EBV-060S048SVF
EBV-060S048SVF
    INVENTRONICS(英飞特)
EBV-060S048SVF 数据手册
EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Features  High Efficiency (up to 91.5%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OCP, OVP, OTP, SCP  Waterproof (IP67)  SELV Output  5 Years Warranty Description The EBV-060SxxxSVF series is a 60W, constant-voltage IP67 LED driver that operates from 176-305 Vac input with excellent power factor. It is created for many lighting applications including architectural, decorative and signage, etc. The high efficiency of the driver and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Power Factor Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power(2) Typical Efficiency (3) 220Vac 24 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 2.5 A 60 W 88.5% 0.96 EBV-060S024SVF 36 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 1.7 A 60 W 89.5% 0.96 EBV-060S036SVF 48 V 176 ~ 305 Vac 190 ~ 250 Vdc 0 ~ 1.25 A 60 W 91.5% 0.96 EBV-060S048SVF Model Number Notes: (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240 Vac. (2) Operating input voltage range: 90-305Vac, and 90-176Vac is for safety operation (see below “Derating” curve for details) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.34 A 2 - - 0.03 A s 0.9 - - - - 10% Input Voltage Inrush Current(I t) PF THD 2 Notes 190 ~ 250 Vdc IEC60598-1; 240Vac/ 60Hz Measured at 100% load and 220Vac input. At 220Vac input, 25C cold start, duration=1.6 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 220-240Vac, 50-60Hz, 75%-100% load(45~60W) 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Output Specifications Parameter Output Voltage Tolerance Total Output Voltage Ripple (pk-avg) EBV-060S024SVF EBV-060S036SVF EBV-060S048SVF Startup Overshoot / Undershoot Min. Typ. Max. -5%Vo - 5%Vo Notes At 100% load condition At 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1μF ceramic capacitor and a 47μF electrolytic capacitor. - - 2.0 V 2.5 V 2.5 V - - 5%Vo At 100% load condition Line Regulation - - ±1% Measured at 100% load Load Regulation - - ±3% Turn-on Delay Time - - 0.5 s Output Deviation - - 8%VO Settling Time - - 10 ms Temperature Coefficient of Vo - 0.03%/C - Load Dynamic Response Measured at 220Vac input, 100% load R/S: 1 A/μs Load: 25% ~ 100% load Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 86.5% 87.5% 89.5% 88.5% 89.5% 91.5% - MTBF - 1171,000 Hours - Lifetime - 99,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 220Vac input: EBV-060S024SVF EBV-060S036SVF EBV-060S048SVF Notes Measured at 100% load and steady-state temperature in 25C ambient; Measured at 220Vac input, 80%load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 6.46 x 1.57 x 0.98 164 x 40.0 x 25.0 - 7.28 x 1.57 x 0.98 185 x 40.0 x 25.0 390 g - Note: All specifications are typical at 25C unless otherwise stated. 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Inrush Current Waveform Efficiency vs. Load EBV-060S024SVF EBV-060S036SVF EBV-060S048SVF 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Mechanical Outline INPUT (H05RN-F 3*1mm 2 OUTPUT (H05RN-F 2*1mm 2 7.2 ) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) 6.8) V+ (BROWN) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-060SxxxSVF 60W Constant Voltage IP67 Driver Rev. B Revision History Description of Change Change Date Rev. 2019-08-09 A Datasheet Release / / 2019-08-14 B MTBF 871,000Hours 1171,000Hours Item From To 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EBV-060S048SVF 价格&库存
很抱歉,暂时无法提供与“EBV-060S048SVF”相匹配的价格&库存,您可以联系我们找货
EBV-060S048SVF
