EUV-300S024SV
EUV-300S024SV
    INVENTRONICS(英飞特)
EUV-300S024SV 数据手册
EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N Features  High Efficiency (Up to 93.0%)  Constant Voltage Output  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OVP, OCP, SCP, OTP  Waterproof (IP67)  SELV Output  Suitable for Independent Use Description The EUV-300SxxxSV series is a 300W, constant-voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Efficiency (2) 110Vac 220Vac 12 Vdc 90 ~ 305 Vac 0~22.9 A 275 W 91.5% 0.99 0.93 EUV-300S012SV 24 Vdc 90 ~ 305 Vac 0~12.5 A 300 W 91.0% 0.99 0.96 EUV-300S024SV 28 Vdc 90 ~ 305 Vac 0~10.71 A 300 W 91.5% 0.99 0.96 EUV-300S028SV 36 Vdc 90 ~ 305 Vac 0~8.33 A 300 W 92.0% 0.99 0.96 EUV-300S036SV 42 Vdc 90 ~ 305 Vac 0~7.14 A 300 W 92.0% 0.99 0.96 EUV-300S042SV 48 Vdc 90 ~ 305 Vac 0~6.25 A 300 W 92.5% 0.99 0.96 EUV-300S048SV 54 Vdc 90 ~ 305 Vac 0~5.56 A 300 W 93.0% 0.99 0.96 EUV-300S054SV Power Factor Model Number (3)(4)(5) Notes: (1) Certified input voltage range: 100-240Vac; (2) Measured at 100% load and 220 Vac input. (3) All the models are certificated to Global-mark, except EUV-300S012SV. (4) All the models are certificated to CCC, except EUV-300S012SV and EUV-300S054SV (5) SELV output Input Specifications Parameter Min. Typ. Max. Notes Input Voltage Range 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.75 mA At 240Vac/60Hz input , grounding effectively - - 3.6 A Measured at 100% load and 100 Vac input. - - 1.6 A Measured at 100% load and 220 Vac input. Input AC Current 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N Input Specifications (Continued) Parameter Min. Typ. Max. - - 2.33 A s 0.90 - - - - 20% Min. Typ. Max. Output Voltage Tolerance -5% - 5% Ripple and Noise (pk-pk) - - 2% VO Output Overshoot / Undershoot - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±3% - 0.4 s 1.0 s Measured at 110Vac input, 75%-100%load - 0.4 s 1.0 s Measured at 220Vac input, 75%-100%load Output Deviation - - 5% VO Settling Time - - 10 mS - - 0.02%/C 2 Inrush Current(I t) Power Factor THD 2 Notes At 220Vac input, 25℃ cold start, duration=3 ms, 10%Ipk-10%Ipk. At 100-240Vac, 50-60Hz,75%-100%load (225-300W) Output Specifications Parameter Notes At 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature coefficient R/S: 1 A / uS Load: 25% ~ 75%100% load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Min. Typ. Max. 89.0% 88.5% 89.0% 89.5% 90.5% 90.5% 91.0% 89.5% 89.0% 89.5% 90.0% 91.0% 91.0% 91.5% - 91.0% 90.5% 91.0% 91.5% 91.5% 92.0% 92.5% 91.5% 91.0% 91.5% 92.0% 92.0% 92.5% 93.0% - No Load Power Dissipation - - 4.5 W MTBF - 278,000 hours - Efficiency at 110 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 28 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.5% lower if measured immediately after startup.) Measured at 110Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N General Specifications (Continued) Parameter Min. Typ. Max. - 58,000 hours - -40 C - +90 C -40 C - +60 C -40 C - +85 C Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes Measured at 220Vac input, 80%Load ,Case temperature=60℃ @ Tc point. See life time vs. Tc curve for the details Humidity: 5% RH to 100% RH With mounting ear 9.88 × 3.86 × 1.75 251 × 98 × 44.5 8.82 × 3.86 × 1.75 224 × 98 × 44.5 Net Weight - 1700 g - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 CCC GB 19510.1, GB 19510.14 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N Derating Curve EUV-300S012SV Others Lifetime vs. Case Temperature Curve Protection Functions Parameter Over Current Protection Min. Typ. Max. Notes 130% IO 165% IO 200% IO Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N Mechanical Outline EUV-300S012SV DC OUTPUT (VDE H05RN-F 2*1.0mm2) AC INPUT (VDE H05RN-F 3*1.0mm2) BROWN (V+) BLUE (V-) BROWN(ACN) BLUE(ACL) YELLOW/GREEN (GND) PROJ: Unspecified tolerance:±1 Note: The 3 DC output cables are connected in parallel internally because one 1.0mm2 wire can only carry 10A. Please connect the 3 brown wires together and 3 blue wires together in application, or ensure each cable carries same current. EUV-300S024/036/042SV DC OUTPUT (VDE H05RN-F 2*1.0mm2) AC INPUT (VDE H05RN-F 3*1.0mm2) BROWN (V+) BLUE (V-) BROWN(ACL) BLUE (ACN) YELLOW /GREEN (GND) PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one 1.0mm2 wire can only carry 10A. Please connect the 2 brown wires together and 2 blue wires together in application, or ensure each cable carries same current. 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N EUV-300S028SV AC INPUT (VDE H05RN-F 3*1.0mm2) DC OUTPUT (VDE H05RR-F 2*1.5mm2) BROWN (V+) BLUE(V-) BROWN(ACN) BLUE (ACL) YELLOW/GREEN (GND) PROJ: Unspecified tolerance:±1 EUV-300S048/054SV AC INPUT (VDE H05RN-F 3*1.0mm2) DC OUTPUT (VDE H05RN-F 2*1.0mm2) BROWN (V+) BLUE (V-) BROWN(ACL) BLUE (ACN) YELLOW /GREEN (GND) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N Revision History Description of Change Change Date Rev. 2010-09-15 A 2011-07-20 B 2012-02-20 2012-3-27 2012-5-04 2012-7-17 2012-8-14 2013-01-05 Item C D From To First Release. MTBF Delete 24V Add 28V Life Use Tcase data to replace the old test condition Efficiency of 24V,28V,36V / Notes of Life time Measured at 220Vac input, Case temperature=80C 80%Load and 45C ambient temperature Efficiency of 28V / 0.5% Higher Mechanical Outline / Updated Life time Curve / added Life time & MTBF / Corrected Max Case Temperature / Updated Deleted 42V Model & Added 54VModel / Updated Efficiency of 48V Model / 0.5% Lower Input AC Current @100Vac 3.3 A 3.5 A MTBF 250,000Hrs 200,000Hours Life Time 100,000Hrs @ Tc70C 50,000Hrs @ Tc65C Min Operating Temperature/ Derating Curve -35C -40C Inrush current 50A 150A Min PF and max THD / Added Temperature Coefficient / Added MTBF Min 250,000 hours Typ.278,000 hours Life time Min 50,000 hours Typ.58,000 hours Life time curve / Updated Input AC Current @100Vac Max3.5 A Typ3.3A, Max3.5A 2% Lower E F G H 2013-02-26 I Efficiency of 48V, 54V / 0.5%lower 2013-03-11 J Over Current Protection 110%,155%,180% 130%,165%,200% 2013-12-13 K Turn-on delay time 0.1s,0.2s 0.4s,1.0s Derating curve / Updated 2014-09-26 L Derating curve of EUV-300S012SV / Added 2014-09-26 L Mechanical outline of EUV-200S012SV / Updated 2015-09-11 M Format / Updated 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-300SxxxSV 300W Constant Voltage IP67 Driver  Rev. N Revision History (Continued) Change Date 2015-09-11 2019-03-01 Description of Change Rev. Item M From To External Grounding Screw Solution / / Features / Updated Description / Updated Models EUV-300S042SV Added General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature for Warranty Tc_w Added General Specifications Storage Temperature Added Environmental Specifications / Delete Safety & EMC Compliance / Update Protection Functions / Update Mechanical Outline / Update Header Outdoor IP67 Global Mark / Updated CCC / Added Description / Updated Input Specifications Power Factor/ THD Added General Specifications With mounting ear Added General Specifications - Net Weight 1540g 1700g N Safety & EMC Compliance Updated 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-300S024SV
物料型号包括EUV-300S012SV、EUV-300S024SV、EUV-300S028SV、EUV-300S036SV、EUV-300S042SV、EUV-300S048SV和EUV-300S054SV,它们支持不同的输出电压和电流范围,最大输出功率为300W。
器件简介为一款高效率、多功能保护且适合独立使用的LED驱动器。
引脚分配方面,不同型号有不同规格的DC输出和AC输入,部分型号的输出电缆内部是并联连接的。
参数特性包括输入电压范围90Vac至305Vac,效率高达93.0%,功率因数高达0.99,并且具备全面的安全保护功能。
功能详解涉及产品高效率、防水、适合独立使用及全面的保护功能。
应用信息指出产品适用于多种照明应用,如高杆灯、高杆、体育场和道路照明等。
封装信息提供详细的尺寸和重量信息,以及符合RoHS标准的认证。
EUV-300S024SV 价格&库存
很抱歉,暂时无法提供与“EUV-300S024SV”相匹配的价格&库存,您可以联系我们找货
EUV-300S024SV
