EUG-150S210DV
EUG-150S210DV
    INVENTRONICS(英飞特)
EUG-150S210DV 数据手册
EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Features • Ultra High Efficiency (Up to 93.5%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6kV line-line, 10kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) • SELV Output • Suitable for Independent Use • 7 Years Warranty Description The EUG-150SxxxDV series is a 150W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, tunnel and roadway lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Default Current Output Range (1) Current 45-700mA 450-700mA 530 mA 70-1050mA 700-1050mA 700 mA 140-2100mA 1400-2100mA 1400 mA 245-3500mA 2450-3500mA 3150 mA 385-5600mA 3850-5600mA 4200 mA Input Voltage Range(2) 90~305 Vac 100~250 Vdc 90~305 Vac 100~250 Vdc 90~305 Vac 100~250 Vdc 90~305 Vac 100~250 Vdc 90~305 Vac 100~250 Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (4) 117~333Vdc 150 W 93.5% 0.99 0.96 EUG-150S070DV 75~214Vdc 150 W 93.5% 0.99 0.96 EUG-150S105DV 38~107Vdc 150 W 92.5% 0.99 0.96 EUG-150S210DV 22 ~ 61Vdc 150 W 92.0% 0.99 0.96 EUG-150S350DV 14 ~ 39Vdc 150 W 92.0% 0.99 0.96 EUG-150S560DV(5) (5) (5) Notes: (1) Output current range with constant power at 150W (2) Certified Voltage range: 100-240Vac or 100-250Vdc (except CCC, PSE, KS and BIS). (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to KS, except EUG-150S070DV (5) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F I-V Operation Area EUG-150S070DV EUG-150S105DV EUG-150S210DV EUG-150S350DV EUG-150S560DV 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 1.87 A Measured at full load and 100 Vac input. - - 0.81 A Measured at full load and 220 Vac input. - - 1.98 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 45 mA 70 mA 140 mA 245 mA 385 mA - 700 mA 1050 mA 2100 mA 3500 mA 5600 mA 450 mA 700 mA 1400 mA 2450 mA 3850 mA - 700 mA 1050 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-150S070DV EUG-150S105DV EUG-150S210DV EUG-150S350DV EUG-150S560DV - - 370 V 235 V 120 V 75 V 48 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% 100-250Vdc IEC60598-1; 240Vac/ 60 Hz Input AC Current At 220Vac input, 25 ℃ cold start, 2 Inrush Current(I t) PF 2 duration=712 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (90-150 W) At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150 W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUG-150S070DV EUG-150S105DV EUG-150S210DV EUG-150S350DV EUG-150S560DV Output Current Setting Range with Constant Power EUG-150S070DV EUG-150S105DV EUG-150S210DV EUG-150S350DV EUG-150S560DV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes At full load condition At full load condition, 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUG-150S070DV Io= 450 mA Io= 700 mA EUG-150S105DV Io= 700 mA Io=1050 mA EUG-150S210DV Io=1400 mA Io=2100 mA EUG-150S350DV Io=2450 mA Io=3500 mA EUG-150S560DV Io=3850 mA Io=5600 mA Efficiency at 220 Vac input: EUG-150S070DV Io= 450 mA Io= 700 mA EUG-150S105DV Io= 700 mA Io=1050 mA EUG-150S210DV Io=1400 mA Io=2100 mA EUG-150S350DV Io=2450 mA Io=3500 mA EUG-150S560DV Io=3850 mA Io=5600 mA Min. Typ. Max. 87.5% 87.0% 90.5% 90.0% - 88.0% 87.0% 91.0% 90.0% - 87.0% 87.0% 90.0% 90.0% - 87.0% 86.5% 90.0% 89.5% - 86.5% 85.0% 89.5% 88.0% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.5% 93.5% 92.5% - 90.5% 90.0% 92.5% 92.0% - 90.0% 90.0% 92.0% 92.0% - 90.0% 88.5% 92.0% 90.5% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F General Specifications (Continued) Parameter Min. Typ. Max. 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 90.5% 92.5% 92.5% - 90.0% 88.5% 92.0% 90.5% - MTBF - 271,000 Hours - Lifetime - 99,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Storage Temperature -40°C - +85°C Efficiency at 277 Vac input: EUG-150S070DV Io= 450 mA Io= 700 mA EUG-150S105DV Io= 700 mA Io=1050 mA EUG-150S210DV Io=1400 mA Io=2100 mA EUG-150S350DV Io=2450 mA Io=3500 mA EUG-150S560DV Io=3850 mA Io=5600 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight - 7.40 × 2.66 × 1.56 188 × 67.5 × 39.7 1100 g Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220 Vac input, 80%Load and 25 °C ambient temperature (MIL-HDBK217F) Measured at 220 Vac input, 80%Load and 70 °C case temperature; See lifetime vs. Tc curve for the details Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Humidity: 5%RH to 100%RH With mounting ear 8.23 × 2.66 × 1.56 209 × 67.5 × 39.7 - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Dimming Output Range Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA EUG-150S070DV EUG-150S105DV EUG-150S210DV EUG-150S350DV EUG-150S560DV 10%Ioset - Ioset EUG-150S070DV EUG-150S105DV EUG-150S210DV EUG-150S350DV EUG-150S560DV 45 mA 70 mA 140 mA 245 mA 385 mA - Ioset Notes Vdim(+) = 0 V 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2450 mA ≤ Ioset ≤ 3500 mA 3850 mA ≤ Ioset ≤ 5600 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 245 mA ≤ Ioset < 2450 mA 385 mA ≤ Ioset < 3850 mA 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Dimming Specifications (Continued) Parameter Min. Typ. Max. Notes 0V - 5V Dimming mode set to 0-5V in PC interface. 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Recommended Dimming Range for 0-5V Recommended Dimming Range for 0-10V PWM_in Duty Cycle Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25°C unless otherwise stated. Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUG-150S070DV(Io=450mA) EUG-150S070DV(Io=700mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F EUG-150S105DV(Io=700mA) EUG-150S105DV(Io=1050mA) EUG-150S210DV(Io=1400mA) EUG-150S210DV(Io=2100mA) EUG-150S350DV(Io=2450mA) EUG-150S350DV(Io=3500mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F EUG-150S560DV(Io=3850mA) EUG-150S560DV(Io=5600mA) Power Factor Total Harmonic Distortion 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV  150W Programmable IP67 Driver Rev.F 0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.  Time Dimming Set the timing curve by pulling the sliders. 12 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Programming Connection Diagram Note: The driver does not need to be powered on during the programming process.  Please refer to PRG-MUL2 (Programmer) datasheet for details. Mechanical Outline INPUT(VDE H05RN-F 3*1.0mm2 7.2) DIMMING WIRE(VDE 3*0.5mm2 6.3) AC/L(BROWN) AC/N(BLUE) GND (YELLOW/GREEN) V+(BROWN) V-(BLUE) Tc BLACK/WHITE PURPLE GRAY OUTPUT(VDE H05RN-F 2*1.0mm2 6.8) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 13 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-150SxxxDV 150W Programmable IP67 Driver Rev.F Revision History Description of Change Change Date Rev. 2015-08-07 A 2016-01-12 B 2016-04-07 2017-08-01 2017-10-26 2018-01-31 Item C D E F From To Datasheets Release / / TUV、KS、BIS / Added EUG-150S070DV / Added Input Specifications Input AC Current Updated General Specifications With mounting ear Added General Specifications Net Weight Added Safety &EMC Compliance / Updated Mechanical Outline / Updated Input Specifications PF/THD Updated Output Specifications Temperature Coefficient of Ioset Updated General Specifications Dimensions Updated Safety &EMC Compliance / Updated Mechanical Outline / Updated Features 7 Years Warranty Added Operating Case Temperature for / Warranty Tc_w Updated Description / Updated General Specifications Lifetime Updated General Specifications Operating Case Temperature for Warranty Tc_w Updated Lifetime vs. Case Temperature / Updated 14 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-150S210DV 价格&库存
很抱歉,暂时无法提供与“EUG-150S210DV”相匹配的价格&库存,您可以联系我们找货
