EUD-096S070DVL
EUD-096S070DVL
    INVENTRONICS(英飞特)
EUD-096S070DVL 数据手册
` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A Features • Innovative Design with No Electrolytic Capacitors • Ultra Long Lifetime: Greater than 100,000 hrs at 85°C Case Temperature • Full Power at Wide Output Current Range (Constant Power) • Thermal Sensing and Protection for LED Module • 0-10V/PWM/Timer Dimmable (3 Timer Modes ) • Dim-to-Off with Standby Power ≤ 0.5 W • Always-on Auxiliary Power: 12Vdc, 200mA • Output Lumen Compensation • Input Surge Protection: 6kV line-line, 10kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) • SELV Output • Suitable for Independent Use • 10 Years Warranty Description The EUD-096SxxxDVL series is a novel 96W design that has removed the use of Electrolytic capacitors to extend lifetime at elevated temperatures. It is a constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for high bay, tunnel and street lights, it provides a dim-tooff mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature of both the driver and the external LED array. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 45-700mA 450-700mA 530 mA 90~305Vac 74~213Vdc 127~250Vdc 96 W 92.5% 0.98 0.96 EUD-096S070DVL 70-1050mA 700-1050mA 700 mA 90~305Vac 48~137Vdc 127~250Vdc 96 W 92.0% 0.98 0.96 EUD-096S105DVL 140-2100mA 1400-2100mA 2100 mA 90~305Vac 24 ~ 69Vdc 127~250Vdc 96 W 91.5% 0.98 0.96 EUD-096S210DVL 245-3500mA 2450-3500mA 2800 mA 90~305Vac 14 ~ 39Vdc 127~250Vdc 96 W 91.5% 0.98 0.96 EUD-096S350DVL Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number (4) (4) Notes: (1) Output current range with constant power at 96W (2) Certified input voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE and KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A I-V Operating Area EUD-096S070DVL EUD-096S105DVL EUD-096S210DVL EUD-096S350DVL Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.20 A Measured at full load and 100 Vac input. - - 0.50 A Measured at full load and 220 Vac input. - - 0.76 A s 127~250 Vdc IEC60598-1; 240Vac/ 60Hz Input AC Current 2 Inrush Current(I t) 2 At 220Vac input, 25°C Cold Start, Duration=116 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (72-96W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 45 mA 70 mA 140 mA 245 mA - 700 mA 1050 mA 2100 mA 3500 mA 450 mA 700 mA 1400 mA 2450 mA - 700 mA 1050 mA 2100 mA 3500 mA - 8%Iomax 15%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-096S070DVL EUD-096S105DVL EUD-096S210DVL EUD-096S350DVL - - 230 V 160 V 77 V 45 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA PF Notes At 100-240Vac, 50-60Hz, 60%-100% Load (58-96W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-096S070DVL EUD-096S105DVL EUD-096S210DVL EUD-096S350DVL Output Current Setting Range with Constant Power EUD-096S070DVL EUD-096S105DVL EUD-096S210DVL EUD-096S350DVL Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset At full load condition At full load condition Measured at full load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A General Specifications Parameter Min. Typ. Max. 88.5% 87.5% 90.5% 89.5% - 88.0% 87.0% 90.0% 89.0% - 87.5% 86.0% 89.5% 88.0% - 87.5% 86.5% 89.5% 88.5% - 90.5% 89.5% 92.5% 91.5% - 90.0% 89.0% 92.0% 91.0% - 89.5% 88.5% 91.5% 90.5% - 89.5% 88.0% 91.5% 90.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 90.0% 88.5% 92.0% 90.5% - 90.0% 88.5% 92.0% 90.5% - Standby power - - 0.5 W MTBF - 219,000 Hours - Lifetime - 100,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 10 years warranty. Please see Inventronics EUD-DVL Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-096S070DVL Io= 450 mA Io= 700 mA EUD-096S105DVL Io= 700 mA Io= 1050 mA EUD-096S210DVL Io= 1400 mA Io= 2100 mA EUD-096S350DVL Io= 2450 mA Io= 3500 mA Efficiency at 220 Vac input: EUD-096S070DVL Io= 450 mA Io= 700 mA EUD-096S105DVL Io= 700 mA Io= 1050 mA EUD-096S210DVL Io= 1400 mA Io= 2100 mA EUD-096S350DVL Io= 2450 mA Io= 3500 mA Efficiency at 277 Vac input: EUD-096S070DVL Io= 450 mA Io= 700 mA EUD-096S105DVL Io= 700 mA Io= 1050 mA EUD-096S210DVL Io= 1400 mA Io= 2100 mA EUD-096S350DVL Io= 2450 mA Io= 3500 mA Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 85°C case temperature; See lifetime vs. Tc curve for the details 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Typ. Max. With mounting ear 7.92 × 2.66 × 1.44 201 × 67.5 × 36.5 7.09 × 2.66 × 1.44 180 × 67.5 × 36.5 - 960 g Notes - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+) Pin EUD-096S070DVL EUD-096S105DVL EUD-096S210DVL EUD-096S350DVL Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset EUD-096S070DVL EUD-096S105DVL EUD-096S210DVL EUD-096S350DVL Recommended Dimming Input Range 45 mA 70 mA 140 mA 245 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz PWM_in Duty Cycle 1% - 99% PWM Dimming off (Positive Logic) 2% 5% 8% PWM Dimming on (Positive Logic) 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Dimming Output Range Hysteresis PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25°C unless otherwise stated. 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge(ESD): 8kV air discharge, 4kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient/Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6kV, line to earth 10kV EN 61000-4-6 Conducted Radio Frequency Disturbances test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2)To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A Inrush Current Waveform Efficiency vs. Load EUD-096S070DVL(Io=450mA) EUD-096S070DVL(Io=700mA) EUD-096S105DVL(Io=700mA) EUD-096S105DVL(Io=1050mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A EUD-096S210DVL(Io=1400mA) EUD-096S210DVL(Io=2100mA) EUD-096S350DVL(Io=2450mA) EUD-096S350DVL(Io=3500mA) Power Factor 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. R2 - 4.16 kOhm - When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+(BRN) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) 0 (1)-10V Dimmer Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming V+(BRN) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 2: Positive logic 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-096SxxxDVL 96W Programmable Driver with Ultra Long Lifetime Rev.A V+(BRN) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 3: Negative logic   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-096S070DVL
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电晶体管开关,具有高输入阻抗和低输出阻抗,适用于高速光耦合器。
3. 引脚分配:共4个引脚,分别为阳极、阴极、发射极和集电极。
4. 参数特性:工作温度范围为-40℃至+85℃,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强和响应速度快的特点。
6. 应用信息:广泛应用于数字通信、测量设备和工业控制系统等领域。
7. 封装信息:采用DIP-4封装。
EUD-096S070DVL 价格&库存
很抱歉,暂时无法提供与“EUD-096S070DVL”相匹配的价格&库存,您可以联系我们找货
