EUV-026S048PS
EUV-026S048PS
    INVENTRONICS(英飞特)
    EUV Series 26 W 0.54 A 48 Vdc Out Max Outdoor Constant Voltage LED Driver
EUV-026S048PS 数据手册
EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J Features  High Efficiency (Up to 86%)  Active Power Factor Correction (Typical 0.95)  Constant Output Voltage  Waterproof (IP66) and Damp Location  All-Around Protection: OVP, SCP, OCP  Class 2 and SELV Description The EUV-026SxxxPS Series operates from a 90 ~ 305 Vac input range. They are designed to be highly efficient and highly reliable. Features include over voltage protection, short circuit protection and over current protection. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Power Factor Efficiency 120Vac 220Vac (2) 24 Vdc 90 ~ 305 Vac 0~1080mA 26 W 84% 0.96 0.95 EUV-026S024PS 36 Vdc 90 ~ 305 Vac 0~720 mA 26 W 85% 0.96 0.95 EUV-026S036PS 48 Vdc 90 ~ 305 Vac 0~540 mA 26 W 86% 0.96 0.95 EUV-026S048PS Model Number (3) (3) (4) Notes: (1) UL, FCC certified input voltage range: 100~277Vac, other certified input voltage range except UL & FCC: 100~240Vac. (2) Measured at 100% load and 220 Vac input. (3) Class 2 output (USR & CNR). (4) Class 2 output (USR), Non-Class 2 output (CNR). Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 V - 305 V Input Frequency 47 Hz - 63 Hz - - 0.75 mA At 277Vac 60Hz input - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 0.4 A - - 0.2 A - - 40 A Leakage Current Input AC Current Inrush Current 2 Inrush Current(I t) Power Factor THD 2 - - 0.043 A s 0.90 - - - - 20% Measured at 100% load and 100 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input 25℃ Cold Start. Duration=100 μs, 10%Ipk-10%Ipk. At 100Vac-277Vac, 50-60Hz,75%load100%load (19.5~26W) 1/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J Output Specifications Parameter Min. Output Voltage Tolerance Typ. -5%Vo Max. 5%Vo Output Voltage Ripple Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. - - 3V 4V 4V - - 28 V 40 V 52 V - - 10%Vo Line Regulation - - ±2% Load Regulation - - ±3% - 0.40 s 0.75 s - 0.30 s 0.50 s - - 0.2%/C Vo = 24 V Vo = 36 V Vo = 48 V No Load Output Voltage Vo = 24 V Vo = 36 V Vo = 48 V Output Voltage Overshoot / Undershoot Turn-on Delay Time Temperature coefficient Notes At 100% load condition. Measured at 100% load. Measured at 120Vac input, 75%load-100% load Measured at 220Vac input, 75%load-100% load Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 82% 83% 84% 83% 84% 85% - Measured at 100% load and steady-state temperature in 25℃ ambient. 83% 84% 85% 84% 85% 86% - Measured at 100% load and steady-state temperature in 25℃ ambient. - - 5W 200,000 hours - - Measured at 120Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) - 91,100 Hours - Measured at 120Vac input, 80%Load, Case temperature=60℃ @ Tc point, See life time vs. Tc curve for the details. Operating Case Temperature for Safety Tc_s -40 ℃ - +90C Operating Case Temperature for Warranty Tc_w -40 ℃ - +70 ℃ Humidity: 10% RH to 100% RH. Storage Temperature -40 ℃ - +85 ℃ Humidity: 5% RH to 100% RH Efficiency at 120 Vac input: Vo = 24 V Vo = 36 V Vo = 48 V Efficiency at 220 Vac input: Vo = 24 V Vo = 36 V Vo = 48 V No Load Power Dissipation MTBF Lifetime Notes 2/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J General Specifications (Continued) Parameter Min. Typ. Max. Notes Dimensions 3.07 × 3.15 × 1.06 78 × 80 × 27 Inches (L × W × H) Millimeters (L × W × H) Net Weight - 220 g - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015/KN 15 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 2 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J Lifetime vs. Case Temperature Efficiency vs. Load EUV-026S024PS EUV-026S036PS EUV-026S048PS 4/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J Power Factor Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection 110% 120% 130% Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. Over Current Protection 1.1Io 1.4Io 1.7Io Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. 5/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J Mechanical Outline AC INPUT (UL1015 18AWG) WHITE (ACN) BLACK(ACL) Tc RED(V+) BLACK(V-) DCOUTPUT (UL1007 18AWG) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 6/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-026SxxxPS 26W Constant Voltage IP66 Driver  Rev. J Revision History Description of Change Change Date Rev. 2012-04-24 A Datasheet Release / / 2012-05-25 B EN 61000-4-5--- line to line 2 kV, line to earth 4 kV / Corrected 2012-06-06 C Lifetime vs. Tc Curve / Added Notes of lifetime / Updated 2012-07-17 D Max Case Temperature / Updated 2012-07-30 E Min Operating Temperature -20℃ -40℃ Derating Curve / Updated Inrush Current 60A 40A Inrush Current(I2t) / Added Temperature Coefficient / Added Lifetime Min 50,000hrs Typical 91,100hrs Lifetime Curve / Updated Energy star / Deleted Turn-on Delay Time at 120Vac Max.=1.0 s Max.=0.75 s Operating Case Temperature for Warranty Tc_w / Added Net Weight 200 g 220 g Environmental Specifications / Deleted KS Certificate Regulation / Added Note of EMI Standard / Added Derating Curve / Deleted KCC Logo / Added Input Specifications(PF/THD) 50-60Hz Added Safety &EMC Compliance UL/CUL Updated Safety &EMC Compliance KS 2012-08-20 Item F 2012-11-26 G 2013-07-01 H 2016-08-08 2019-08-14 I J From To Updated (1) (1) Safety &EMC Compliance EN 55015 EN 55015/KN 15 Safety &EMC Compliance FCC Updated Safety &EMC Compliance EN 61000-4-4 Updated Safety &EMC Compliance EN 61000-4-5 Updated RoHS Compliance / Updated 7/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-026S048PS 价格&库存
很抱歉,暂时无法提供与“EUV-026S048PS”相匹配的价格&库存,您可以联系我们找货
