EUD-200S105BTA
EUD-200S105BTA
    INVENTRONICS(英飞特)
EUD-200S105BTA 数据手册
EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C Features  Ultra High Efficiency (Up to 94.5%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  DALI/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA (Transient Peak Current up to 400mA)  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  7 Years Warranty Description The EUD-200SxxxBTA series is a 200W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, arena and roadway, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 100~300 Vdc 90~305 Vac/ 140-2100mA 1400-2100mA 1400 mA 100~300 Vdc 90~305 Vac/ 245-3500mA 2450-3500mA 2800 mA 100~300 Vdc 90~305 Vac/ 385-5600mA 3850-5600mA 4900 mA 100~300 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (5) 95~286Vdc 200W 94.5% 0.99 0.96 EUD-200S105BTA 48~143Vdc 200W 94.0% 0.99 0.96 EUD-200S210BTA 29 ~ 82Vdc 200W 93.5% 0.99 0.96 EUD-200S350BTA 18 ~ 52Vdc 200W 93.0% 0.99 0.96 EUD-200S560BTA (4) (4) Notes: (1) Output current range with constant power at 200W (2) Certified voltage range: UL, FCC 100-277Vac or 100-300Vdc; otherwise 100-240Vac or 100-250Vdc (except KS). (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output (5) All the models are certificated to KS, except EUD-200S105BTA 1 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C I-V Operation Area EUD-200S105BTA EUD-200S210BTA EUD-200S350BTA EUD-200S560BTA Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 2.50 A Measured at 100% load and 100 Vac input. - - 1.10 A Measured at 100% load and 220 Vac input. - - 2.90 A2s 100~300Vdc Leakage Current Input AC Current Inrush Current(I2t) At 220Vac input, 25°C cold start, duration=1.20 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (150-200W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 140 mA 245 mA 385 mA - 1050 mA 2100 mA 3500 mA 5600 mA 700 mA 1400 mA 2450 mA 3850 mA - 1050 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-200S105BTA EUD-200S210BTA EUD-200S350BTA EUD-200S560BTA - - 330 V 170 V 100 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Return terminal is “OTP−“ - - 400 mA 400mA peak for a maximum duration of 300ms in a 2s period during which time the average should not exceed 200mA. PF Notes At 100-277Vac, 50-60Hz, 70%-100% Load (140-200W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-200S105BTA EUD-200S210BTA EUD-200S350BTA EUD-200S560BTA Output Current Setting Range with Constant Power EUD-200S105BTA EUD-200S210BTA EUD-200S350BTA EUD-200S560BTA Total Output Current Ripple (pk-pk) 12V Auxiliary Output Transient Peak Current At 100% load condition, 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset At 100% load condition At 100% load condition Measured at 100% load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. 3 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C General Specifications Parameter Min. Typ. Max. 89.5% 88.5% 91.5% 90.5% - 89.0% 88.0% 91.0% 90.0% - 89.0% 87.5% 91.0% 89.5% - 88.5% 86.5% 90.5% 88.5% - 92.5% 91.0% 94.5% 93.0% - 92.0% 91.0% 94.0% 93.0% - 91.5% 90.0% 93.5% 92.0% - 91.0% 88.5% 93.0% 90.5% - 92.5% 91.5% 94.5% 93.5% - 92.5% 91.0% 94.5% 93.0% - 92.0% 90.5% 94.0% 92.5% - 91.5% 89.0% 93.5% 91.0% - Standby power - - 0.5 W MTBF - 233,000 Hours - Lifetime - 108,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-200S105BTA Io= 700mA Io=1050mA EUD-200S210BTA Io=1400mA Io=2100mA EUD-200S350BTA Io=2450mA Io=3500mA EUD-200S560BTA Io=3850mA Io=5600mA Efficiency at 220 Vac input: EUD-200S105BTA Io= 700mA Io=1050mA EUD-200S210BTA Io=1400mA Io=2100mA EUD-200S350BTA Io=2450mA Io=3500mA EUD-200S560BTA Io=3850mA Io=5600mA Efficiency at 277 Vac input: EUD-200S105BTA Io= 700mA Io=1050mA EUD-200S210BTA Io=1400mA Io=2100mA EUD-200S350BTA Io=2450mA Io=3500mA EUD-200S560BTA Io=3850mA Io=5600mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.10 × 2.66 × 1.56 231 × 67.5 × 39.5 8.27 × 2.66 × 1.56 210 × 67.5 × 39.5 - Notes 1200 g - Note: All specifications are typical at 25C unless otherwise stated. 4 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C Dimming Specifications Parameter Min. Typ. Max. DA, DA High Level 9.5 V 16 V 22.5 V DA, DA Low Level -6.5 V 0V 6.5 V DA, DA Current 0 mA - 2 mA Dimming Output Range EUD-200S105BTA EUD-200S210BTA EUD-200S350BTA EUD-200S560BTA 10%Ioset - Ioset EUD-200S105BTA EUD-200S210BTA EUD-200S350BTA EUD-200S560BTA 70 mA 140 mA 245 mA 385 mA - Ioset Notes 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA Note: All specifications are typical at 25 C unless stated otherwise. Standards Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment 5 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C Standards Compliance (Continued) DALI Standards DALI Notes IEC62386-101,102 & part of 207 (3) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore lineto-earth surge protection and secure the end cap. (3) Optional Commands Implemented: 242 (query short circuit), 243 (query open circuit) Lifetime vs. Case Temperature Inrush Current Waveform 6 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C Efficiency vs. Load EUD-200S105BTA(Io=700mA) EUD-200S105BTA(Io=1050mA) EUD-200S210BTA(Io=1400mA) EUD-200S210BTA(Io=2100mA) EUD-200S350BTA(Io=2450mA) EUD-200S350BTA(Io=3500mA) 7 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C EUD-200S560BTA(Io=3850mA) EUD-200S560BTA(Io=5600mA) Power Factor Total Harmonic Distortion 8 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA 200W Programmable IP67 Driver with DALI Rev. C Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset ≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  DALI Dimming The recommended implementation of the dimming control is provided below. Implementation: DALI Dimming 9 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-200SxxxBTA   200W Programmable IP67 Driver with DALI Rev. C Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-200S105BTA 价格&库存
很抱歉,暂时无法提供与“EUD-200S105BTA”相匹配的价格&库存,您可以联系我们找货
