END-CAP02
END-CAP02
    INVENTRONICS(英飞特)
END-CAP02 数据手册
END-CAP02 Cable Clamp for Independent Application Rev. A Features  Flexible Cable Clamp for Simple and Quick Cable Mounting  Easy to Install with LED Driver  Only Suitable for Inventronics 2nd Gen. EBS Series Drivers Description The END-CAP02 is a cable clamp installed with Inventronics 2nd generation EBS series drivers for independent application. Model Name Description Part Number Cable Clamp Driver Accessory Kit END-CAP02 Driver Part Number Notes Compatible List Part Number EBS-040xxxDT2 EBS-040xxxBT2 END-CAP02 EBS-080xxxDT2 EBS-080xxxBT2 Environmental Specifications Parameter Min. Typ. Max. Operating Temperature -40C - +70C Storage Temperature -40C - +85C Min. Typ. Max. Notes Humidity: 5%RH to 85%RH. No condensation. Humidity: 5%RH to 85%RH. No condensation. General Specifications Parameter Notes Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 3.03 x 1.93 x 1.3 77 x 49 x 33 - 29 g - 1/4 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com END-CAP02 Cable Clamp for Independent Application Rev. A Mechanical Outline PROJ: Unspecified tolerance:±1 2/4 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com END-CAP02 Cable Clamp for Independent Application Rev. A RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 3/4 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com END-CAP02 Cable Clamp for Independent Application Rev. A Revision History Description of Change Change Date Rev. 2020-07-22 A Item From Datasheet Release / 4/4 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 To / All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
END-CAP02 价格&库存
很抱歉,暂时无法提供与“END-CAP02”相匹配的价格&库存,您可以联系我们找货
END-CAP02
