EDC-150S105SV-0007
EDC-150S105SV-0007
    INVENTRONICS(英飞特)
EDC-150S105SV-0007 数据手册
X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B Features  Low THD, 10% Max up to 240 Vac  High Efficiency (Up to 92%)  Input Surge Protection: DM 4kV, CM 6kV  High Reliability & Long Lifetime: 97,000 Hrs. at 70°C Case Temperature  Suitable for Class I Luminaires  Input UVP and Input OVP  IP67  5 Year Warranty Description The EDC-150S105SV-000x is a 150W, constant-current, IP67 LED driver that operates from 140-305 Vac input with excellent power factor. Created for many lighting applications including high bay, tunnel, street, etc. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Output Current Range Input Voltage Range(1)(2) Output Voltage Range Max. Output Power Typical Efficiency (3) Power Factor (3) Model Number(4) 700 mA 140 ~ 305 Vac 107 ~ 214 Vdc 150 W 92.0% 0.96 EDC-150S105SV-0007 860 mA 140 ~ 305 Vac 97 ~ 174 Vdc 150 W 92.0% 0.96 EDC-150S105SV-0004 1050 mA 140 ~ 305 Vac 97 ~ 143 Vdc 150 W 91.0% 0.96 EDC-150S105SV Notes: (1) Certified input voltage range: 220-240Vac. (2) Operating input voltage range: 100-305Vac, and 100-140Vac is for safety operation. (3) Measured at 100% load and 220Vac input. (4) For BIS models please click here see the: BIS Models List. Operating Area 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B Input Specifications Parameter Min. Typ. Max. 140 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 1.0 A 2 - - 0.54 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100%load (112.5~150W) Min. Typ. Max. Notes Output Current Tolerance -8%Io - 8%Io At 100% load condition Startup Overshoot Current - - 10%Iomax At 100% load condition No Load Output Voltage EDC-150S105SV-0007 EDC-150S105SV-0004 EDC-150S105SV - - 250 V 250 V 250 V Line Regulation - - ± 5.0% Load Regulation - - ± 5.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Iomax - 0.04%/C - Min. Typ. Max. 90.0% 90.0% 89.0% 92.0% 92.0% 91.0% - MTBF - 616,000 Hours - Lifetime - 97,000 Hours - Input Voltage Inrush Current(I t) PF 2 Notes IEC60598-1; 240Vac/60Hz Measured at 100% load and 220 Vac input. At 220Vac input, 25C cold start, duration=200 us, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 200-277Vac, 50-60Hz, 75%-100%load (112.5~150W) Output Specifications Parameter Measured at 100% load Measured at 220Vac input, 75%-100% Load Case temperature = 0C~Tc max General Specifications Parameter Efficiency at 220 Vac input: EDC-150S105SV-0007 EDC-150S105SV-0004 EDC-150S105SV 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. Operating Case Temperature for Safety Tc_s -40 °C - +90 °C Operating Case Temperature for Warranty Tc_w -40 °C - +75 C Case temperature for 5 years warranty. Humidity: 10%RH to 95%RH Storage Temperature -40 °C - +85 °C Humidity: 5%RH to 95%RH Dimensions Inches (L × W × H) Millimeters (L × W × H) With mounting ear 7.36 × 2.66 × 1.56 187 × 67.5 × 39.7 6.54 × 2.66 × 1.56 166 × 67.5 × 39.7 Net Weight - 905 g Notes - Safety &EMC Compliance Safety Category Standard BIS IS 15885(PART2/SEC13) CCC GB 19510.1, GB 19510.14 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EDC-150S105SV(Io=1050mA) EDC-150S105SV-0004(Io=860mA) 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B EDC-150S105SV-0007(Io=700mA) Power Factor Total Harmonic Distortion 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Turn off the output when the input voltage falls below 100V. And the driver will restart when the input voltage is in normal. Input Over Voltage Protection Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage  320 Vac 340 Vac 360 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 320 Vac 340 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. - - 440 Vac The driver can survive for 48 hours with input over-voltage of 440Vac. Input Over Voltage Protection Diagram Io Recovery Protection Vin 340 Vac 320 Vac 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B Mechanical Outline EDC-150S105SV-000x INPUT(VDE H05RN-F 3*1.0mm2 7.2) OUTPUT(VDE H05RN-F 2*1.0mm 2 6.8) N W E OU RL BB +VV AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) ︵ ︵ Tc ︶ ︶ PROJ: Unspecified tolerance:±1 EDC-150S105SV-300x INPUT(BIS 3*1.0mm2 OUTPUT(BIS 2*1.0mm 2 7.25) AC/L (RED) AC/N (BLACK) GND (YELLOW/GREEN) 6.85) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com X EDC-150S105SV-000x 150W Constant Current IP67 Driver Rev. B Revision History Description of Change Change Date Rev. 2017-03-03 A 2021-01-05 Item B From To Datasheet Release / / Format / Updated Features / Updated Product image / Updated Independent logo / Added Description / Updated Notes of models - (4) For BIS models please click / here see the: BIS Models List. Added Operating Area / Added Note of Output Current Tolerance Without power derating At 100% load condition. and 100% load General Specifications - Humidity / Updated Derating / Deleted Protection Functions - Input Under Voltage Protection / Updated Mechanical Outline - EDC-150S105SV-300x / Added RoHS Compliance / Updated 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
EDC-150S105SV-0007 价格&库存
很抱歉,暂时无法提供与“EDC-150S105SV-0007”相匹配的价格&库存,您可以联系我们找货
EDC-150S105SV-0007
