EUV-076S048SV
EUV-076S048SV
    INVENTRONICS(英飞特)
EUV-076S048SV 数据手册
EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H Features  High Efficiency (Up to 91%)  Active Power Factor Correction (0.99 Typical)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Round Protection: OVP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The EUV-076SxxxSV series is a 76W, constant-voltage LED driver that operates from 90 ~ 305 Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Output Voltage Input Voltage Range Output Current Range Max. Output Power Typical Efficiency (1) 110Vac 220Vac 12 V 90 ~ 305 Vac 0~5.00 A 60 W 87% 0.99 0.96 EUV-076S012SV 24 V 90 ~ 305 Vac 0~3.17 A 76 W 88% 0.99 0.96 EUV-076S024SV 36 V 90 ~ 305 Vac 0~2.11 A 76 W 89% 0.99 0.96 EUV-076S036SV 42 V 90 ~ 305 Vac 0~1.81 A 76 W 89% 0.99 0.96 EUV-076S042SV 48 V 90 ~ 305 Vac 0~1.58 A 76 W 90% 0.99 0.96 EUV-076S048SV 54 V 90 ~ 305 Vac 0~1.41 A 76 W 91% 0.99 0.96 EUV-076S054SV Power Factor Model Number Notes: (1) Measured at 100% load and 220 Vac input. (2) For BIS models add suffix -3000. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 V - 305 V Input Frequency 47 Hz - 63 Hz Leakage Current - - 1 mA At 277Vac 60Hz input - - 0.9 A Measured at 100% load and 100 Vac input. - - 0.42 A Measured at 100% load and 220 Vac input. Input AC Current 1/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H Input Specifications (Continued) Parameter Min. Typ. Max. - - 60 A - - 2 0.7 A s 0.9 - - - - 20% Min. Typ. Max. Output Voltage Tolerance -5% - 5% Ripple and Noise (pk-pk) - - 2% VO Line Regulation - - 1% Load Regulation - - 2% - 0.8 s 1.2 s Measured at 110Vac input. 0.4 s 0.6 s Measured at 220Vac input. - - 10% When power on or off. - - 5% VO - - 10 mS Inrush Current 2 Inrush Current(I t) PF Notes At 220Vac input 25°C Cold Start, duration= 1 mS, 10%Ipk-10%Ipk. At 100-277Vac, 50-60Hz, 75%-100% Load THD Output Specifications Parameter Notes Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Output Overshoot / Undershoot Output Load Deviation Dynamic Response Settling Time R/S: 1 A/uS Load: 25% ~ 75% full load. Note: All specifications are typical at 25 C unless otherwise stated. Protection Functions Parameter Min. Typ. Max. Over Voltage Protection Vo = 12 V Vo = 24 V Vo = 36 V Vo = 42 V Vo = 48 V Vo = 54 V - 18 V 35 V 50 V 58 V 60 V 65 V 22 V 40 V 55 V 63 V 65 V 70 V 1.2 Io - 1.5 Io Over Current Protection Over Temperature Protection Short Circuit Protection Notes Latch mode. The power supply shall return to normal operation only after the power is turn-on again. Latch mode. The power supply shall return to normal operation only after the power is turn-on again. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. - 110 C - 2/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H General Specifications Parameter Min. Typ. Max. Notes Vo = 12 V Vo = 24 V Vo = 36 V Vo = 42 V Vo = 48 V Vo = 54 V 83% 84% 85% 85% 85% 86% 85% 86% 87% 87% 87% 88% - Measured at 100% load, 110Vac input, 25℃ ambient temperature, after the unit is thermally stabilized. It will be lower about 2%, if measured immediately after startup. Vo = 12 V Vo = 24 V Vo = 36 V Vo = 42 V Vo = 48 V Vo = 54 V 85% 86% 87% 87% 87% 88% 87% 88% 89% 89% 89% 90% 395,000 hours - Measured at 100% load, 220Vac input, 25℃ ambient temperature, after the unit is thermally stabilized. It will be lower about 2%, if measured immediately after startup. Efficiency Efficiency Measured at 110Vac input, 80% load and 25C ambient temperature (MIL-HDBK-217F) Measured at 110Vac input, 80% load ; Case temperature=65℃ @ Tc point. See lifetime vs. Tc curve for the details MTBF - Lifetime - 51,000 hours - -40°C - +90 ℃ -40°C - +65 ℃ Case temperature for 5 years warranty -40°C - +85 ℃ Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters ( L × W × H ) - With mounting ear 6.97 × 2.66 × 1.44 177 × 67.5 × 36.5 5.91 × 2.66 × 1.44 150 × 67.5 × 36.5 Net Weight - 750 g - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category Standard TUV&CE EN 61347-1, EN 61347-2-13 CCC GB 19510.1, GB 19510.14 BIS IS 15885(Part2/Sec13) PSE J 61347-1, J 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 3/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies to Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Curve Derating Curve 100 Load(%) 80 60 40 20 0 90 120 150 180 210 240 270 300 330 Input Voltage(V) Lifetime vs. Case Temperature Curve 4/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H Mechanical Outline EUV-076SxxxSV INPUT (VDE H05RN-F 3*1.0mm2 OUTPUT (VDE H05RN-F 2*1.0mm2 7.2) AC/L(BROWN) AC/N(BLUE) GND/(YELLOW/GREEN) 6.8) (V+) BROWN (V-) BLUE Tc PROJ: Unspecified tolerance:±1 EUV-076SxxxSV-3000 INPUT(BIS 3*1.0mm2 7.25) AC/L (RED) AC/N (BLACK) GND (YELLOW/GREEN) OUTPUT(BIS 2*1.0mm 2 6.85) V+ (RED) V- (BLACK) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 5/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H Revision History Change Date Description of Change Rev. Item From To Add notes of UL1310 Class 2 for all models. (4) (5) Min. 84.5%, 85.5%, 86.5%, 86.5%, 87.5%, 87.5%, Min. 86.5%, 87.5%, 88.5%, 88.5%, 89.5%, 89.5%, Efficiency (110Vac) Vo = 12 V Vo = 24 V Vo = 36 V Vo = 42 V Vo = 48 V Vo = 54 V Efficiency (220Vac) 2010-03-03 Vo = 12 V Vo = 24 V Vo = 36 V Vo = 42 V Vo = 48 V Vo = 54 V A 0.95 0.96 Change MTBF 498,000 hours 450,000 hours / / / / Current in Input Add Derating Curve B Min. 83%, 84%, 85%, 85%, 86%, 87%, Min. 85%, 86%, 87%, 87%, 88%, 89%, Change PF of 12V (220Vac) Add Leakage Specifications 2012-06-19 Typ. 86% 87% 88% 88% 89% 89% Typ. 88% 89% 90% 90% 91% 91% Modify the tin-plated wire length ±0.5 ±2 tolerance in Mechanical Outline Life Time vs. Case Temperature / Added Curve line to line 2 kV, line to earth 4 line to line 4 kV, line to earth 6 EN61000-4-5 kV kV Mechanical outline / Updated 2012-7-5 C Inrush Current 50 A 60 A 2012-7-17 D Max Case Temperature / Updated Inrush Current(I t) / Added Turn-on Delay Time @ 110Vac 0.5s,0.8s 0.8s,1.2s OCP / Added Efficiency of 48V,54V / 1% Lower MTBF-typical value / Added Life time-typical value / Added Life time curve / Updated Format / Updated Features / Updated 2 2013-03-13 2017-06-19 E Typ. 85% 86% 87% 87% 88% 89% Typ. 87% 88% 89% 89% 90% 91% F 6/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-076SxxxSV 76W Constant Voltage IP67 Driver Rev. H Revision History (Continued) Change Date 2017-06-19 2018-11-21 Description of Change Rev. Item / Updated Models Notes Added Input Specifications PF Added Input Specifications THD Added General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications With mounting ear Added Safety & EMC Compliance / Updated Mechanical Outline / Updated TUV/BIS / Updated PSE / Added Features 5 Years Warranty Added Description / Updated PF/THD Notes Updated Lifetime Notes Updated F G General Specifications H To Description General Specifications 2019-12-17 From Operating Case Temperature Updated for Safety Tc_s Operating Case Temperature Updated for Warranty Tc_w General Specifications Storage Temperature Updated Environmental Specifications / Deleted Safety &EMC Compliance / Updated Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof (IP67) IP67 Models Notes(2) Added Safety &EMC Compliance PSE Updated Safety &EMC Compliance J 55015 Deleted Safety &EMC Compliance EN 61000-4-5 Updated Derating Curve Ambient Temperature(°C) Deleted Mechanical Outline EUV-076SxxxSV-3000 Added RoHS Compliance / Updated 7/7 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-076S048SV 价格&库存
很抱歉,暂时无法提供与“EUV-076S048SV”相匹配的价格&库存,您可以联系我们找货
EUV-076S048SV
