EUD-075S280DT
EUD-075S280DT
    INVENTRONICS(英飞特)
    EUD-075S280DT
EUD-075S280DT 数据手册
EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Features  High Efficiency (Up to 91.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  Class 2 & SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  Class P, UL Listed Versions Available (See Note 6)  7 Years Warranty Description The EUD-075SxxxDT series is a 75W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for low bay, tunnel and street lights, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 45-700mA 450-700mA 530 mA 70-1050mA 700-1050mA 700 mA 119-1750mA 1190-1750mA 1400 mA 140-1800mA 1400-1800mA 1400 mA 192-2800mA 1920-2800mA 2100 mA Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number 54~167Vdc 75 W 91.0% 0.99 0.96 EUD-075S070DT 36~107Vdc 75 W 91.0% 0.99 0.96 EUD-075S105DT (4) 22 ~ 63Vdc 75 W 90.5% 0.99 0.96 EUD-075S175DT (4) 22 ~ 54Vdc 75 W 90.5% 0.99 0.96 EUD-075S180DT (5) 14 ~ 39Vdc 75 W 89.5% 0.99 0.96 EUD-075S280DT (5) Notes: (1) Output current range with constant power at 75W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV Output. (6) Standard part UL Type TL. For UL Listed Class P models add suffix -00C0. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C I-V Operating Area EUD-075S070DT EUD-075S105DT EUD-075S175DT EUD-075S180DT % 70 10 0% Lo ad ad Lo EUD-075S280DT 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 1.02 A Measured at full load and 100 Vac input. - - 0.48 A Measured at full load and 220 Vac input. - - 1.03 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (56.25-75W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 45 mA 70 mA 119 mA 140 mA 192 mA - 700 mA 1050 mA 1750 mA 1800 mA 2800 mA 450 mA 700 mA 1190 mA 1400 mA 1920 mA - 700 mA 1050 mA 1750 mA 1800 mA 2800 mA - 5%Iomax 10%Iomax - 1%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-075S070DT EUD-075S105DT EUD-075S175DT EUD-075S180DT EUD-075S280DT - - 190 V 120 V 71 V 59 V 45 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% 127~300 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25°C cold start, duration=740 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (52.5-75W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-075S070DT EUD-075S105DT EUD-075S175DT EUD-075S180DT EUD-075S280DT Output Current Setting Range with Constant Power EUD-075S070DT EUD-075S105DT EUD-075S175DT EUD-075S180DT EUD-075S280DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “Dim−“ - - 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. Turn-on Delay Time Temperature Coefficient of Ioset 12V Auxiliary Output Transient Peak Current Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-075S070DT Io= 450 mA Io= 700 mA EUD-075S105DT Io= 700 mA Io=1050 mA EUD-075S175DT Io=1190 mA Io=1750 mA EUD-075S180DT Io=1400 mA Io=1800 mA EUD-075S280DT Io=1920 mA Io=2800 mA Efficiency at 220 Vac input: EUD-075S070DT Io= 450 mA Io= 700 mA EUD-075S105DT Io= 700 mA Io=1050 mA EUD-075S175DT Io=1190 mA Io=1750 mA EUD-075S180DT Io=1400 mA Io=1800 mA EUD-075S280DT Io=1920 mA Io=2800 mA Min. Typ. Max. 86.5% 86.5% 88.5% 88.5% - 86.5% 86.0% 88.5% 88.0% - 86.5% 86.0% 88.5% 88.0% - 86.5% 86.0% 88.5% 88.0% - 86.0% 85.0% 88.0% 87.0% - 89.0% 88.5% 91.0% 90.5% - 89.0% 88.5% 91.0% 90.5% - 88.5% 88.0% 90.5% 90.0% - 88.5% 88.0% 90.5% 90.0% - 87.5% 87.0% 89.5% 89.0% - Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. Max. 89.0% 89.0% 91.0% 91.0% - 89.0% 89.0% 91.0% 91.0% - 89.0% 88.0% 91.0% 90.0% - 89.0% 88.0% 91.0% 90.0% - 88.0% 87.0% 90.0% 89.0% - Standby power - - 0.5 W MTBF - 219,000 Hours - Lifetime - 98,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-075S070DT Io= 450 mA Io= 700 mA EUD-075S105DT Io= 700 mA Io=1050 mA EUD-075S175DT Io=1190 mA Io=1750 mA EUD-075S180DT Io=1400 mA Io=1800 mA EUD-075S280DT Io=1920 mA Io=2800 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 820 g Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.17 × 2.66 × 1.44 182 × 67.5 × 36.5 6.10 × 2.66 × 1.44 155 × 67.5 × 36.5 - Notes - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA EUD-075S070DT EUD-075S105DT EUD-075S175DT EUD-075S180DT EUD-075S280DT 10%Ioset - Ioset EUD-075S070DT EUD-075S105DT EUD-075S175DT EUD-075S180DT EUD-075S280DT 45mA 70mA 119mA 140mA 192mA - Ioset Notes Vdim(+) = 0 V 450mA ≤ Ioset ≤ 700mA 700mA ≤ Ioset ≤ 1050mA 1190mA ≤ Ioset ≤ 1750mA 1400mA ≤ Ioset ≤ 1800mA 1920mA ≤ Ioset ≤ 2800mA 45mA ≤ Ioset < 450mA 70mA ≤ Ioset < 700mA 119mA ≤ Ioset < 1190mA 140mA ≤ Ioset < 1400mA 192mA ≤ Ioset < 1920mA 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 2% 5% 8% 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards EN 55015 (1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Safety & EMC Compliance (Continued) EMS Standards Notes (2) EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Efficiency vs. Load EUD-075S070DT(Io=450mA) EUD-075S070DT(Io=700mA) EUD-075S105DT(Io=700mA) EUD-075S105DT(Io=1050mA) EUD-075S175DT(Io=1190mA) EUD-075S175DT(Io=1750mA) 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C EUD-075S180DT(Io=1400mA) EUD-075S180DT(Io=1800mA) EUD-075S280DT(Io=1920mA) EUD-075S280DT(Io=2800mA) Power Factor 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. R2 - 4.16 kOhm - When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) 0 (1)-10V Dimmer Implementation 1: DC Input 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-075SxxxDT 75W Programmable IP67 Driver Rev. C Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 2: Positive logic V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-075S280DT 价格&库存
很抱歉,暂时无法提供与“EUD-075S280DT”相匹配的价格&库存,您可以联系我们找货
