EUM-680S840MT
EUM-680S840MT
    INVENTRONICS(英飞特)
EUM-680S840MT 数据手册
EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Features  Ultra High Efficiency (Up to 96.0%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC)with Programmability  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  INV Digital Dimming, UART Based Communication Protocol  Dim-to-Off with Standby Power ≤ 0.5 W  Minimum Dimming Level with 5% or 10% Selectable  Maximum Dimming Level with 9V or 10V Selectable  Fade Time Adjustable  Always-on Auxiliary Power: 12Vdc, 250mA  Low inrush current  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IOVP,IUVP, OVP, SCP, OTP   IP66 / IP67 and UL Dry / Damp / Wet Location TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location 5 Years Warranty  Description The EUM-680SxxxMx series is a 680W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 90-305Vac input with excellent power factor. Created for many lighting applications including high mast, sports, UV-LED, aquaculture and horticulture, etc. It provides an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range Input Voltage Range(2) Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac Model Number 0.125-1.7A 1.25-1.7A 1.7 A 90~305Vac 200 ~ 544Vdc 680 W 127~300Vdc 95.5% 0.99 0.96 EUM-680S170Mx 0.18-2.4A 1.8-2.4A 2.1 A 90~305Vac 141.5 ~ 378Vdc 680 W 127~300Vdc 94.5% 0.99 0.96 EUM-680S240Mx 0.26-3.5A 2.6-3.5A 3.5 A 90~305Vac 97.1 ~ 262Vdc 680 W 127~300Vdc 95.0% 0.99 0.96 EUM-680S350Mx 0.42-5.6A 4.2-5.6A 5.6 A 90~305Vac 60.7 ~ 163Vdc 680 W 127~300Vdc 94.5% 0.99 0.96 EUM-680S560Mx 0.63-8.4A 6.3-8.4A 8.4 A 90~305Vac 40.4 ~ 108Vdc 680 W 127~300Vdc 95.0% 0.99 0.96 EUM-680S840Mx(4) 0.96 EUM-680S15AMx(4) 90~305Vac 0.99 22.6 ~ 54Vdc 680 W 95.5% 127~300Vdc Notes: (1) Output current range with constant power at 680W. (2) Certified input voltage range: UL, FCC, CB 100-277Vac; otherwise 100-240Vac 1.26-15.0A 12.6-15.0A 15.0 A 1 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models. I-V Operating Area EUM-680S170Mx EUM-680S240Mx EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx 2 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Input Specifications Parameter Min. Typ. Max. Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz 0.70 mA IEC60598-1; 240Vac/ 60Hz,  Leakage Current Notes - - 6.9 A Measured at 100% load and 120 Vac input. - - 3.6 A Measured at 100% load and 220 Vac input. - - 2.1 A2s 0.90 - - - - 20% Input AC Current At 220Vac input, 25℃ cold start, Inrush Current(I2t) PF THD THD duration=14.2 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 60%-100% Load (408 - 680W) 10% At 220-240Vac, 50-60Hz, 75%-100% Load (510 - 680W) Notes Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset Range EUM-680S170Mx EUM-680S240Mx EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx Output Current Setting Range with Constant Power EUM-680S170Mx EUM-680S240Mx EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Startup Overshoot Current Min. Typ. Max. -5%Ioset - 5%Ioset 125 mA 180 mA 260 mA 420 mA 630 mA 1260 mA - 1700 mA 2400 mA 3500 mA 5600 mA 8400 mA 15000 mA 1250 mA 1800 mA 2600 mA 4200 mA 6300 mA 12600 mA - 1700 mA 2400 mA 3500 mA 5600 mA 8400 mA 15000 mA - 5%Iomax 10%Iomax 100% load, 20 MHz BW - - 2%Iomax 70%-100% load - - 10%Iomax 100% load 3 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 100% load All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Output Specifications (Continued) Parameter Min. Typ. Max. No Load Output Voltage EUM-680S170Mx EUM-680S240Mx EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx - - 600 V 420 V 300 V 200 V 120 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA Min. Typ. Max. 92.0% 92.0% 94.0% 94.0% - 90.5% 90.0% 92.5% 92.0% - 90.0% 90.5% 92.0% 92.5% - 90.0% 90.0% 92.0% 92.0% - 90.5% 90.5% 92.5% 92.5% - 92.0% 92.0% 94.0% 94.0% - Notes 100% load Measured at 120-277Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 250mA. 850mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 250mA. General Specifications Parameter Efficiency at 120 Vac input: EUM-680S170Mx Io= 1250 mA Io= 1700 mA EUM-680S240Mx Io= 1800 mA Io= 2400 mA EUM-680S350Mx Io= 2600 mA Io= 3500 mA EUM-680S560Mx Io= 4200 mA Io= 5600 mA EUM-680S840Mx Io= 6300 mA Io= 8400 mA EUM-680S15AMx Io= 12600 mA Io= 15000 mA 4 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A General Specifications (Continued) Parameter Min. Typ. Max. 93.5% 93.5% 95.5% 95.5% - 92.5% 92.5% 94.5% 94.5% - 92.5% 93.0% 94.5% 95.0% - 92.5% 92.5% 94.5% 94.5% - 93.0% 93.0% 95.0% 95.0% - 93.5% 93.5% 95.5% 95.5% - 93.5% 93.5% 95.5% 95.5% - 93.0% 93.0% 95.0% 95.0% - 93.0% 93.5% 95.0% 95.5% - 93.0% 93.0% 95.0% 95.0% - 93.0% 93.0% 95.0% 95.0% - 94.0% 94.0% 96.0% 96.0% - Standby Power - - 0.5 W MTBF - 201,000 Hours - - 107,000 Hours - - 67,000 Hours - -40°C - +90°C -40°C - +80°C -40°C - +85°C Efficiency at 220 Vac input: EUM-680S170Mx Io= 1250 mA Io= 1700 mA EUM-680S240Mx Io= 1800 mA Io= 2400 mA EUM-680S350Mx Io= 2600 mA Io= 3500 mA EUM-680S560Mx Io= 4200 mA Io= 5600 mA EUM-680S840Mx Io= 6300 mA Io= 8400 mA EUM-680S15AMx Io= 12600 mA Io= 15000 mA Efficiency at 277 Vac input: EUM-680S170Mx Io= 1250 mA Io= 1700 mA EUM-680S240Mx Io= 1800 mA Io= 2400 mA EUM-680S350Mx Io= 2600 mA Io= 3500 mA EUM-680S560Mx Io= 4200 mA Io= 5600 mA EUM-680S840Mx Io= 6300 mA Io= 8400 mA EUM-680S15AMx Io= 12600 mA Io= 15000 mA Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Net Weight - 3079 g www.inventronics-co.com Tel: 86-571-56565800 Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Measured at 220Vac input, 100%Load and 40C ambient temperature Case temperature for 5 years warranty Humidity: 10%RH to 95%RH Humidity: 5%RH to 100%RH - 5 / 20 Specifications are subject to changes without notice. Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) With mounting ear 10.83 × 5.31 × 1.81 275 ×135 x 46 9.84 × 5.31 × 1.81 250 × 135 x 46 Inches (L × W × H) Millimeters (L × W × H) Notes All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 uA 300 uA 450 uA EUM-680S170Mx EUM-680S240Mx EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx 10%Ioset - Ioset 125 mA 180 mA 260 mA 420 mA 630 mA 1260 mA - Ioset 5%Ioset - Ioset 63 mA 90 mA 130 mA 210 mA 315 mA 630 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range with 10%-100% EUM-680S170Mx EUM-680S240Mx (Default) EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx EUM-680S170Mx EUM-680S240Mx EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx Dimming Output Range with EUM-680S170Mx 5%-100% EUM-680S240Mx (Settable) EUM-680S350Mx EUM-680S560Mx EUM-680S840Mx EUM-680S15AMx Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis 6 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V 1250 mA ≤ Ioset ≤ 1700 mA 1800 mA ≤ Ioset ≤ 2400 mA 2600 mA ≤ Ioset ≤ 3500 mA 4200 mA ≤ Ioset ≤ 5600 mA 6300 mA ≤ Ioset ≤ 8400 mA 12600 mA ≤ Ioset ≤ 15000 mA 125 mA ≤ Ioset < 1250 mA 180 mA ≤ Ioset <1800 mA 260 mA ≤ Ioset < 2600 mA 420 mA ≤ Ioset < 4200 mA 630 mA ≤ Ioset < 6300 mA 1260 mA ≤ Ioset < 12600 mA 1250 mA ≤ Ioset ≤ 1700 mA 1800 mA ≤ Ioset ≤ 2400 mA 2600 mA ≤ Ioset ≤ 3500 mA 4200 mA ≤ Ioset ≤ 5600 mA 6300 mA ≤ Ioset ≤ 8400 mA 12600 mA ≤ Ioset ≤ 15000 mA 125 mA ≤ Ioset < 1250 mA 180 mA ≤ Ioset <1800 mA 260 mA ≤ Ioset < 2600 mA 420 mA ≤ Ioset < 4200 mA 630 mA ≤ Ioset < 6300 mA 1260 mA ≤ Ioset < 12600 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx Rev.A 680W Programmable Driver with INV Digital Dimming Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 NOM NOM-058-SCFI EMI Standards EN 55015/GB 17743(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 7 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx Rev.A 680W Programmable Driver with INV Digital Dimming Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUM-680S170Mx(lo=1250mA) EUM-680S170Mx(lo=1700mA) 8 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx Rev.A 680W Programmable Driver with INV Digital Dimming EUM-680S240Mx(lo=1800mA) EUM-680S240Mx(lo=2400mA) EUM-680S350Mx(lo=2600mA) EUM-680S350Mx(lo=3500mA) EUM-680S560Mx(lo=4200mA) EUM-680S560Mx(lo=5600mA) 9 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx Rev.A 680W Programmable Driver with INV Digital Dimming EUM-680S840Mx(lo=6300mA) EUM-680S840Mx(lo=8400mA) EUM-680S15AMx(lo=12600mA) EUM-680S15AMx(lo=15000mA) Power Factor 10 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP)  Input Protection Voltage Input Recovery Voltage Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 70 Vac 80 Vac 90 Vac Turn off the output when the input voltage falls below protection voltage. 75 Vac 85 Vac 95 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 8 hours with a stable input voltage stress of 350Vac. Input Under Voltage Protection Diagram lo 80 Vac 85 Vac 11 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Vin All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx  680W Programmable Driver with INV Digital Dimming Rev.A Input Over Voltage Protection Diagram lo Recovery Protection 310 Vac 320 Vac Vin Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 12 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic 13 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-680SxxxMx 680W Programmable Driver with INV Digital Dimming Rev.A Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-680S840MT 价格&库存
很抱歉,暂时无法提供与“EUM-680S840MT”相匹配的价格&库存,您可以联系我们找货
EUM-680S840MT
    EUM-680S840MT
      EUM-680S840MT
