ESM-240S105LT
ESM-240S105LT
    INVENTRONICS(英飞特)
ESM-240S105LT 数据手册
ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Features   Full Power at Wide Output Current Range (Constant Power) Adjustable Output Current (AOC) with NFC   Isolated 0-10V/PWM/3-Timer-Modes Dimmable INV Digital Dimming, UART Based Communication Protocol Compliant with T/CSA-051    Dim-to-Off with Standby Power Always-on Auxiliary Power: 12Vdc,250mA,3W (Transient Peak Power up to 10W) Low Inrush Current  Integrated Power Metering with High Accuracy up to ±1%  Output Lumen Compensation  End-of-Life Indicator  Thermal Sensing and Protection for LED Module  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IUVP, IOVP, OVP, SCP, OTP   IP66 / IP67 and UL Dry / Damp / Wet Location TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location 5 Years Warranty  Description The ESM-240SxxxLx series is a 240W, constant-current, NFC programmable and IP66/IP67 rated LED driver that operates from 249-528Vac input with excellent power factor. Created for smart lighting and health monitoring applications, this family provides integrated AC power monitoring with an auxiliary voltage and dimto-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol that complies with T/CSA-051. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 249~528 Vac/ 352~500 Vdc 249~528 Vac/ 105-1500mA 1050-1500mA 1050 mA 352~500 Vdc 249~528 Vac/ 215-3500mA 2150-3500mA 2150 mA 352~500 Vdc 249~528 Vac/ 420-6700mA 4200-6700mA 4900 mA 352~500 Vdc 70-1050mA 700-1050mA 700 mA Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 277Vac 480Vac Model Number (5) 115~343Vdc 240W 94.0% 0.99 0.96 ESM-240S105Lx 80~229 Vdc 240W 93.5% 0.99 0.96 ESM-240S150Lx 35~111 Vdc 240W 93.0% 0.99 0.96 ESM-240S350Lx (4) 18 ~ 57 Vdc 240W 92.5% 0.99 0.96 ESM-240S670Lx (4) Notes: (1) Output current range with constant power at 240W (2) Certified input voltage range: 277-480Vac. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output. (5) ) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A I-V Operation Area ESM-240S105Lx ESM-240S150Lx ESM-240S350Lx ESM-240S670Lx Input Specifications Parameter Min. Typ. Max. Input AC Voltage 249 Vac - 528 Vac Input DC Voltage 352 Vdc - 500 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz - - 0.70 mA IEC60598-1; 480Vac/ 60Hz, - - 1.10 A Measured at 100% load and 277 Vac input. - - 0.65 A Measured at 100% load and 480 Vac input. - - 2.10 A s Leakage Current Input AC Current 2 Inrush Current(I t) 2 Notes At 480Vac input, 25°C cold start, duration=520 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 215 mA 420 mA - 1050 mA 1500 mA 3500 mA 6700 mA 700 mA 1050 mA 2150 mA 4200 mA - 1050 mA 1500 mA 3500 mA 6700 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage ESM-240S105Lx ESM-240S150Lx ESM-240S350Lx ESM-240S670Lx - - 400 V 290 V 120 V 75 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA Return terminal is “Dim−“ - - 850 mA 850mA peak for a maximum duration of 1.3 ms in a 5.2 ms period during which time the average should not exceed 250mA. PF THD Notes At 277-480Vac, 50-60Hz, 60%-100% Load (144-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESM-240S105Lx ESM-240S150Lx ESM-240S350Lx ESM-240S670Lx Output Current Setting Range with Constant Power ESM-240S105Lx ESM-240S150Lx ESM-240S350Lx ESM-240S670Lx Total Output Current Ripple (pk-pk) 12V Auxiliary Output Transient Peak Current Notes At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 277-480Vac input, 60%-100% Load Case temperature = 0°C ~Tc max 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A General Specifications Parameter Min. Typ. Max. 90.5% 91.0% 92.5% 93.0% - 90.0% 90.0% 92.0% 92.0% - 90.0% 88.5% 92.0% 90.5% - 89.5% 87.5% 91.5% 89.5% - 91.5% 91.5% 93.5% 93.5% - 91.5% 91.0% 93.5% 93.0% - 91.0% 89.5% 93.0% 91.5% - 90.5% 88.5% 92.5% 90.5% - 91.5% 92.0% 93.5% 94.0% - 91.5% 91.0% 93.5% 93.0% - 91.0% 89.5% 93.0% 91.5% - 90.5% 89.0% 92.5% 91.0% - -1% - 1% Standby Power - 1.5 W - MTBF - 203,000 Hours - Lifetime - 106,000 Hours - -40°C - +90°C -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 277 Vac input: ESM-240S105Lx Io= 700 mA Io=1050 mA ESM-240S150Lx Io=1050 mA Io=1500 mA ESM-240S350Lx Io=2150 mA Io=3500 mA ESM-240S670Lx Io=4200 mA Io=6700 mA Efficiency at 400 Vac input: ESM-240S105Lx Io= 700 mA Io=1050 mA ESM-240S150Lx Io=1050 mA Io=1500 mA ESM-240S350Lx Io=2150 mA Io=3500 mA ESM-240S670Lx Io=4200 mA Io=6700 mA Efficiency at 480 Vac input: ESM-240S105Lx Io= 700 mA Io=1050 mA ESM-240S150Lx Io=1050 mA Io=1500 mA ESM-240S350Lx Io=2150 mA Io=3500 mA ESM-240S670Lx Io=4200 mA Io=6700 mA Power Metering Accuracy Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) At 100% load condition Measured at 480Vac/50Hz; Dimming off Measured at 480Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Typ. Max. With mounting ear 8.58 × 3.01 × 1.52 218 × 76.5 × 38.5 7.91 × 3.01 × 1.52 201 × 76.5 × 38.5 Net Weight Notes - 1200 g - Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin ESM-240S105Lx ESM-240S150Lx ESM-240S350Lx ESM-240S670Lx 10%Ioset - Ioset ESM-240S105Lx ESM-240S150Lx ESM-240S350Lx ESM-240S670Lx 70 mA 105 mA 215 mA 420 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 2150 mA ≤ Ioset ≤ 3500 mA 4200 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 215 mA ≤ Ioset < 2150 mA 420 mA ≤ Ioset < 4200 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL ENEC & CE Standard UL8750,CAN/CSA-C22.2 No. 250.13 EN 61347-1, EN 61347-2-13 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Safety &EMC Compliance (Continued) Safety Category CB Standard IEC 61347-1, IEC 61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Inrush Current Waveform Efficiency vs. Load ESM-240S105Lx(Io=700mA) ESM-240S105Lx(Io=1050mA) ESM-240S150Lx(Io=1050mA) ESM-240S150Lx(Io=1500mA) 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A ESM-240S350Lx(Io=2150mA) ESM-240S350Lx(Io=3500mA) ESM-240S670Lx(Io=4200mA) ESM-240S670Lx(Io=6700mA) Power Factor 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Total Harmonic Distortion Protection Functions Parameter External Thermal Protection Min. Typ. Max. R1 (Start derating) - 1.67 kΩ - R2 (Stop derating) - 1.27 kΩ - 10%Ioset 20%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 20%) Iomin 20%Ioset 100%Ioset 10%Ioset ≤ Iomin (default setting is 20%) Protection Current Floor Notes The output current starts to decrease linearly when the actual NTC resistance value is lower than R1, until R2 is reached. When the actual NTC resistance value is lower than R2, the output current will stay at the programmed Protection Current Floor. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Input Under Voltage Protection (IUVP) Input Over Voltage Protection Input Protection Voltage 220 Vac 230 Vac 240 Vac Recovery Voltage 230 Vac 240 Vac 250 Vac 550 Vac 570 Vac 590 Vac 530 Vac 550 Vac 570 Vac - - 590 Vac Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage Turn off the output when the input voltage exceeds protection voltage. Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. Turn off the output when the input voltage exceeds protection voltage. Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 8 hours with input voltage stress of 590Vac. Note: (1) The recommended NTC type is 10kΩ NTC, Murata NCP18XH103J03RB. 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A  Input Under Voltage Protection Diagram  Input Over Voltage Protection Diagram 570 Vac 550 Vac Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESM-240SxxxLx 240W NFC Driver with INV Digital Dimming Rev. A Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESM-240S105LT 价格&库存
很抱歉,暂时无法提供与“ESM-240S105LT”相匹配的价格&库存,您可以联系我们找货
ESM-240S105LT
