EUV-600S054ST
EUV-600S054ST
    INVENTRONICS(英飞特)
EUV-600S054ST 数据手册
EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B Features  Ultra High Efficiency (Up to 93%)  Constant Voltage Output  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OCP, OVP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The EUV-600SxxxST series is a 600W, constant-voltage IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including architectural, decorative and signage. The high efficiency of the driver and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Input Voltage Range(1) Output Voltage 90~305 Vac 127~300 Vdc 90~305 Vac 127~300 Vdc 48 Vdc 54 Vdc Output Current Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 0 ~ 12.5 A 600 W 92.5% 0.95 0.90 EUV-600S048ST 0 ~ 11.2 A 600 W 93.0% 0.95 0.90 EUV-600S054ST Power Factor Model Number (3) Notes: (1) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (2) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (3) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively - - 6.15 A Measured at 100% load and 120 Vac input. - - 3.25 A Measured at 100% load and 220 Vac input. - - 3.82 A s Leakage Current 127~300 Vdc Input AC Current 2 Inrush Current(I t) 2 At 220Vac input, 25C cold start, duration=6.68ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% Min. Typ. Max. -2.5%VO - 2.5%VO PF Notes At 100-277Vac, 50-60Hz, 60%-100%load (360 - 600W) At 220-240Vac, 50-60Hz, 75%-100%load (450 - 600W) Output Specifications Parameter Output Voltage Tolerance Output Voltage Ripple (pk-pk) - - 2%VO Output Voltage Overshoot / Undershoot - - 5%Vo Line Regulation - - ±0.5% Load Regulation - - ±1.0% - - 0.5 s - - 0.5 s Output Deviation - - 5%VO Settling Time - - 10 ms - 0.03%/C - Turn-on Delay Time Load Dynamic Response Temperature Coefficient Notes At 100% load condition At 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 μF ceramic capacitor and a 10 μF electrolytic capacitor. Measured at 100% load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load R/S: 1 A/μs Load: 25% ~ 100% load. Case temperature = 0C ~ Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Efficiency at 120Vac input: EUV-600S048ST EUV-600S054ST 88.5% 89.0% 90.5% 91.0% - Efficiency at 220Vac input: EUV-600S048ST EUV-600S054ST 90.5% 91.0% 92.5% 93.0% - Efficiency at 277Vac input: EUV-600S048ST EUV-600S054ST 91.0% 91.5% 93.0% 93.5% - - 201,000 Hours - MTBF Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B General Specifications (Continued) Parameter Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Min. Typ. Max. Notes - 106,000 Hours - Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details -40°C - +90C -40°C - +75C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40°C - +85°C Humidity: 5%RH to 100%RH Dimensions With mounting ear 10.83 × 5.67 × 1.91 275 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 Inches (L × W × H) Millimeters (L × W × H) Net Weight - 3320 g - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, CAN/CSA-C22.2 No. 250.13 CE EN 61347-1,EN 61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore lineto-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B Inrush Current Waveform Efficiency vs. Load EUV-600S048ST EUV-600S054ST Power Factor 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B Total Harmonic Distortion Protection Functions Parameter Min. Over Current Protection 105%IO Over Voltage Protection Typ. Max. 110%IO Notes 120%IO Constant current limiting, recovers automatically after fault condition is removed. Limits output voltage at no load and in case the normal voltage limit fails. Auto Recovery. Constant current limiting, recovers automatically after fault condition Short Circuit Protection is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Mechanical Outline INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*14AWG 7.8) 8.8) V+(RED) V-(BLUE) Tc AC/L(BLACK) AC/N(WHITE) GND(GREEN) PROJ: Unspecified tolerance:±1 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-600SxxxST 600W Constant Voltage IP67 Driver  Rev. B Revision History Description of Change Change Date Rev. 2019-11-06 A 2019-12-17 B Item From To Datasheet Release / / Models Power Factor Updated Safety &EMC Compliance EN 61000-4-5 Updated 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-600S054ST
物料型号:EUV-600SxxxST系列
器件简介: - 600W恒压IP67 LED驱动器,适用于90-305Vac输入,具有出色的功率因数。 - 适用于建筑、装饰和标识等多种照明应用。 - 高效率和紧凑的金属外壳设计,运行更凉爽,提高可靠性并延长产品寿命。
引脚分配: - 输入:UL SJTW 318AWG 7.8 - 输出:UL SJTW 214AWG 8.8 - 正极(V+):红色 - 负极(V-):蓝色
参数特性: - 效率高达93%,具有输入浪涌保护、全方位保护(过载、过压、短路、过温)。 - IP67防护等级,适用于干燥/潮湿/湿润环境。 - SELV输出,适用于I类II区危险(分类)场所。
功能详解: - 提供了输入电压范围、输出电压范围、输出电流范围、最大输出功率、典型效率和功率因数的详细表格。 - 包括输入规格、输出规格和一般规格的详细参数。
应用信息: - 适用于多种照明应用,包括建筑、装饰和标识。
封装信息: - 尺寸:9.84x5.67x1.91英寸(含安装耳10.83x5.67x1.91英寸)。 - 重量:3320克。
安全与EMC合规性: - 符合UL、CE、FCC等安全标准。 - 包括EMI和EMS标准的详细测试和要求。
修订历史: - 2019年11月6日发布数据手册。 - 2019年12月17日更新了型号和功率因数。
RoHS合规性: - 产品符合RoHS指令,消除了电子产品中的铅和其他有害物质。
EUV-600S054ST 价格&库存
很抱歉,暂时无法提供与“EUV-600S054ST”相匹配的价格&库存,您可以联系我们找货
EUV-600S054ST
    EUV-600S054ST
      EUV-600S054ST
