EUD-240S210BVA
EUD-240S210BVA
    INVENTRONICS(英飞特)
EUD-240S210BVA 数据手册
EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Features  Ultra High Efficiency (Up to 94%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  DALI/Timer Dimmable (3 Timer Modes)  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use  7 Years Warranty Description The EUD-240SxxxBVA series is a 240W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 70-1050mA 700-1050mA 1050 mA 105-1500mA 1050-1500mA 1050 mA 140-2100mA 1400-2100mA 1400 mA 280-4200mA 2800-4200mA 4200 mA 445-6700mA 4450-6700mA 6700 mA Input Voltage Range(2) 90~305 Vac 127~250 Vdc 90~305 Vac 127~250 Vdc 90~305 Vac 127~250 Vdc 90~305 Vac 127~250 Vdc 90~305 Vac 127~250 Vdc Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range Model Number (5) 114~343Vdc 240W 94.0% 0.99 0.96 EUD-240S105BVA 80~229Vdc 240W 93.0% 0.99 0.96 EUD-240S150BVA 57~171Vdc 240W 93.5% 0.99 0.96 EUD-240S210BVA 29 ~ 86Vdc 240W 93.0% 0.99 0.96 EUD-240S420BVA (4) 18 ~ 54Vdc 240W 93.0% 0.99 0.96 EUD-240S670BVA (4) Notes: (1) Output current range with constant power at 240W (2) Certified voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE and KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output (5) All the models are certificated to KS, except EUD-240S105BVA 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D I-V Operating Area EUD-240S105BVA EUD-240S150BVA EUD-240S210BVA EUD-240S420BVA EUD-240S670BVA 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 3.00 A Measured at full load and 100 Vac input. - - 1.30 A Measured at full load and 220 Vac input. - - 2.60 A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 105 mA 140 mA 280 mA 445 mA - 1050 mA 1500 mA 2100 mA 4200 mA 6700 mA 700 mA 1050 mA 1400 mA 2800 mA 4450 mA - 1050 mA 1500 mA 2100 mA 4200 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-240S105BVA EUD-240S150BVA EUD-240S210BVA EUD-240S420BVA EUD-240S670BVA - - 360 V 260 V 190 V 96 V 66 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Input AC Current 2 Inrush Current(I t) PF 2 Notes 127-250 Vdc IEC60598-1; 240Vac/ 60Hz, grounding effectively At 220Vac input, 25℃ cold start, duration=840 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (144-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-240S105BVA EUD-240S150BVA EUD-240S210BVA EUD-240S420BVA EUD-240S670BVA Output Current Setting Range with Constant Power EUD-240S105BVA EUD-240S150BVA EUD-240S210BVA EUD-240S420BVA EUD-240S670BVA Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “OTP−“ - - 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. Turn-on Delay Time Temperature Coefficient of Ioset 12V Auxiliary Output Transient Peak Current Notes Measured at 120Vac input, 60%-100% Load. Measured at 220Vac input, 60%-100% Load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-240S105BVA Io= 700 mA Io=1050 mA EUD-240S150BVA Io=1050 mA Io=1500 mA EUD-240S210BVA Io=1400 mA Io=2100 mA EUD-240S420BVA Io=2800 mA Io=4200 mA EUD-240S670BVA Io=4450 mA Io=6700 mA Efficiency at 220 Vac input: EUD-240S105BVA Io= 700 mA Io=1050 mA EUD-240S150BVA Io=1050 mA Io=1500 mA EUD-240S210BVA Io=1400 mA Io=2100 mA EUD-240S420BVA Io=2800 mA Io=4200 mA EUD-240S670BVA Io=4450 mA Io=6700 mA Min. Typ. Max. 89.0% 88.0% 91.0% 90.0% - 88.0% 87.0% 90.0% 89.0% - 89.0% 87.5% 91.0% 89.5% - 88.5% 87.0% 90.5% 89.0% - 89.0% 87.0% 91.0% 89.0% - 92.0% 90.5% 94.0% 92.5% - 91.0% 89.5% 93.0% 91.5% - 91.5% 90.0% 93.5% 92.0% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.0% 93.0% 91.0% - Notes Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 91.5% 90.0% 93.5% 92.0% - 92.0% 90.5% 94.0% 92.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.0% 93.5% 91.0% - Standby power - - 0.5 W MTBF - 228,000 Hours - Lifetime - 96,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-240S105BVA Io= 700 mA Io=1050 mA EUD-240S150BVA Io=1050 mA Io=1500 mA EUD-240S210BVA Io=1400 mA Io=2100 mA EUD-240S420BVA Io=2800 mA Io=4200 mA EUD-240S670BVA Io=4450 mA Io=6700 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.45 × 2.66 × 1.57 240 × 67.5 × 39.7 8.63 × 2.66 × 1.57 219 × 67.5 × 39.7 - Notes 1300 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Min. Typ. Max. DA, DA High Level 9.5V 16V 22.5V DA, DA Low Level -6.5V 0V 6.5V DA, DA Current 0mA - 2mA Notes 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Dimming Specifications (Continued) Parameter Dimming Output Range Min. Typ. Max. EUD-240S105BVA EUD-240S150BVA EUD-240S210BVA EUD-240S420BVA EUD-240S670BVA 10%Ioset - Ioset EUD-240S105BVA EUD-240S150BVA EUD-240S210BVA EUD-240S420BVA EUD-240S670BVA 70 mA 105 mA 140 mA 280 mA 445 mA - Ioset Notes 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset <1500 mA 1400 mA ≤ Ioset ≤ 2100 mA 2800 mA ≤ Ioset ≤ 4200 mA 4450 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset <1050 mA 140 mA ≤ Ioset <1400 mA 280 mA ≤ Ioset <2800 mA 445 mA ≤ Ioset <4450 mA Note: All specifications are typical at 25 C unless stated otherwise. Standards Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards EN 55015 (1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment DALI Standards DALI (2) Notes IEC62386-101,102 & part of 207 (3) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. (3) Optional Commands Implemented: 242 (query short circuit), 243 (query open circuit) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Derating Lifetime vs. Case Temperature Inrush Current Waveform 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Efficiency vs. Load EUD-240S105BVA(Io=700mA) EUD-240S105BVA(Io=1050mA) EUD-240S150BVA(Io=1050mA) EUD-240S150BVA(Io=1500mA) EUD-240S210BVA(Io=1400mA) EUD-240S210BVA(Io=2100mA) 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D EUD-240S420BVA(Io=2800mA) EUD-240S420BVA(Io=4200mA) EUD-240S670BVA(Io=4450mA) EUD-240S670BVA(Io=6700mA) Power Factor 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset ≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  DALI Dimming The recommended implementation of the dimming control is provided below. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-240SxxxBVA 240W Programmable IP67 Driver with DALI Rev.D Implementation: DALI Dimming   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-240S210BVA 价格&库存
很抱歉,暂时无法提供与“EUD-240S210BVA”相匹配的价格&库存,您可以联系我们找货
