EUV-026SxxxPS
26W Constant Voltage IP66 Driver
Rev. J
Features
High Efficiency (Up to 86%)
Active Power Factor Correction (Typical 0.95)
Constant Output Voltage
Waterproof (IP66) and Damp Location
All-Around Protection: OVP, SCP, OCP
Class 2 and SELV
Description
The EUV-026SxxxPS Series operates from a 90 ~ 305 Vac input range. They are designed to be highly efficient
and highly reliable. Features include over voltage protection, short circuit protection and over current protection.
Models
Output
Voltage
Input
Voltage
Range(1)
Output
Current
Range
Max.
Output
Power
Typical
Power Factor
Efficiency
120Vac 220Vac
(2)
24 Vdc
90 ~ 305 Vac
0~1080mA
26 W
84%
0.96
0.95
EUV-026S024PS
36 Vdc
90 ~ 305 Vac
0~720 mA
26 W
85%
0.96
0.95
EUV-026S036PS
48 Vdc
90 ~ 305 Vac
0~540 mA
26 W
86%
0.96
0.95
EUV-026S048PS
Model Number
(3)
(3)
(4)
Notes: (1) UL, FCC certified input voltage range: 100~277Vac, other certified input voltage range except UL & FCC:
100~240Vac.
(2) Measured at 100% load and 220 Vac input.
(3) Class 2 output (USR & CNR).
(4) Class 2 output (USR), Non-Class 2 output (CNR).
Input Specifications
Parameter
Min.
Typ.
Max.
Notes
Input Voltage
90 V
305 V
Input Frequency
47 Hz
63 Hz
0.75 mA
At 277Vac 60Hz input
0.70 mA
IEC60598-1; 240Vac/ 60Hz
0.4 A
0.2 A
40 A
Leakage Current
Input AC Current
Inrush Current
2
Inrush Current(I t)
Power Factor
THD
2
0.043 A s
0.90
20%
Measured at 100% load and 100 Vac
input.
input.
At 220Vac input 25℃ Cold Start.
Duration=100 μs, 10%Ipk-10%Ipk.
At 100Vac-277Vac, 50-60Hz,75%load100%load (19.5~26W)
1/7
Specifications are subject to changes without notice.
www.inventronics-co.com
Tel: 86-571-56565800
Fax: 86-571-86601139
sales@inventronics-co.com
EUV-026SxxxPS
Rev. J
Output Specifications
Parameter
Min.
Output Voltage Tolerance
Typ.
-5%Vo
Max.
5%Vo
Output Voltage Ripple
Measured by 20 MHz bandwidth
oscilloscope and the output paralleled a
0.1 uF ceramic capacitor and a 10 uF
electrolytic capacitor.
3V
4V
4V
28 V
40 V
52 V
10%Vo
Line Regulation
±2%
Load Regulation
±3%
0.40 s
0.75 s
0.30 s
0.50 s
0.2%/C
Vo = 24 V
Vo = 36 V
Vo = 48 V
No Load Output Voltage
Vo = 24 V
Vo = 36 V
Vo = 48 V
Output Voltage Overshoot
/ Undershoot
Turn-on Delay Time
Temperature coefficient
Notes
At 100% load condition.
Measured at 100% load.
Measured at 120Vac input, 75%load-100%
load
Measured at 220Vac input, 75%load-100%
load
Case temperature = 0C ~Tc max
Note: All specifications are typical at 25 C unless otherwise stated.
General Specifications
Parameter
Min.
Typ.
Max.
82%
83%
84%
83%
84%
85%
Measured at 100% load and steady-state
temperature in 25℃ ambient.
83%
84%
85%
84%
85%
86%
5W
200,000
hours
Measured at 120Vac input, 80%Load and
25C ambient temperature (MIL-HDBK217F)
91,100
Hours
Measured at 120Vac input, 80%Load,
Case temperature=60℃ @ Tc point, See
life time vs. Tc curve for the details.
Operating Case Temperature for
Safety Tc_s
-40 ℃
+90C
Warranty Tc_w
-40 ℃
+70 ℃
Humidity: 10% RH to 100% RH.
Storage Temperature
-40 ℃
+85 ℃
Humidity: 5% RH to 100% RH
Efficiency at 120 Vac input:
Vo = 24 V
Vo = 36 V
Vo = 48 V
Efficiency at 220 Vac input:
Vo = 24 V
Vo = 36 V
Vo = 48 V
No Load Power Dissipation
MTBF
Lifetime
Notes
2/7
EUV-026SxxxPS
Rev. J
General Specifications (Continued)
Parameter
Min.
Typ.
Max.
Notes
Dimensions
3.07 × 3.15 × 1.06
78 × 80 × 27
Inches (L × W × H)
Millimeters (L × W × H)
Net Weight
220 g
Safety & EMC Compliance
Safety Category
UL/CUL
Standard
UL8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91
CE
EN 61347-1, EN61347-2-13
KS
KS C 7655
EMI Standards
(1)
EN 55015/KN 15
Notes
Conducted emission Test & Radiated emission Test
EN 61000-3-2
Harmonic current emissions
EN 61000-3-3
Voltage fluctuations & flicker
ANSI C63.4 Class B
(1)
FCC Part 15
This device complies with Part 15 of the FCC Rules. Operation is subject to the
following two conditions: [1] this device may not cause harmful interference, and [2]
this device must accept any interference received, including interference that may
cause undesired operation.
EMS Standards
Notes
EN 61000-4-2
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge
EN 61000-4-3
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
EN 61000-4-4
Electrical Fast Transient / Burst-EFT
EN 61000-4-5
Surge Immunity Test: AC Power Line: Differential Mode 2 kV
EN 61000-4-6
Conducted Radio Frequency Disturbances Test-CS
EN 61000-4-8
Power Frequency Magnetic Field Test
EN 61000-4-11
Voltage Dips
EN 61547
Electromagnetic Immunity Requirements Applies To Lighting Equipment
Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends
also on the other devices connected to the driver and on the fixture itself.
3/7
EUV-026SxxxPS
Rev. J
Lifetime vs. Case Temperature
Efficiency vs. Load
EUV-026S024PS
EUV-026S036PS
EUV-026S048PS
4/7
EUV-026SxxxPS
Rev. J
Power Factor
Protection Functions
Parameter
Min.
Typ.
Max.
Notes
Over Voltage Protection
110%
120%
130%
Hiccup mode. The power supply shall be
self-recovery when the fault condition is
removed.
Over Current Protection
1.1Io
1.4Io
1.7Io
removed.
Short Circuit Protection
Auto Recovery. No damage shall occur when any output operating in a short circuit
condition. The power supply shall be self-recovery when the fault condition is
removed.
5/7
EUV-026SxxxPS
Rev. J
Mechanical Outline
AC INPUT (UL1015 18AWG)
WHITE (ACN)
BLACK(ACL)
Tc
RED(V+)
BLACK(V-)
DCOUTPUT (UL1007 18AWG)
PROJ:
Unspecified tolerance:±1
RoHS Compliance
Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the
elimination of lead and other hazardous substances from electronic products.
6/7
EUV-026SxxxPS
Rev. J
Revision History
Description of Change
Change
Date
Rev.
2012-04-24
A
Datasheet Release
2012-05-25
B
EN 61000-4-5--- line to line 2 kV, line to earth 4 kV
Corrected
2012-06-06
C
Lifetime vs. Tc Curve
Added
Notes of lifetime
Updated
2012-07-17
D
Max Case Temperature
Updated
2012-07-30
E
Min Operating Temperature
-20℃
-40℃
Derating Curve
Updated
Inrush Current
60A
40A
Inrush Current(I2t)
Added
Temperature Coefficient
Added
Lifetime
Min 50,000hrs
Typical 91,100hrs
Lifetime Curve
Updated
Energy star
Deleted
Turn-on Delay Time at 120Vac
Max.=1.0 s
Max.=0.75 s
Operating Case Temperature for Warranty Tc_w
Added
Net Weight
200 g
220 g
Environmental Specifications
Deleted
KS Certificate Regulation
Added
Note of EMI Standard
Added
Derating Curve
Deleted
KCC Logo
Added
Input Specifications(PF/THD)
50-60Hz
Added
Safety &EMC Compliance
UL/CUL
Updated
KS
2012-08-20
Item
F
2012-11-26
G
2013-07-01
H
2016-08-08
2019-08-14
I
J
From
To
Updated
(1)
(1)
EN 55015
EN 55015/KN 15
FCC
Updated
EN 61000-4-4
Updated
EN 61000-4-5
Updated
RoHS Compliance
Updated
7/7
很抱歉,暂时无法提供与“EUV-026S024PS”相匹配的价格&库存,您可以联系我们找货
