should not exceed 16.5Kg. B Mechanical Outline EUR-240SxxxDT-0000 B Hositing thread: DN15 INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL SJTW 2*18AWG Tc 7.3) V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) GRAY PURPLE BLACK/WHITE C C Dimming Wire(UL21996 3*22AWG 5.0) D D M4 PROJ: ERENCE AWING NO. Unspecified tolerance:±1 E E DRAWN MATERIAL: HECKED 2 1 更改调光线为21996 jay 2017.3.17 FINISH: 增加输出孔标注 UNLESS OTHERWISE SPECIFIED TOLERANCES AS FOLLOWS -SURF. ROUGHNESS TO BE ISO 2768-1 AND ISO 2768-2 F MARK ECN NO. DATE -DIMENSIONS ARE IN MM -DENOTES CHANGE DO NOT SCALE DRAWING -WORKMANSHIP SHALL BE THE BEST COMMERCIAL QUALITY 3.2 DESCRIPTION: EUR-240SxxxDT-00000A F 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com 1 2 3 4 6 5 7 8 DEUR240S00015 A A MECHANICAL OUTLINE DRAWING EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D EUR-240SxxxST-0000 B Hositing thread: DN15 B AC INPUT (UL SJTW 3*18AWG) Tc DC OUTPUT (UL SJTW 2*18AWG) RED(V+) BLUE(V-) BLACK (ACL) WHITE (ACN) C C GREEN (GND) POTENTIOMETER D D 1 2 M4 3 4 6 5 7 8 DEUR240S00014 PROJ: A Unspecified tolerance:±1 A MECHANICAL OUTLINE DRAWING EFERENCE RAWING NO. E E DRAWN CHECKED MATERIAL: EUR-240SxxxDT-0001 B B Hositing thread: M12X1.75 F FINISH: OUTPUT (UL SJTW 2*18AWG 7.3) 增加输出孔标注 INPUT (UL SJTW 3*18AWG 7.8) UNLESS OTHERWISE SPECIFIED TOLERANCES AS FOLLOWS -SURF. ROUGHNESS TO BE ISO 2768-1 AND ISO 2768-2 MARK jay SEMBLE NO. DO NOT SCALE DRAWING -WORKMANSHIP SHALL BE THE BEST COMMERCIAL QUALITY PROJ: 2016.02.23 Tc EUR-240SxxxST-00000A DESCRIPTION: 3.2 -DIMENSIONS ARE IN MM -DENOTES CHANGE DATE ECN NO. WEIGHT SCALE VERSION P/N: B 3 AC/L (BLACK) 4 DEUR240S00015 SHEET MFG 2 1 6 5 AC/N (WHITE) F 7 V+ (RED) V- (BLUE) 8 GND (GREEN) C C GRAY PURPLE BLACK/WHITE Dimming Wire(UL21996 3*22AWG 5.0 ) D D M4 PROJ: Unspecified tolerance:±1 ERENCE WING NO. E E RAWN MATERIAL: 2 HECKED 1 更改调光线为21996 jay 2017.3.17 FINISH: 增加输出孔标注 UNLESS OTHERWISE SPECIFIED TOLERANCES AS FOLLOWS -SURF. ROUGHNESS TO BE ISO 2768-1 AND ISO 2768-2 F MARK ECN NO. jay EMBLE NO. 2016.02.23 3.2 -DIMENSIONS ARE IN MM -DENOTES CHANGE DATE DO NOT SCALE DRAWING -WORKMANSHIP SHALL BE THE BEST COMMERCIAL QUALITY PROJ: DESCRIPTION: EUR-240SxxxDT-00010A F WEIGHT SCALE VERSION C P/N: 12 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D EUR-240SxxxST-0001 B B Hositing thread: M12X1.75 Tc DC OUTPUT (UL SJTW 2*18AWG) AC INPUT (UL SJTW 3*18AWG) BLACK (ACL) RED(V+) BLUE(V-) WHITE (ACN) GREEN (GND) C C POTENTIOMETER D D M4 PROJ: Unspecified tolerance:±1 FERENCE AWING NO. E E DRAWN MATERIAL: Optional Metal Parts HKK-D1500 BLT-M1200 M12*1.75 DN15 PROJ: PROJ: Unspecified tolerance:±1 Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. REFERENCE DRAWING NO. DRAWN 13 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUR-240SxxxDT(ST) 240W AOC Driver for High Bay Rev. D Revision History Description of Change Change Date Rev. 2016-07-08 A 2016-10-25 B 2017-07-27 2018-03-01 Item From To Datasheets Release / / Features / Updated Mechanical Outline / Updated Input Specifications PF/THD(Notes) Updated Output Specifications Temperature Coefficient of Ioset Updated Safety & EMC Compliance / Updated Mechanical Outline / Updated Features 5 Years Warranty Added Description / Updated Models Notes(2) Updated General Specifications Case temperature for 5 years Updated warranty Mechanical Outline Optional Metal Parts C D Added 14 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUR-240S420DT 价格&库存
很抱歉,暂时无法提供与“EUR-240S420DT”相匹配的价格&库存,您可以联系我们找货
