EUP-320S670SV
EUP-320S670SV
    INVENTRONICS(英飞特)
EUP-320S670SV 数据手册
EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Features  Ultra High Efficiency (Up to 93.5%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Dip-switch  Non-dimming Control   Input Surge Protection: DM 6kV, CM 10kV All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  5 Years Warranty Descriptio The EUP-320SxxxSV series is a 320W, constant-current, AOC IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, aquaculture and sports, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305 Vac/ 127~250 Vdc 90~305 Vac/ 2100 mA 127~250 Vdc 90~305 Vac/ 2750 mA 127~250 Vdc 90~305 Vac/ 4200 mA 127~250 Vdc 90~305 Vac/ 6700 mA 127~250 Vdc Power Max. Typical Factor Output Efficiency Power (3) 120Vac 220Vac Output Voltage Range Model Number 850-1500mA 1050-1500mA 1400 mA 107~305Vdc 320 W 93.5% 0.99 0.96 EUP-320S150SV 1100-2200mA 1500-2200mA 73~213Vdc 320 W 93.5% 0.99 0.96 EUP-320S220SV 50~139Vdc 320 W 92.5% 0.99 0.96 EUP-320S320SV 35~100Vdc 320 W 92.5% 0.99 0.96 EUP-320S460SV 24 ~ 68Vdc 320 W 92.5% 0.99 0.96 EUP-320S670SV 1700-3200mA 2300-3200mA 2400-4600mA 3200-4600mA 3700-6700mA 4700-6700mA (4) (4) Notes: (1) Output current range with constant power at 320W. (2) Certified input voltage range: 100-240Vac or 127-250Vdc (except CCC). (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 3.20 A - - 1.70 A - - 1.30 A2s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 850 mA 1100 mA 1700 mA 2400 mA 3700 mA - 1500 mA 2200 mA 3200 mA 4600 mA 6700 mA 1050 mA 1500 mA 2300 mA 3200 mA 4700 mA - 1500 mA 2200 mA 3200 mA 4600 mA 6700 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUP-320S150SV EUP-320S220SV EUP-320S320SV EUP-320S460SV EUP-320S670SV - - 350 V 250 V 170 V 120 V 85 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Input AC Current 2 Inrush Current(I t) PF Notes 127~250 Vdc IEC60598-1; 240Vac/ 60Hz Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25C cold start, duration=3.92 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100%Load (192-320W) At 220-240Vac, 50-60Hz, 75%-100% Load (240-320W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUP-320S150SV EUP-320S220SV EUP-320S320SV EUP-320S460SV EUP-320S670SV Output Current Setting Range with Constant Power EUP-320S150SV EUP-320S220SV EUP-320S320SV EUP-320S460SV EUP-320S670SV Total Output Current Ripple (pk-pk) Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/C - Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUP-320S150SV Io=1050mA Io=1500mA EUP-320S220SV Io=1500mA Io=2200mA EUP-320S320SV Io=2300mA Io=3200mA EUP-320S460SV Io=3200mA Io=4600mA EUP-320S670SV Io=4700mA Io=6700mA Efficiency at 220 Vac input: EUP-320S150SV Io=1050mA Io=1500mA EUP-320S220SV Io=1500mA Io=2200mA EUP-320S320SV Io=2300mA Io=3200mA EUP-320S460SV Io=3200mA Io=4600mA EUP-320S670SV Io=4700mA Io=6700mA Min. Typ. Max. 89.50% 89.00% 91.50% 91.00% - 89.00% 89.00% 91.00% 91.00% - 88.00% 88.00% 90.00% 90.00% - 88.50% 88.00% 90.50% 90.00% - 88.00% 87.00% 90.00% 89.00% - 91.50% 91.50% 93.50% 93.50% - 91.50% 91.50% 93.50% 93.50% - 90.50% 90.00% 92.50% 92.00% - 90.50% 90.00% 92.50% 92.00% - 90.50% 89.50% 92.50% 91.50% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 92.00% 91.50% 94.00% 93.50% - 92.00% 91.50% 94.00% 93.50% - 90.50% 90.50% 92.50% 92.50% - 90.50% 90.50% 92.50% 92.50% - 91.00% 90.00% 93.00% 92.00% - MTBF - 303,000 Hours - Lifetime - 78,000 Hours - -40°C - +85°C -40°C - +75C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUP-320S150SV Io=1050mA Io=1500mA EUP-320S220SV Io=1500mA Io=2200mA EUP-320S320SV Io=2300mA Io=3200mA EUP-320S460SV Io=3200mA Io=4600mA EUP-320S670SV Io=4700mA Io=6700mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.89 × 3.15 × 1.66 251 × 80 × 42 8.82 × 3.15 × 1.66 224 × 80 × 42 Net Weight - Notes 1550 g - Note: All specifications are typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category Standard ENEC & TUV & CE EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 CB CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 EAC ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUP-320S150SV(lo=1050mA) EUP-320S150SV(lo=1500mA) 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B EUP-320S220SV(lo=1540mA) EUP-320S220SV(lo=2200mA) EUP-320S320SV(lo=2240mA) EUP-320S320SV(lo=3200mA) EUP-320S460SV(lo=3220mA) EUP-320S460SV(lo=4600mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B EUP-320S670SV(lo=4690mA) EUP-320S670SV(lo=6700mA) Power Factor Total Harmonic Distortion 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Output Current vs. Dip Switch Setting  EUP-320S150SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1500mA 107V 213V ON ON ON OFF 1450mA 111V 221V ON ON OFF ON 1400mA 115V 229V ON ON OFF OFF 1350mA 119V 237V ON OFF ON ON 1300mA 123V 246V ON OFF ON OFF 1250mA 128V 256V ON OFF OFF ON 1200mA 134V 267V ON OFF OFF OFF 1150mA 139V 278V OFF ON ON ON 1100mA 146V 291V OFF ON ON OFF 1050mA 153V 305V OFF ON OFF ON 1000mA 160V 305V OFF ON OFF OFF 950mA 169V 305V OFF OFF ON ON 900mA 178V 305V OFF OFF ON OFF 850mA 189V 305V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV  320W AOC IP67 Driver Rev. B EUP-320S220SV Output Current Setting(Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2200mA 73V 145V ON ON ON OFF 2100mA 76V 152V ON ON OFF ON 2000mA 80V 160V ON ON OFF OFF 1900mA 84V 168V ON OFF ON ON 1800mA 89V 178V ON OFF ON OFF 1700mA 94V 188V ON OFF OFF ON 1600mA 100V 200V ON OFF OFF OFF 1500mA 107V 213V OFF ON ON ON 1400mA 115V 213V OFF ON ON OFF 1300mA 123V 213V OFF ON OFF ON 1200mA 134V 213V OFF ON OFF OFF 1100mA 146V 213V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. EUP-320S320SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 3200mA 50V 100V ON ON ON OFF 3050mA 53V 105V ON ON OFF ON 2900mA 55V 110V ON ON OFF OFF 2750mA 58V 116V ON OFF ON ON 2600mA 62V 123V ON OFF ON OFF 2450mA 66V 131V ON OFF OFF ON 2300mA 70V 139V ON OFF OFF OFF 2150mA 75V 139V OFF ON ON ON 2000mA 80V 139V OFF ON ON OFF 1850mA 87V 139V OFF ON OFF ON 1700mA 94V 139V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 10 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV  320W AOC IP67 Driver Rev. B EUP-320S460SV Output Current Setting(Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 4600mA 35V 69.5V ON ON ON OFF 4400mA 37V 72.5V ON ON OFF ON 4200mA 38V 76V ON ON OFF OFF 4000mA 40V 80V ON OFF ON ON 3800mA 42V 84V ON OFF ON OFF 3600mA 45V 89V ON OFF OFF ON 3400mA 47V 94V ON OFF OFF OFF 3200mA 50V 100V OFF ON ON ON 3000mA 54V 100V OFF ON ON OFF 2800mA 57V 100V OFF ON OFF ON 2600mA 62V 100V OFF ON OFF OFF 2400mA 67V 100V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. EUP-320S670SV Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 6700mA 24V 48V ON ON ON OFF 6450mA 25V 49.5V ON ON OFF ON 6200mA 26V 51.5V ON ON OFF OFF 5950mA 27V 54V ON OFF ON ON 5700mA 28V 56V ON OFF ON OFF 5450mA 30V 58.5V ON OFF OFF ON 5200mA 31V 61.5V ON OFF OFF OFF 4950mA 33V 64.5V OFF ON ON ON 4700mA 34V 68V OFF ON ON OFF 4450mA 36V 68V OFF ON OFF ON 4200mA 38V 68V OFF ON OFF OFF 3950mA 41V 68V OFF OFF ON ON 3700mA 44V 68V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 11 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Notes: 1. Dip switch must be set in the setting range as specified to insure the driver operates as expected. 2. Endcap covering dip switch must be tight to insure IP67 rating. Mechanical Outline INPUT(VDE H05RN-F 3*1mm2 7.2 ) AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN ) OUTPUT(VDE H05RN-F 2*1mm2 6.8 ) Tc V+ (BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 12 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-320SxxxSV 320W AOC IP67 Driver Rev. B Revision History Description of Change Change Date Rev. 2019-02-12 A 2019-11-19 Item B From To Datasheets Release / / KCC Logo / Added EAC Logo / Added Global Mark Logo / Added Independent Logo / Added Features 6kV line-line, 10kV line-earth DM 6kV, CM 10kV Features Waterproof (IP67) Features Suitable for Independent Use Deleted Safety &EMC Compliance CB Added Safety &EMC Compliance EAC Added Safety &EMC Compliance Global Mark IP67 Added (1) (1) Safety &EMC Compliance EN 55015/GB 17743 Safety &EMC Compliance EN 61000-4-5 Updated RoHS Compliance / Updated EN 55015/GB 17743/KN 15 13 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUP-320S670SV 价格&库存
很抱歉,暂时无法提供与“EUP-320S670SV”相匹配的价格&库存,您可以联系我们找货
