EUD-480S280DV
EUD-480S280DV
    INVENTRONICS(英飞特)
EUD-480S280DV 数据手册
EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Features  Ultra High Efficiency (Up to 95%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 0.5 W  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  7 Years Warranty Description The EUD-480SxxxDV series is a 480W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, aquaculture and sport, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range 0.105-1.40A 1.05–1.40A 0.210-2.80A 2.10–2.80A 0.315-4.20A 3.15–4.20A 0.435-5.60A 4.35–5.60A 0.750-10.0A 7.50–10.0A Input Voltage Range(2) 90~305Vac/ 127~250Vdc 90~305Vac/ 2.8 A 127~250Vdc 90~305Vac/ 4.2 A 127~250Vdc 90~305Vac/ 5.6 A 127~250Vdc 90~305Vac/ 10.0 A 127~250Vdc 1.4A Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (5) 171 ~ 457Vdc 480W 95.0% 0.99 0.96 EUD-480S140DV 86 ~ 228Vdc 480 W 94.0% 0.99 0.96 EUD-480S280DV 57 ~ 152Vdc 480 W 94.5% 0.99 0.96 EUD-480S420DV 43 ~ 110Vdc 480 W 94.0% 0.99 0.96 EUD-480S560DV 24 ~ 64Vdc 480 W 94.0% 0.99 0.96 EUD-480S10ADV (4) (4) Notes: (1) Output current range with constant power at 480W. (2) Certified input voltage range: 100-240Vac or 127-250Vdc (except CCC, BIS and PSE). (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) For BIS models add suffix -3000. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B I-V Operating Area EUD-480S140DV EUD-480S280DV EUD-480S420DV EUD-480S560DV EUD-480S10ADV 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 4.95 A Measured at 100% load and 120 Vac input. - - 2.65 A Measured at 100% load and 220 Vac input. - - 2.80A s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (360-480W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 105 mA 210 mA 315 mA 435 mA 750 mA - 1400 mA 2800 mA 4200 mA 5600 mA 10000 mA 1050 mA 2100 mA 3150 mA 4350 mA 7500 mA - 1400 mA 2800 mA 4200 mA 5600 mA 10000 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-480S140DV EUD-480S280DV EUD-480S420DV EUD-480S560DV EUD-480S10ADV - - 500Vdc 280Vdc 190Vdc 120Vdc 80Vdc Line Regulation - - ±0.5% Load Regulation - - ±1.5% 127-250Vdc IEC60598-1; 240Vac/ 60Hz Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25℃ cold start, duration=5.56 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (288-480W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-480S140DV EUD-480S280DV EUD-480S420DV EUD-480S560DV EUD-480S10ADV Output Current Setting Range with Constant Power EUD-480S140DV EUD-480S280DV EUD-480S420DV EUD-480S560DV EUD-480S10ADV Total Output Current Ripple (pk-pk) At 100% load condition At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUD-480S140DV Io= 1050 mA Io= 1400 mA EUD-480S280DV Io= 2100 mA Io= 2800 mA EUD-480S420DV Io= 3150 mA Io= 4200 mA EUD-480S560DV Io= 4350 mA Io= 5600 mA EUD-480S10ADV Io= 7500 mA Io= 10000 mA Efficiency at 220 Vac input: EUD-480S140DV Io= 1050 mA Io= 1400 mA EUD-480S280DV Io= 2100 mA Io= 2800 mA EUD-480S420DV Io= 3150 mA Io= 4200 mA EUD-480S560DV Io= 4350 mA Io= 5600 mA EUD-480S10ADV Io= 7500 mA Io= 10000 mA Min. Typ. Max. 90.5% 89.5% 92.5% 91.5% - 90.0% 88.5% 92.0% 90.5% - 90.5% 89.0% 92.5% 91.0% - 90.0% 89.0% 92.0% 91.0% - 90.0% 89.0% 92.0% 91.0% - 93.0% 92.0% 95.0% 94.0% - 92.0% 91.0% 94.0% 93.0% - 92.5% 91.0% 94.5% 93.0% - 92.0% 91.0% 94.0% 93.0% - 92.0% 90.5% 94.0% 92.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 93.5% 92.5% 95.5% 94.5% - 92.5% 91.0% 94.5% 93.0% - 92.5% 91.0% 94.5% 93.0% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - Standby power - - 0.5 W MTBF - 216,000 Hours - Lifetime - 91,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +85C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-480S140DV Io= 1050 mA Io= 1400 mA EUD-480S280DV Io= 2100 mA Io= 2800 mA EUD-480S420DV Io= 3150 mA Io= 4200 mA EUD-480S560DV Io= 4350 mA Io= 5600 mA EUD-480S10ADV Io= 7500 mA Io= 10000 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 10.32 × 4.93 × 1.72 262 × 125 × 43.5 9.26 × 4.93 × 1.72 235 × 125 × 43.5 - Notes 2650 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA EUD-480S140DV EUD-480S280DV EUD-480S420DV EUD-480S560DV EUD-480S10ADV 10%Ioset - Ioset EUD-480S140DV EUD-480S280DV EUD-480S420DV EUD-480S560DV EUD-480S10ADV 105 mA 210 mA 315 mA 435 mA 750 mA - Ioset Notes Vdim(+) = 0 V 1050mA ≤ Ioset ≤ 1400mA 2100mA ≤ Ioset ≤ 2800mA 3150mA ≤ Ioset ≤ 4200mA 4350mA ≤ Ioset ≤ 5600mA 7500mA ≤ Ioset ≤ 10000mA 105mA ≤ Ioset < 1050mA 210mA ≤ Ioset < 2100mA 315mA ≤ Ioset < 3150mA 435mA ≤ Ioset < 4350mA 750mA ≤ Ioset < 7500mA 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Dimming Specifications (Continued) Parameter Min. Typ. Max. 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category Standard ENEC & CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KC K 61347-1, K 61347-2-13 BIS IS 15885(PART2/SEC13) EAC ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test & Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating Lifetime vs. Case Temperature 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Inrush Current Waveform Efficiency vs. Load EUD-480S140DV(Io=1050mA) EUD-480S140DV(Io=1400mA) EUD-480S280DV(Io=2100mA) EUD-480S280DV(Io=2800mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B EUD-480S420DV(Io=3150mA) EUD-480S420DV(Io=4200mA) EUD-480S560DV(Io=4350mA) EUD-480S560DV(Io=5600mA) EUD-480S10ADV(Io=7500mA) EUD-480S10ADV(Io=10000mA) 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-480SxxxDV 480W Programmable IP67 Driver Rev. B Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-480S280DV 价格&库存
很抱歉,暂时无法提供与“EUD-480S280DV”相匹配的价格&库存,您可以联系我们找货
