ESD-600S420DT
ESD-600S420DT
    INVENTRONICS(英飞特)
ESD-600S420DT 数据手册
ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Features  Ultra High Efficiency (Up to 95.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 1.5 W  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The ESD-600SxxxDT series is a 600W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including high mast, sports, aquaculture and horticulture, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Default Current Output Range(1) Current 0.136-1.70A 1.36–1.70A 0.168-2.10A 1.68–2.10A 0.224-2.80A 2.24–2.80A 0.336-4.20A 3.36–4.20A 0.448-5.60A 4.48–5.60A 0.592-7.40A 5.92–7.40A 0.784-9.80A 7.84–9.80A 1.0–12.5 A 10–12.5 A Input Voltage Range(2) 249~528Vac 352~500Vdc 249~528Vac 2.1A 352~500Vdc 249~528Vac 2.8 A 352~500Vdc 249~528Vac 4.2 A 352~500Vdc 249~528Vac 5.6 A 352~500Vdc 249~528Vac 7.0 A 352~500Vdc 249~528Vac 9.8 A 352~500Vdc 249~528Vac 12.5 A 352~500Vdc 1.7A Typical Max. Typical Power Factor Output Efficiency Power (3) 277Vac 480Vac Output Voltage Range Model Number 176 ~ 441Vdc 600 W 95.0% 0.96 0.95 ESD-600S170DT(5) 143 ~ 357Vdc 600 W 95.0% 0.96 0.95 ESD-600S210DT(5) 108 ~ 268Vdc 600 W 94.5% 0.96 0.95 ESD-600S280DT(6) 72 ~ 178Vdc 600 W 95.0% 0.96 0.95 ESD-600S420DT 54 ~ 134Vdc 600 W 95.0% 0.96 0.95 ESD-600S560DT 41 ~ 101Vdc 600 W 94.5% 0.96 0.95 ESD-600S740DT(4) 31 ~ 76Vdc 600 W 94.0% 0.96 0.95 ESD-600S980DT(4) 24 ~ 60Vdc 600 W 94.0% 0.96 0.95 ESD-600S12ADT(4) Notes: (1) Output current range with constant power at 600W. (2) Certified voltage range: 277-480Vac or 352-500Vdc. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV output. (5) the models are certificated to CCC, KC, KCC. (6) the model is certificated to KCC. 1 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G I-V Operating Area ESD-600S170DT ESD-600S210DT 430 540 (10%Ioset,600/Ioset) 360 (Ioset,600/Ioset) (1700,211) 180 (1700,176) (Ioset,176 ) (170,176) 90 Good Performance Area Allowed Operating Area Programmed Operating Area 350 1400 220 80 (2100,143) (Ioset,143 ) (210,143) Good Performance Area Allowed Operating Area Programmed Operating Area 500 1700 0 0 700 1050 1750 0 2100 900 1300 2100 Output Current (mA) Output Current (mA) Note: 1360mA≤Ioset≤1700mA Note: 1680mA≤Ioset≤2100mA ESD-600S280DT 2500 ESD-600S420DT 330 210 (2240,268) 10 0% Lo a (1344,268) (10%Ioset,600/Ioset) 220 d ad Lo 165 (2800,129) 110 (Ioset,108) (280,108) 55 (2800,108) Good Performance Area Allowed Operating Area Programmed Operating Area 550 2200 140 %L o ad (4200,143) (Ioset,600/Ioset) ad Lo % 60 (Ioset,600/Ioset) (10%Ioset,600/Ioset) % 60 (2800,214) (3360,178) 10 0 (2016,178) (336,178) 175 Output Voltage(V) 275 (224,268) Output Voltage(V) (2100,285) (2100,171) 150 0 105 (4200,86) 70 (4200,72) (Ioset,72) (420,72) 35 0 Good Performance Area Allowed Operating Area Programmed Operating Area 800 3200 0 0 1100 1650 2750 3300 0 1600 2400 4000 Output Current (mA) Output Current (mA) Note: 2240mA≤Ioset≤2800mA Note: 3360mA≤Ioset≤4200mA ESD-600S560DT 4800 ESD-600S740DT 120 150 (4480,134) 10 0% (2688,134) (10%Ioset,600/Ioset) Lo ad (5600,107) (Ioset,600/Ioset) 50 (Ioset,54) (560,54) 25 Good Performance Area Allowed Operating Area Programmed Operating Area 80 Lo a d (7400,81) (Ioset,600/Ioset) 60 ad (5600,64) (5600,54) (10%Ioset,600/Ioset) Lo % ad Lo 75 (5920,101) 10 0% (3552,101) 60 % 60 100 (592,101) 100 Output Voltage(V) (448,134) 125 Output Voltage(V) d (Ioset,600/Ioset) ad Lo ad Lo 270 (10%Ioset,600/Ioset) 290 % 60 d (1700,353) (1680,357) 10 0% Lo a (1008,357) 360 (168,357) (1360,441) 10 0% Lo a (816,441) Output Voltage(V) (136,441) % 60 Output Voltage(V) 450 40 (7400,48.5) (7400,41) (Ioset,41) (740,41) 20 Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 0 1000 2000 3000 4000 5000 0 6000 1350 2700 4050 5400 Output Current (mA) Output Current (mA) Note: 4480mA≤Ioset≤5600mA Note: 5920mA≤Ioset≤7400mA 2 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 6750 8100 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G ESD-600S980DT ESD-600S12ADT 90 70 (10%Ioset,600/Ioset) 60 60 Lo ad (9800,61) (Ioset,600/Ioset) 30 (Ioset,31) (980,31) 15 Good Performance Area Allowed Operating Area Programmed Operating Area 0 (10%Ioset,600/Ioset) Loa 50 40 (Ioset,600/Ioset) d (12500,48) ad Lo (9800,36.5) (9800,31) (10000,60) 10 0% % 60 ad 45 (6000,60) (1000,60) 60 Lo % Output Voltage(V) (7840,76) 10 0% Output Voltage(V) (4704,76) (784,76) 75 (12500,29) 30 (1250,24) 20 (Ioset,24) (12500,24) Programmed Operating Area Good Performance Area Allowed Operating Area 10 0 1800 3600 5400 7200 9000 10800 0 1250 3750 6250 8750 Output Current (mA) Output Current (mA) Note: 7840mA≤Ioset≤9800mA Note: 10000mA≤Ioset≤12500mA 11250 13750 Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 325 Vdc - 500 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU - - 0.70 mA - - 2.50 A - - 1.45 A - - 20.4 A2s 0.90 - - - - 20% Min. Typ. Max. Output Current Tolerance -5%Ioset - 5%Ioset Output Current Setting(Ioset) Range ESD-600S170DT ESD-600S210DT ESD-600S280DT ESD-600S420DT ESD-600S560DT ESD-600S740DT ESD-600S980DT ESD-600S12ADT 136 mA 168 mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA Leakage Current Input AC Current Inrush Current(I2t) PF THD Notes UL8750; 480Vac/ 60Hz, Grounding effectively IEC60598-1; 480Vac/ 60Hz, Grounding effectively Measured at 100% load and 277 Vac input. Measured at 100% load and 480 Vac input. At 480Vac input, 25℃ cold start, duration=869 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100% Load (360 - 600W) Output Specifications Parameter 3 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes 100% load All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Output Specifications (Continued) Parameter Min. Typ. Max. 1360 mA 1680 mA 2240 mA 3360 mA 4480 mA 5920 mA 7840 mA 10000 mA - 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage ESD-600S170DT ESD-600S210DT ESD-600S280DT ESD-600S420DT ESD-600S560DT ESD-600S740DT ESD-600S980DT ESD-600S12ADT - - 480 V 420 V 300 V 200 V 160 V 120 V 95 V 80 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.75 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Output Current Setting Range with Constant Power ESD-600S170DT ESD-600S210DT ESD-600S280DT ESD-600S420DT ESD-600S560DT ESD-600S740DT ESD-600S980DT ESD-600S12ADT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 4 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes 100% load, 20 MHz BW 100% load Measured at 277-480Vac input, 60%100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G General Specifications Parameter Efficiency at 277 Vac input: ESD-600S170DT Io= 1360 mA Io= 1700 mA ESD-600S210DT Io= 1680 mA Io= 2100 mA ESD-600S280DT Io= 2240 mA Io= 2800 mA ESD-600S420DT Io= 3360 mA Io= 4200 mA ESD-600S560DT Io= 4480 mA Io= 5600 mA ESD-600S740DT Io= 5920 mA Io= 7400 mA ESD-600S980DT Io= 7840 mA Io= 9800 mA ESD-600S12ADT Io=10000 mA Io=12500 mA Efficiency at 347 Vac input: ESD-600S170DT Io= 1360 mA Io= 1700 mA ESD-600S210DT Io= 1680 mA Io= 2100 mA ESD-600S280DT Io= 2240 mA Io= 2800 mA ESD-600S420DT Io= 3360 mA Io= 4200 mA ESD-600S560DT Io= 4480 mA Io= 5600 mA ESD-600S740DT Io= 5920 mA Io= 7400 mA ESD-600S980DT Io= 7840 mA Io= 9800 mA ESD-600S12ADT Io=10000 mA Io=12500 mA Min. Typ. Max. 92.0% 92.0% 94.0% 94.0% - 92.0% 91.5% 94.0% 93.5% - 91.5% 91.0% 93.5% 93.0% - 92.0% 91.5% 94.0% 93.5% - 92.0% 91.5% 94.0% 93.5% - 91.5% 90.5% 93.5% 92.5% - 90.5% 89.5% 92.5% 91.5% - 91.0% 90.0% 93.0% 92.0% - 92.5% 92.5% 94.5% 94.5% - 93.0% 92.0% 95.0% 94.0% - 92.0% 91.5% 94.0% 93.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.0% 94.0% 93.0% - 91.0% 90.5% 93.0% 92.5% - 91.5% 90.5% 93.5% 92.5% - 5 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G General Specifications (Continued) Parameter Min. Typ. Max. 93.0% 93.0% 95.0% 95.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 93.0% 92.5% 95.0% 94.5% - 93.0% 92.5% 95.0% 94.5% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - 92.0% 91.0% 94.0% 93.0% - Standby power - - 1.5 W MTBF - 200,000 Hours - Lifetime - 101,000 Hours - -40°C - +89C -40°C - +75C -40°C - +85°C Efficiency at 480 Vac input: ESD-600S170DT Io= 1360 mA Io= 1700 mA ESD-600S210DT Io= 1680 mA Io= 2100 mA ESD-600S280DT Io= 2240 mA Io= 2800 mA ESD-600S420DT Io= 3360 mA Io= 4200 mA ESD-600S560DT Io= 4480 mA Io= 5600 mA ESD-600S740DT Io= 5920 mA Io= 7400 mA ESD-600S980DT Io= 7840 mA Io= 9800 mA ESD-600S12ADT Io=10000 mA Io=12500 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Case temperature for 5 years warranty Humidity: 10%RH to 95%RH Humidity: 5%RH to 95%RH With mounting ear 10.87 × 5.67 × 1.91 276 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 Inches (L × W × H) Millimeters (L × W × H) Notes - 3330g - Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA Dimming Specifications Parameter 6 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Dimming Specifications (Continued) Parameter Min. Typ. Max. Notes 1360 mA ≤ Ioset ≤ 1700 mA 1680 mA ≤ Ioset ≤ 2100 mA 2240 mA ≤ Ioset ≤ 2800 mA 3360 mA ≤ Ioset ≤ 4200 mA 4480 mA ≤ Ioset ≤ 5600 mA 5920 mA ≤ Ioset ≤ 7400 mA 7840 mA ≤ Ioset ≤ 9800 mA 10000 mA ≤ Ioset ≤ 12500 mA 136 mA ≤ Ioset < 1360 mA 168 mA ≤ Ioset < 1680 mA 224 mA ≤ Ioset < 2240 mA 336 mA ≤ Ioset < 3360 mA 448 mA ≤ Ioset < 4480 mA 592 mA ≤ Ioset < 5920 mA 784 mA ≤ Ioset < 7840 mA 1000 mA ≤ Ioset < 10000 mA ESD-600S170DT ESD-600S210DT ESD-600S280DT ESD-600S420DT ESD-600S560DT ESD-600S740DT ESD-600S980DT ESD-600S12ADT 10%Ioset - Ioset ESD-600S170DT ESD-600S210DT ESD-600S280DT ESD-600S420DT ESD-600S560DT ESD-600S740DT ESD-600S980DT ESD-600S12ADT 136 mA 168 mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL Standard UL 8750,CAN/CSA-C22.2 No. 250.13 ENEC & TUV & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 7 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Safety &EMC Compliance (Continued) EMI Standards EN 55015/GB 17743/KN 15(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8kV air discharge, 4kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6kV, Common Mode 10kV (2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 8 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Inrush Current Waveform Efficiency vs. Load ESD-600S170DT(Io=1360mA) ESD-600S170DT(Io=1700mA) ESD-600S210DT(lo=1680mA) ESD-600S210DT(lo=2100mA) 9 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G ESD-600S280DT(lo=2240mA) ESD-600S280DT(lo=2800mA) ESD-600S420DT(lo=3600mA) ESD-600S420DT(lo=4200mA) ESD-600S560DT(lo=4480mA) ESD-600S560DT(lo=5600mA) 10 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G ESD-600S740DT(lo=5920mA) ESD-600S740DT(lo=7400mA) ESD-600S980DT(lo=7840mA) ESD-600S980DT(lo=9800mA) ESD-600S12ADT(lo=10000mA) ESD-600S12ADT(lo=12500mA) 11 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 12 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+ L V- Vac N Inventronics LED Driver G OTP+ OTPVaux Dim+ Dimmer Dim- Implementation 1: DC Input Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener.  PWM Dimming The recommended implementation of the dimming control is provided below. V+ L V- Vac N Inventronics LED Driver OTP+ OTPVaux Dim+ G PWM Signal Dim- Implementation 2: Positive logic V+ L V- Vac N Inventronics LED Driver G OTP+ OTPVaux Dim+ PWM Signal Dim- Implementation 3: Negative logic 13 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDT 600W Programmable IP67 Driver Rev.G Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-600S420DT 价格&库存
很抱歉,暂时无法提供与“ESD-600S420DT”相匹配的价格&库存,您可以联系我们找货
