EUG-240S105DT
EUG-240S105DT
    INVENTRONICS(英飞特)
EUG-240S105DT 数据手册
EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Feature • Ultra High Efficiency (Up to 94%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6 kV line-line, 10 kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location • UL Type TL (Temperature Limited) • 7 Years Warranty Description The EUG-240SxxxDT series is a 240W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for high bay, high mast, arena and roadway lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac Full-Power Current Range (1) Default Output Current 70-1050mA 700-1050mA 700 mA 90~305 Vac/ 114~343Vdc 240W 127~300 Vdc 94.0% 0.99 0.96 EUG-240S105DT 140-2100mA 1400-2100mA 1400 mA 90~305 Vac/ 57~171Vdc 240W 127~300 Vdc 93.0% 0.99 0.96 EUG-240S210DT 280-4200mA 2800-4200mA 4200 mA 90~305 Vac/ 29 ~ 86Vdc 240W 127~300 Vdc 93.0% 0.99 0.96 EUG-240S420DT (5) 445-6700mA 4450-6700mA 6700 mA 90~305 Vac/ 18 ~ 54Vdc 240W 127~300 Vdc 93.0% 0.99 0.96 EUG-240S670DT (5) Model Number (4) Notes: (1) Output current range with constant power at 240W (2) Certified voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS, except EUG-240S105DT (5) SELV Output. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D I-V Operating Area EUG-240S105DT EUG-240S210DT EUG-240S420DT EUG-240S670DT Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively - - 3.10 A Measured at full load and 100 Vac input. - - 1.40 A Measured at full load and 220 Vac input. - - 3.75 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 Notes 127~300 Vdc At 220Vac input, 25°C cold start, duration=1.26 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Input Specifications (Continued) Parameter Min. Typ. Max. Notes 0.9 - - THD - - 20% At 100-277Vac, 50-60Hz, 70%-100% Load (168-240W) THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 140 mA 280 mA 445 mA - 1050 mA 2100 mA 4200 mA 6700 mA 700 mA 1400 mA 2800 mA 4450 mA - 1050 mA 2100 mA 4200 mA 6700 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-240S105DT EUG-240S210DT EUG-240S420DT EUG-240S670DT - - 356 V 187 V 96 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA PF Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUG-240S105DT EUG-240S210DT EUG-240S420DT EUG-240S670DT Output Current Setting Range with Constant Power EUG-240S105DT EUG-240S210DT EUG-240S420DT EUG-240S670DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition. 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset At full load condition At full load condition Measured at full load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D General Specifications Parameter Min. Typ. Max. 90.0% 88.5% 92.0% 90.5% - 88.5% 88.0% 90.5% 90.0% - 89.0% 87.0% 91.0% 89.0% - 88.5% 87.0% 90.5% 89.0% - 92.0% 90.5% 94.0% 92.5% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.5% 93.0% 91.5% - 91.0% 89.5% 93.0% 91.5% - 92.5% 91.0% 94.5% 93.0% - 92.0% 89.5% 94.0% 91.5% - 91.5% 90.0% 93.5% 92.0% - 91.5% 89.5% 93.5% 91.5% - MTBF - 218,000 Hours - Lifetime - 86,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +88°C Operating Case Temperature for Warranty Tc_w -40°C - +70°C Operating Case Temperature for Type TL Tc_TL -40°C - +88°C Storage Temperature -40°C - +85°C Efficiency at 120 Vac input: EUG-240S105DT Io= 700 mA Io=1050 mA EUG-240S210DT Io=1400 mA Io=2100 mA EUG-240S420DT Io=2800 mA Io=4200 mA EUG-240S670DT Io=4450 mA Io=6700 mA Efficiency at 220 Vac input: EUG-240S105DT Io= 700 mA Io=1050 mA EUG-240S210DT Io=1400 mA Io=2100 mA EUG-240S420DT Io=2800 mA Io=4200 mA EUG-240S670DT Io=4450 mA Io=6700 mA Efficiency at 277 Vac input: EUG-240S105DT Io= 700 mA Io=1050 mA EUG-240S210DT Io=1400 mA Io=2100 mA EUG-240S420DT Io=2800 mA Io=4200 mA EUG-240S670DT Io=4450 mA Io=6700 mA Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Humidity: 5%RH to 100%RH 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Typ. Max. Notes With mounting ear 9.17 × 2.66 × 1.56 233 × 67.5 × 39.7 8.35 × 2.66 × 1.56 212 × 67.5 × 39.7 Net Weight - 1200 g - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. Notes -20 V - 20 V 200 uA 300 uA 450 uA Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2800 mA ≤ Ioset ≤ 4200 mA 4450 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset <1400 mA 280 mA ≤ Ioset <2800 mA 445 mA ≤ Ioset <4450 mA EUG-240S105DT EUG-240S210DT EUG-240S420DT EUG-240S670DT 10%Ioset - Ioset EUG-240S105DT EUG-240S210DT EUG-240S420DT EUG-240S670DT 70 mA 140 mA 280 mA 445 mA - Ioset 0V - 5V Dimming mode set to 0-5V in PC interface. 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Dimming Output Range Recommended Dimming Range for 0-5V Recommended Dimming Range for 0-10V PWM_in Duty Cycle Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Safety &EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUG-240S105DT(Io=700mA) EUG-240S105DT(Io=1050mA) 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D EUG-240S210DT(Io=1400mA) EUG-240S210DT(Io=2100mA) EUG-240S420DT(Io=2800mA) EUG-240S420DT(Io=4200mA) EUG-240S670DT(Io=4450mA) EUG-240S670DT(Io=6700mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L Vac N Inventronics LED Driver V-(BLU) Vaux(BLK/WHT) Dim+(PUR) G Dim-(GRY) 0 - 5V Dimmer Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  0-10V Dimming The recommended implementation of the dimming control is provided below. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Implementation 3: Positive logic Implementation 4: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Set the timing curve by pulling the sliders. 12 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Programming Connection Diagram Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 (Programmer) datasheet for details Mechanical Outline EUG-240S105DT INPUT(UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL 21996 3*22AWG 5.0) V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) BLACK/WHITE PURPLE GRAY Tc OUTPUT(UL STW 2*18AWG 8.9) PROJ: Unspecified tolerance:±1 13 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Others INPUT(UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL 21996 3*22AWG AC/L (BLACK) AC/N (WHITE) GND (GREEN) 5.0) V+ (RED) V- (BLUE) BLACK/WHITE PURPLE GRAY Tc OUTPUT(UL SJTW 2*18AWG 7.3) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 14 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-240SxxxDT 240W Programmable IP67 Driver Rev. D Revision History Description of Change Change Date Rev. 2016-02-29 A 2016-04-08 2017-07-04 2017-10-26 Item B C D From To Datasheets Release / / Feature / Updated General Specifications Operating Case Temperature for Type Added TL Tc_TL General Specifications With mounting ear Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Feature / Updated Models / Updated Temperature Coefficient of Ioset / Updated Dimensions / Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features 7 Years Warranty Added Operating Case Temperature for Warranty Tc_w / Updated 15 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-240S105DT 价格&库存
很抱歉,暂时无法提供与“EUG-240S105DT”相匹配的价格&库存,您可以联系我们找货
