EBV-400S024SV
EBV-400S024SV
    INVENTRONICS(英飞特)
EBV-400S024SV 数据手册
EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Features  High Efficiency (up to 93%)  Constant Voltage Output  Input Surge Protection: DM 4kV , CM 6kV  All-Around Protection: OCP, OVP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The EBV-400SxxxSV series is a 400W, constant-voltage IP67 LED driver that operates from 176-305 Vac input with excellent power factor. It is created for many lighting applications including architectural, decorative and signage, etc. The high efficiency of the driver and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Input Voltage Range(1) Output Voltage 12 V 24 V 36 V 48 V 176 ~ 305 Vac 190 ~ 250 Vdc 176 ~ 305 Vac 190 ~ 250 Vdc 176 ~ 305 Vac 190 ~ 250 Vdc 176 ~ 305 Vac 190 ~ 250 Vdc Output Current Range Max. Output Power(2) Typical Efficiency (3) Power Factor 0 ~ 28.4 A 340 W 91.0% 0.96 EBV-400S012SV 0 ~ 16.7 A 400 W 93.0% 0.96 EBV-400S024SV 0 ~ 11.2 A 400 W 93.0% 0.96 EBV-400S036SV 0 ~ 8.4 A 400 W 92.5% 0.96 EBV-400S048SV Model Number(4)(5) 220Vac Notes: (1) CCC certified input voltage range: 220/230/240 Vac; other certified input voltage range except CCC: 200-240 Vac or 190-250Vdc (except BIS). (2) Operating input voltage range: 90-305Vac, and 90-176Vac is for safety operation (see below “Derating” curve for details) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) For BIS models add suffix -3000. Input Specifications Parameter Min. Typ. Max. 176 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 2.2 A 2 - - 3.776 A s Input Voltage Inrush Current(I t) Notes 190-250 Vdc IEC60598-1; 240Vac/60Hz Measured at 100% load and 220Vac input. 2 At 220Vac input, 25C cold start, duration=1.38 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% load Min. Typ. Max. Notes -2.5%Vo - 2.5%Vo PF Notes At 220-240Vac, 50-60Hz, 60%-100% load Output Specifications Parameter Output Voltage Tolerance At 100% load condition Total Output Voltage Ripple (pk-pk) - - 2%Vo Measured at 220Vac input, 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 μF ceramic capacitor and a 10 μF electrolytic capacitor. Startup Overshoot / Undershoot - - 5%Vo At 100% load condition Line Regulation - - ±0.5% Measured at 100% load Load Regulation - - ±1% Turn-on Delay Time - - 0.5 s Output Deviation - - 5%VO Settling Time - - 10 ms Temperature Coefficient of Vo - 0.03%/C - Load Dynamic Response Measured at 220Vac input, 100% load R/S: 1 A/μs Load: 25%~100% load Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Efficiency at 220Vac input: EBV-400S012SV EBV-400S024SV EBV-400S036SV EBV-400S048SV 89.0% 91.0% 91.0% 90.5% 91.0% 93.0% 93.0% 92.5% - MTBF - 217,000 Hours - Lifetime - 97,000 Hours - -40°C - +90°C -40°C - +75C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40°C - +85°C Humidity: 5%RH to 100%RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters ((L × W × H) Typ. Max. With mounting ear 8.94 x 3.15 x 1.65 227 x 80 x 42 7.87 x 3.15 x 1.65 200 x 80 x 42 Net Weight - Notes 1350 g - Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category ENEC & CE CB Standard EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 BIS IS 15885(PART2/SEC13) KC K 61347-1, K 61347-2-13 EMI Standards EN 55015/GB 17743/KN 15(1) Notes Conducted emission Test & Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Derating Lifetime vs. Case Temperature Inrush Current Waveform 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Efficiency vs. Load EBV-400S012SV EBV-400S024SV EBV-400S036SV EBV-400S048SV Power Factor 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Mechanical Outline EBV-400S012/024SV IN P U T (V D E H 0 5 R N -F 3C *1.0m m 2 O U T P U T (V D E H 0 7R N -F 2C *1.5m m 7 .2) A C /L (B ROW N) A C /N (B LU E ) G N D (Y E LL O W /GR EE N ) Tc 2 9 .4 ) V + (B R OW N) V - (B LU E ) V + (B R OW N) V - (B LU E ) P RO J: U nsp ecifie d tole rance:±1 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C 2 Note: The 2 DC output cables are connected in parallel internally because one 1.5mm wire can only carry 14.5A. Please connect the 2 brown wires together and 2 blue wires together in application, or ensure each cable carries same current. EBV-400S036/048SV IN P U T (V D E H 0 5 R N -F 3 C *1 .0 m m 2 O U T P U T (V D E H 0 7 R N -F 2 C *1 .5 m m 7 .2 ) A C / L (B RO W N) A C/ N (B L U E ) G ND (Y E L L O W /G R E E N) 2 9 .4 ) Tc V + (B RO W N ) V - (B L U E ) P R O J: U n s p e c ifie d tolerance:±1 EBV-400S024SV-3000 IN P U T (B IS 3*1.0m m 2 AC/L (R ED) AC/N (BLACK) GND (YELLOW /G REEN) 7.25) O U TPU T (BIS 2*1.5m m 2 Tc 7.5) V+ (R ED) V- (BLACK) V+ (RED) V- (BLACK) PROJ: Unspecified tolerance:±1 RoHS & Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Revision History Description of Change Change Date Rev. 2018-07-23 A Item / / Product image / Updated CE certificate / Added CB certificate / Added ENEC certificate / Added BIS certificate / Added Models EBV-400S012SV EBV-400S036SV EBV-400S048SV Added Notes of Models B To Datasheet Release Notes of Models 2018-12-29 From Input AC Current (1) CCC certified input voltage range: 220/230/240 (1) Certified input Voltage Vac; other certified input range: 200-240Vac or 190voltage range except CCC: 250Vdc (except CCC and BIS). 200-240 Vac or 190-250Vdc (except BIS). (5) For BIS models add suffix Added 3000. 2.42 A 2.2 A Hold Up Time / Deleted Efficiency at 220Vac input: EBV-400S012SV EBV-400S036SV EBV-400S048SV Added MTBF 240,000Hours 217,000Hours Lifetime 104,000Hours 97,000Hours Safety & EMC Compliance / Updated Efficiency vs. Load curve EBV-400S012SV EBV-400S036SV EBV-400S048SV Added Power Factor curve / Updated Total Harmonic Distortion curve / Updated Mechanical Outline EBV-400S012SV EBV-400S024SV Updated Mechanical Outline – note of EBV/ 400S012/024SV EBV-400S036SV Mechanical Outline EBV-400S048SV Added Added 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EBV-400SxxxSV 400W Constant Voltage IP67 Driver Rev. C Revision History (Continued) Change Date 2019-12-17 Description of Change Rev. Item C From To KC / KCC Logo / Added Independent Logo / Added Features 4kV line-line, 6kV line-earth DM 4kV , CM 6kV Features Waterproof (IP67) IP67 Features Suitable for Independent Use Deleted Safety &EMC Compliance KC Added Safety &EMC Compliance EN 55015/GB 17743 EN 55015/GB 17743/KN 15 Safety &EMC Compliance EN 61000-4-5 Updated Mechanical Outline EBV-400S024SV-3000 Added RoHS Compliance / Updated (1) 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EBV-400S024SV 价格&库存
很抱歉,暂时无法提供与“EBV-400S024SV”相匹配的价格&库存,您可以联系我们找货
EBV-400S024SV
