ESV-320S048ST
ESV-320S048ST
    INVENTRONICS(英飞特)
ESV-320S048ST 数据手册
ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Features  Ultra High Efficiency (Up to 93.5%)  Ultra High Input Voltage (249~528Vac)  Constant Voltage Output  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OCP, OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location   UL Class P & SELV Output TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified ) Location 5 Years Warranty  Description The ESV-320SxxxST series is a 320W, constant-voltage IP67 LED driver that operates from 249~528 Vac input with excellent power factor. It is created for many lighting applications including horticulture lighting, architectural, and decorative. The high efficiency of these drivers enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power Typical Efficiency (2) 277Vac 480Vac 24 Vdc 249~528Vac 352~500Vdc 0 ~ 13.4 A 320 W 92.5% 0.95 0.90 ESV-320S024ST 36 Vdc 249~528Vac 352~500Vdc 0 ~ 8.9 A 320 W 92.5% 0.95 0.90 ESV-320S036ST 48 Vdc 249~528Vac 352~500Vdc 0 ~ 6.7 A 320 W 93.0% 0.95 0.90 ESV-320S048ST 54 Vdc 249~528Vac 352~500Vdc 0 ~ 6.0 A 320 W 93.5% 0.95 0.90 ESV-320S054ST Power Factor Model Number(3) Notes: (1) Certified voltage range: 277-480Vac or 352-500Vdc. (2) Measured at 25C, 100% load and 480 Vac input. (3) SELV output. Input Specifications Parameter Input Voltage Input Frequency Min. Typ. Max. Notes 249 Vac - 528 Vac 47 Hz - 63 Hz - - 0.75 MIU - - 0.7 mA - - 1.4 A 352~500Vdc UL8750; 480Vac/60Hz Leakage Current Input AC Current IEC60598-1; 480Vac/60Hz Measured at 100% load and 277 Vac input. 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Input Specifications (Continued) Parameter Min. Typ. Max. Input AC Current - - 0.81 A 2 - - 8.93 A s 0.90 - - - - 20% Min. Typ. Max. -2.5% - 2.5% Inrush Current(I t) PF THD Notes 2 Measured at 100% load and 480 Vac input. At 480Vac input, 25C Cold Start, Duration=616μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 277-480Vac, 50-60Hz, 60%-100% load (192-320W) Output Specifications Parameter Output Voltage Tolerance Notes At 0% - 100% load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 μF ceramic capacitor and a 10 μF electrolytic capacitor. Output Voltage Ripple (pk-pk) - - 2%VO Output Voltage Overshoot /Undershoot - - 5%Vo Line Regulation - - ±0.5% Load Regulation - - ±1.0% - - 0.5 s Measured at 277Vac input, 60%-100% load - - 0.5 s Measured at 480Vac input, 60%-100% load Output Deviation - - 5%VO Settling Time - - 10 ms - 0.03%/C - Measured at 100% load Turn-on Delay Time Load Dynamic Response Temperature Coefficient R/S: 1 A/us Load: 10% ~ 100%load. Case temperature = 0C~Tc max Note: All specifications are typical at 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Efficiency at 277Vac input: ESV-320S024ST ESV-320S036ST ESV-320S048ST ESV-320S054ST 89.0% 89.5% 90.0% 90.0% 91.0% 91.5% 92.0% 92.0% - Efficiency at 347Vac input: ESV-320S024ST ESV-320S036ST ESV-320S048ST ESV-320S054ST 90.0% 90.0% 90.5% 91.0% 92.0% 92.0% 92.5% 93.0% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A General Specifications (Continued) Parameter Min. Typ. Max. Efficiency at 480Vac input: ESV-320S024ST ESV-320S036ST ESV-320S048ST ESV-320S054ST 90.5% 90.5% 91.0% 91.5% 92.5% 92.5% 93.0% 93.5% - MTBF - 230,000 Hours - Lifetime - 93,000 Hours - -40°C - +90C -40°C - +70C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40°C - +85°C Humidity: 5%RH to 100%RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) - 1815 g Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac input, 80%load and 25C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.88 × 3.86 × 1.76 251 × 98 × 44.8 8.82 × 3.86 × 1.76 224 × 98 × 44.8 Net Weight Notes - Note: All specifications are typical at 25C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13 CE EN61347-1, EN61347-2-13 EMI Standards EN 55015 (1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Notes: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Curve 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Inrush Current Waveform Efficiency vs. Load ESV-320S024ST ESV-320S036ST ESV-320S048ST ESV-320S054ST 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Power Factor Characteristics Total Harmonic Distortion Protection Functions Parameter Notes Over Current Protection Auto Recovery. The driver shall be self-recovery when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Auto Recovery. Returning to normal after over temperature is removed. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Mechanical Outline INPUT (UL STW 18AWG/3C OUTPUT (UL SJTW 14AWG/2C 9.5) 8.8) Tc AC/L (BLACK) AC/N (WHITE) GND (GREEN) V+ (RED) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ESV-320SxxxST 320W Constant Voltage IP67 Driver  Rev. A Revision History Description of Change Change Date Rev. 2018-11-30 A Item From Datasheet Release / To / 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
ESV-320S048ST 价格&库存
很抱歉,暂时无法提供与“ESV-320S048ST”相匹配的价格&库存,您可以联系我们找货
