EUR-160S420DT
EUR-160S420DT
    INVENTRONICS(英飞特)
EUR-160S420DT 数据手册
EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Features • Inventronics Patented Metal Case (Patent NO.: 202030323060.3) • Full Power at Wide Output Current Range (Constant Power) • Adjustable Output Current (AOC) with Potentiometer (Sx models) Adjustable Output Current (AOC) with Programmability (Dx models) • • 1-10V/10V PWM/3-Timer-Modes Dimmable (Only Dx models) • Dim-to-Low-Voltage (DTLV) with Standby Power ≤ 0.5W (Function Selectable) • Input Surge Protection: DM 6kV, CM 6kV • All-Around Protection: OVP, SCP, OTP • IP65 and UL Dry / Damp / Wet Location • SELV Output • TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location • 5 Year Warranty Description The EUR-160SxxxDx(Sx) series is a 160W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including bay, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current Input Voltage Range(2) Output Voltage Range Typical Max. Typical Power Factor Model Number Output Efficiency (4)(5) Power (3) 120Vac 220Vac 90~305 Vac/ 34~ 54Vdc 160 W 127~300 Vdc 90~305 Vac/ 3000-4200mA 3000-4200mA 3300mA 34~ 54Vdc 160 W 127~300 Vdc 300-4200mA 3000-4200mA 3300mA 91.5% 0.99 0.96 EUR-160S420Dx 91.5% 0.99 0.96 EUR-160S420Sx Notes: (1) Output current range with constant power at 160W. (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A I-V Operation Area EUR-160S420Dx EUR-160S420Sx Input Specifications Parameter Min. Typ. Max. Notes Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/60Hz - - 0.70 mA IEC60598-1; 240Vac/60Hz - - 1.70 A - - 0.90 A - - 3.90 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. Output Current Tolerance -5%Ioset - 5%Ioset Output Current Setting(Ioset) Range EUR-160S420Dx EUR-160S420Sx 300 mA 3000 mA - 4200mA 4200mA 300 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25°C cold start, duration=252 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac,50-60Hz, 60%-100% load (96-160W) At 220-240Vac,50-60Hz, 60%-100% load (96-160W) Output Specifications Parameter Notes At 100% load condition 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Output Specifications (Continued) Parameter Min. Typ. Max. Output Current Setting Range with Constant Power EUR-160S420Dx EUR-160S420Sx Total Output Current Ripple (pk-pk) 3000 mA 3000 mA - 4200mA 4200mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUR-160S420Dx/Sx - - 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/°C - Min. Typ. Max. Notes At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 100-277Vac input, 60%-100% load Case temperature = 0°C~Tc max General Specifications Parameter Efficiency at 120 Vac input: EUR-160S420Dx/Sx Io=3000 mA Io=4200 mA Efficiency at 220 Vac input: EUR-160S420Dx/Sx Io=3000 mA Io=4200 mA Efficiency at 277 Vac input: EUR-160S420Dx/Sx Io=3000 mA Io=4200 mA Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70°C case temperature; See lifetime vs. Tc curve for the details 87.5% 87.0% 89.5% 89.0% - 89.5% 89.0% 91.5% 91.0% - 90.0% 89.5% 92.0% 91.5% - MTBF - 317,000 Hours - Lifetime - 98,000 Hours - -40°C - +90°C -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5% RH to 95% RH; Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions ∅ 5.12 x 2.44 ∅ 130 x 62 Inches (∅ × H) Millimeters (∅ × H) Net Weight - 1000 g - 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Dimming Specifications Parameter Min. Typ. Max. Notes Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA 10%Ioset - Ioset 3000 mA ≤ Ioset ≤ 4200 mA 300 mA - Ioset 300 mA ≤ Ioset < 3000 mA 0V - 10 V DTLV Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V Hysteresis - 0.2 V - PWM_in High Level - 10 V - PWM_in Low Level - 0V - 200 Hz - 2 KHz PWM_in Duty Cycle 0% - 100% PWM DTLV 3% 5% 8% PWM Dimming on 5% 7% 10% - 2% - Vdim(+) = 0 V Dimming Output Range Recommended Dimming Input Range PWM_in Frequency Range Hysteresis Defult is without DTLV and need to set DTLV function in PC interface Safety & EMC Compliance Safety Category Standard UL/CUL UL8750,CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 NOM NOM-058-SCFI KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Safety & EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment ANSI Standards ANSI C82.77-5 Notes 6kV combi-wave surge rating to comply with ANSI C82.77-5 CAT low Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Lifetime vs. Case Temperature Inrush Current Waveform 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Efficiency vs. Load EUR-160S420Dx(Sx)(Io=3000mA) EUR-160S420Dx(Sx)(Io=4200mA) Power Factor Total Harmonic Distortion 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx) 160W AOC Driver for High Bay Rev. A Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Dimming  1-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 1-10V voltage source signal or passive components like zener.  10V PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Note: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUR-160SxxxDx(Sx)  160W AOC Driver for High Bay Rev. A Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUR-160S420DT 价格&库存
很抱歉,暂时无法提供与“EUR-160S420DT”相匹配的价格&库存,您可以联系我们找货
EUR-160S420DT
