ESD-600S280DV
ESD-600S280DV
    INVENTRONICS(英飞特)
    Driver
ESD-600S280DV 数据手册
ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Features  Ultra High Efficiency (Up to 95.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 1.5 W  Output Lumen Compensation  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The ESD-600SxxxDV series is a 600W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including high mast, sports, aquaculture and horticulture, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range 0.136-1.70A 1.36–1.70A 0.168-2.10A 1.68–2.10A 0.224-2.80A 2.24–2.80A 0.336-4.20A 3.36–4.20A 0.448-5.60A 4.48–5.60A 0.592-7.40A 5.92–7.40A 0.784-9.80A 7.84–9.80A 1.0 – 12.5 A 10 – 12.5 A Input Voltage Range(2) 249~528Vac 352~500Vdc 249~528Vac 2.1A 352~500Vdc 249~528Vac 2.8 A 352~500Vdc 249~528Vac 4.2 A 352~500Vdc 249~528Vac 5.6 A 352~500Vdc 249~528Vac 7.0 A 352~500Vdc 249~528Vac 9.8 A 352~500Vdc 249~528Vac 12.5 A 352~500Vdc 1.7A Output Voltage Range 176 ~ 441Vdc Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) Model Number 600 W 95.0% 0.96 0.95 ESD-600S170DV 143 ~ 357Vdc 600 W 95.0% 0.96 0.95 ESD-600S210DV 108 ~ 268Vdc 600 W 94.5% 0.96 0.95 ESD-600S280DV 72 ~ 178Vdc 600 W 95.0% 0.96 0.95 ESD-600S420DV 54 ~ 134Vdc 600 W 95.0% 0.96 0.95 ESD-600S560DV 41 ~ 101Vdc 600 W 94.5% 0.96 0.95 ESD-600S740DV 31 ~ 76Vdc 600 W 94.0% 0.96 0.95 ESD-600S980DV 24 ~ 60Vdc 600 W 94.0% 0.96 0.95 ESD-600S12ADV (4) (4) (4) Notes: (1) Output current range with constant power at 600W. (2) Certified voltage range: 277-480Vac or 352-500Vdc. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV output. 1 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E I-V Operating Area ESD-600S170DV ESD-600S210DV ESD-600S280DV ESD-600S420DV ESD-600S560DV ESD-600S740DV 2 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E ESD-600S980DV ESD-600S12ADV Input Specifications Parameter Min. Typ. Max. 249 Vac - 528 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 2.50 A - - 1.45 A Input Voltage Notes 325-500Vdc IEC60598-1; 480Vac/ 60Hz, Grounding effectively Measured at 100% load and 277 Vac input. Input AC Current Measured at 100% load and 480 Vac input. At 480Vac input, 25℃ cold start, 2 Inrush Current(I t) 2 - - 20.4 A s 0.90 - - - - 20% Min. Typ. Max. Output Current Tolerance -5%Ioset - 5%Ioset Output Current Setting(Ioset) Range ESD-600S170DV ESD-600S210DV ESD-600S280DV ESD-600S420DV ESD-600S560DV ESD-600S740DV ESD-600S980DV ESD-600S12ADV 136 mA 168 mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA PF THD duration=869 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100% Load (360 - 600W) Output Specifications Parameter Notes 100% load 3 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Output Specifications (Continued) Parameter Min. Typ. Max. 1360 mA 1680 mA 2240 mA 3360 mA 4480 mA 5920 mA 7840 mA 10000 mA - 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage ESD-600S170DV ESD-600S210DV ESD-600S280DV ESD-600S420DV ESD-600S560DV ESD-600S740DV ESD-600S980DV ESD-600S12ADV - - 480 V 390 V 290 V 198 V 153 V 110 V 85 V 70 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - - 0.75 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Output Current Setting Range with Constant Power ESD-600S170DV ESD-600S210DV ESD-600S280DV ESD-600S420DV ESD-600S560DV ESD-600S740DV ESD-600S980DV ESD-600S12ADV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes 100% load, 20 MHz BW 100% load Measured at 277-480Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. 4 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E General Specifications Parameter Efficiency at 277 Vac input: ESD-600S170DV Io= 1360 mA Io= 1700 mA ESD-600S210DV Io= 1680 mA Io= 2100 mA ESD-600S280DV Io= 2240 mA Io= 2800 mA ESD-600S420DV Io= 3360 mA Io= 4200 mA ESD-600S560DV Io= 4480 mA Io= 5600 mA ESD-600S740DV Io= 5920 mA Io= 7400 mA ESD-600S980DV Io= 7840 mA Io= 9800 mA ESD-600S12ADV Io= 10000 mA Io= 12500 mA Efficiency at 347 Vac input: ESD-600S170DV Io= 1360 mA Io= 1700 mA ESD-600S210DV Io= 1680 mA Io= 2100 mA ESD-600S280DV Io= 2240 mA Io= 2800 mA ESD-600S420DV Io= 3360 mA Io= 4200 mA ESD-600S560DV Io= 4480 mA Io= 5600 mA ESD-600S740DV Io= 5920 mA Io= 7400 mA ESD-600S980DV Io= 7840 mA Io= 9800 mA ESD-600S12ADV Io= 10000 mA Io= 12500 mA Min. Typ. Max. 92.0% 92.0% 94.0% 94.0% - 92.0% 91.5% 94.0% 93.5% - 91.5% 91.0% 93.5% 93.0% - 92.0% 91.5% 94.0% 93.5% - 92.0% 91.5% 94.0% 93.5% - 91.5% 90.5% 93.5% 92.5% - 90.5% 89.5% 92.5% 91.5% - 91.0% 90.0% 93.0% 92.0% - 92.5% 92.5% 94.5% 94.5% - 93.0% 92.0% 95.0% 94.0% - 92.0% 91.5% 94.0% 93.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.0% 94.0% 93.0% - 91.0% 90.5% 93.0% 92.5% - 91.5% 90.5% 93.5% 92.5% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 5 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E General Specifications (Continued) Parameter Efficiency at 480 Vac input: ESD-600S170DV Io= 1360 mA Io= 1700 mA ESD-600S210DV Io= 1680 mA Io= 2100 mA ESD-600S280DV Io= 2240 mA Io= 2800 mA ESD-600S420DV Io= 3360 mA Io= 4200 mA ESD-600S560DV Io= 4480 mA Io= 5600 mA ESD-600S740DV Io= 5920 mA Io= 7400 mA ESD-600S980DV Io= 7840 mA Io= 9800 mA ESD-600S12ADV Io= 10000 mA Io= 12500 mA Standby power Min. Typ. Max. 93.0% 93.0% 95.0% 95.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 93.0% 92.5% 95.0% 94.5% - 93.0% 92.5% 95.0% 94.5% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.0% 94.0% 93.0% - 92.0% 91.0% 94.0% 93.0% - - - 1.5 W Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) - 200,000 Hours - Lifetime - 101,000 Hours - -40°C - +89C -40°C - +75C -40°C - +85°C Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Case temperature for 5 years warranty Humidity: 5%RH to 100%RH With mounting ear 10.87× 5.67 × 1.91 276 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 - Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details MTBF Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Notes 3330 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA Notes Vdim(+) = 0 V 6 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Dimming Specifications (Continued) Parameter Min. ESD-600S170DV ESD-600S210DV ESD-600S280DV ESD-600S420DV ESD-600S560DV ESD-600S740DV ESD-600S980DV ESD-600S12ADV Typ. Max. 10%Ioset - Ioset 136 mA 168 mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range ESD-600S170DV ESD-600S210DV ESD-600S280DV ESD-600S420DV ESD-600S560DV ESD-600S740DV ESD-600S980DV ESD-600S12ADV Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes 1360mA ≤ Ioset ≤1700mA 1680mA ≤ Ioset ≤2100mA 2240 mA ≤ Ioset ≤ 2800 mA 3360mA ≤ Ioset ≤ 4200mA 4480mA ≤ Ioset ≤ 5600mA 5920 mA ≤ Ioset ≤ 7400 mA 7840 mA ≤ Ioset ≤ 9800 mA 10000 mA ≤ Ioset ≤ 12500 mA 136mA ≤ Ioset <1360mA 168mA ≤ Ioset <1680mA 224 mA ≤ Ioset < 2240 mA 336mA ≤ Ioset < 3360mA 448mA ≤ Ioset < 4480mA 592 mA ≤ Ioset < 5920 mA 784 mA ≤ Ioset < 7840 mA 1000 mA ≤ Ioset < 10000 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. Safety &EMC Compliance Safety Category ENEC & TUV & CE CB Standard EN 61347-1, EN61347-2-13 IEC 61347-1, IEC 61347-2-13 EMI Standards EN 55015 (1) Notes Conducted emission Test &Radiated emission Test 7 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Safety &EMC Compliance (Continued) EMI Standards Notes EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 8 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Inrush Current Waveform Efficiency vs. Load ESD-600S170DV(Io=1360mA) ESD-600S170DV(Io=1700mA) ESD-600S210DV(lo=1680mA) ESD-600S210DV(lo=2100mA) 9 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E ESD-600S280DV(lo=2240mA) ESD-600S280DV(lo=2800mA) ESD-600S420DV(lo=3600mA) ESD-600S420DV(lo=4200mA) ESD-600S560DV(lo=4480mA) ESD-600S560DV(lo=5600mA) 10 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E ESD-600S740DV(lo=5920mA) ESD-600S740DV(lo=7400mA) ESD-600S980DV(lo=7840mA) ESD-600S980DV(lo=9800mA) ESD-600S12ADV(lo=10000mA) ESD-600S12ADV(lo=12500mA) 11 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 12 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV 600W Programmable IP67 Driver Rev, E Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic Implementation 3: Negative logic 13 / 17 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESD-600SxxxDV   600W Programmable IP67 Driver Rev, E Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-600S280DV 价格&库存
很抱歉,暂时无法提供与“ESD-600S280DV”相匹配的价格&库存,您可以联系我们找货
