EUV-150S024STA
EUV-150S024STA
    INVENTRONICS(英飞特)
EUV-150S024STA 数据手册
EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Features  High Efficiency (Up to 90.5%)  Isolated 0-10V Dimmable (DTA models) Non-Dimmable (STA models)  Deep Dimming down to 0.1%  Constant Voltage PWM Output Frequency up to 1.5kHz  Dim-to-Off with Standby Power ≤ 0.5 W  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OCP, OVP, SCP, OTP  IP67 and UL Dry / Damp / Wet Location  LVLE and SELV Output  UL Class P Type  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The EUV-150SxxxDTA(STA) series is a 150W, constant-voltage IP67 LED driver that operates from 90-305 Vac input with excellent power factor. It was created for many lighting applications including LED strip, architectural, decorative and signage, etc. The high efficiency of the driver and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, over temperature, and short circuit. Models Typical Power Factor Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 12 V 90~305 Vac 127~250 Vdc 0 ~ 12.5 A 150 W 90.0% 0.99 0.96 EUV-150S012DTA(STA) 24 V 90~305 Vac 127~250 Vdc 0 ~ 6.25 A 150 W 90.5% 0.99 0.96 EUV-150S024DTA(STA)(4) Model Number (3) Notes: (1) Certified input voltage range: UL, FCC 100-277Vac or 127-250Vdc; otherwise 100-240Vac or 127-250Vdc (except KS). (2) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (3) SELV output. (4) LVLE output. Input Specifications Parameter Min. Typ. Max. Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 250 Vdc Input Frequency 47 Hz - 63 Hz 1 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 0.75 MIU UL8750; 277Vac/60Hz - - 0.70 mA IEC60598-1; 240Vac/60Hz - - 1.6 A Measured at 100% load and 120Vac input. - - 0.9 A Measured at 100% load and 220Vac input. - - 2.56 A2s 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% load (112.5-150W) Min. Typ. Max. Notes -2.5%Vo - 2.5%Vo At 100% load condition - 12.5 V 24.2 V - At 100% load condition Leakage Current Input AC Current Inrush Current(I2t) PF At 220Vac input, 25C cold start, duration=760 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% load (105-150W) Output Specifications Parameter Output Voltage Tolerance Output Voltage EUV-150S012DTA(STA) EUV-150S024DTA(STA) Total Output Voltage Ripple (pk-pk) - - 2%Vo Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Startup Overshoot Voltage - - 5%Vo At 100% load condition Line Regulation - - ±0.5% Measured at 100% load Load Regulation - - ±1.5% - - 1.0 s Measured at 120Vac input, 70%-100%load - - 0.5 s Measured at 220Vac input, 70%-100%load - 15 ms - Output Deviation - - 5%VO Settling Time - - 10ms - 0.03%/C - Turn-on Delay Time Hold up Time Load Dynamic Response Temperature Coefficient of Vo 2 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Measured at 220Vac input, 100%load R/S: 1A/μs Load: 25% ~ 75% load Case temperature = 0C~Tc max All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C General Specifications Parameter Min. Typ. Max. Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Efficiency at 120 Vac input: EUV-150S012DTA(STA) EUV-150S024DTA(STA) 85.5% 85.5% 87.5% 87.5% - Efficiency at 220Vac input: EUV-150S012DTA(STA) EUV-150S024DTA(STA) 88.0% 88.5% 90.0% 90.5% - Efficiency at 277Vac input: EUV-150S012DTA(STA) EUV-150S024DTA(STA) 88.5% 88.5% 90.5% 90.5% - Standby Power - - 0.5 W MTBF - 258,000 Hours - Lifetime - 89,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 5 years warranty Humidity: 10%RH to 95%RH Storage Temperature -40°C - +85°C Humidity: 5%RH to 95%RH Net Weight 7.08 x 2.66 x 1.44 180 x 67.5 x 36.5 - 950 g Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.91 x 2.66 x 1.44 201 x 67.5 x 36.5 Dimensions Inches (L × W × H) Millimeters ((L × W × H) Measured at 230Vac/50Hz; Dimming off - Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 135 μA 150 μA 165 μA 0.1% - 100% 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - Dimming Output Range Recommended Dimming Input Range Hysteresis 3 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA)  150W Constant Voltage IP67 Driver Rev.C Dimming Principle for PWM Style Output Parameter Output PWM frequency Output DC current Min. Typ. Max. Notes - 0 Hz - Vdim(+) =9.0-10.0 V - 1.5 kHz - Vdim(+) =1.4-9.0 V 300 Hz - 1.5 kHz Vdim(+) = 1.0-1.4 V ON Duty cycle(%) = T ON T 100 % OFF Io = 0A TON T Note: Dimming is achieved by varying the duty cycle of the output current when driving LED strips. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN 61347-2-13 KS KS C 7655 EMI Standards EN 55015(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT 4 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Lifetime vs. Case Temperature 5 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Inrush Current Waveform Efficiency vs. Load EUV-150S012DTA(STA) EUV-150S024DTA(STA) Power Factor 6 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+ L Vac N Inventronics LED Driver V- Dim+ G Dim- Dimmer Implementation 1: DC Input 7 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Resister Dimming V+ L Vac N Inventronics LED Driver G VDim+ Rx Dim- Implementation 2: External Resistor Mechanical Outline EUV-150S012DTA INPUT (UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL21996 2*22AWG 5.0) Tc V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) PURPLE PINK OUTPUT (UL SJTW 2*14AWG 8.8) PROJ: Unspecified tolerance:±1 8 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C EUV-150S024DTA INPUT (UL SJTW 3*18AWG 7.8) DIMMING WIRE(UL21996 2*22AWG 5.0) Tc PURPLE PINK V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) OUTPUT (UL SJTW 2*18AWG 7.3) PROJ: Unspecified tolerance:±1 EUV-150S012STA INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*14AWG 7.8) 8.8) Tc V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) PROJ: Unspecified tolerance:±1 9 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C EUV-150S024STA INPUT (UL SJTW 3*18AWG OUTPUT (UL SJTW 2*18AWG 7.8) 7.3) Tc V+ (RED) V- (BLUE) AC/L (BLACK) AC/N (WHITE) GND (GREEN) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 10 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUV-150SxxxDTA(STA) 150W Constant Voltage IP67 Driver Rev.C Revision History Change Date Rev. 2018-02-05 A 2018-03-09 B 2022-02-18 Description of Change Item From To Datasheet Release / / Features / Updated Note of Dimming Specifications - Dimming Output / Range Deleted Product Photograph / Updated Features / Updated Description / Updated General Specifications Humidity Updated Safety &EMC Compliance / Updated Dimming / Updated Mechanical Outline EUV-150SxxxDTA Updated RoHS Compliance / Updated C 11 / 11 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
EUV-150S024STA
PDF文档的物料型号为:BQ25895RGTR 器件简介:BQ25895是一款高度集成的五段1A开关模式电池充电管理IC,用于单节锂离子或锂聚合物电池。
引脚分配: 1. EN1/EN2:使能引脚 2. STAT:状态引脚 3. PWM:脉冲宽度调制输出 4. SW:开关输出 5. VBAT:电池电压输入 6. VSYS:系统电压输入 参数特性:包括充电电流、充电电压、输入电压、效率、工作温度范围等。
功能详解:具备微处理器接口、可编程充电参数、热调节、输入电流限制、充电终止、电池温度监测等功能。
应用信息:适用于便携式电子设备,如智能手机、平板电脑、移动电源等。
封装信息:采用4mm x 4mm 20引脚QFN封装。
EUV-150S024STA 价格&库存
很抱歉,暂时无法提供与“EUV-150S024STA”相匹配的价格&库存,您可以联系我们找货
EUV-150S024STA
