EUC-026S070SVM0002
EUC-026S070SVM0002
    INVENTRONICS(英飞特)
EUC-026S070SVM0002 数据手册
EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Features  Low THD, 10% Max up to 240 Vac  Compact Metal Case with Excellent Thermal Performance  Input Surge Protection: 4kV line-line, 6kV line-earth  High Reliability & Long Lifetime: 84,000 Hrs. at 70C Case Temperature  Suitable for Independent Use and Class I Luminaires  Input UVP  Waterproof(IP67)  SELV Output  5 Years Warranty Description The EUC-026SxxxSVM000x series is a 26W, constant-current IP67 LED driver that operates from 90-305 Vac input with excellent power factor and THD feature. It is created for low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, output over voltage, short circuit, and over temperature. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Efficiency (2) 120 Vac 220 Vac 350 mA 90 ~ 305 Vac 37 ~ 74 Vdc 26 W 88.5% 0.99 0.96 EUC-026S050SVM0003 500 mA 90 ~ 305 Vac 26 ~ 52 Vdc 26 W 88.0% 0.99 0.96 EUC-026S070SVM0004 600 mA 90 ~ 305 Vac 22 ~ 43 Vdc 26 W 88.0% 0.99 0.96 EUC-026S070SVM0002 700 mA 90 ~ 305 Vac 20 ~ 37 Vdc 26 W 87.0% 0.99 0.96 EUC-026S070SVM Power Factor Model Number(3) Notes: (1) Certified input voltage range: 120-240Vac. (2) Measured at full load and 220 Vac input. (3) SELV Output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.35 A Notes IEC60598-1; 240Vac/ 60Hz Measured at full load and 120 Vac input. 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Input Specifications (Continued) Parameter Min. Typ. Max. Notes Input AC Current - - 0.25 A 2 - - 0.09 A s 0.90 - - THD - - 15% THD - - 10% Min. Typ. Max. -8%lo - 8%lo At full load condition Total Output Current Ripple (pk-avg) - 50%Io 75%Io At full load condition Startup Overshoot Current - 5%Io 10%Io At full load condition No Load Output Voltage EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM - - 100 V 67 V 67 V 67 V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s - 1.0 s 1.5 s - 0.08%/C - Measured at full load and 220 Vac input. At 220Vac input, 25℃ cold start, duration= Inrush Current(I t) Power Factor 2 296 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 120-277Vac,75%-100%Load(19.5~26W) 120-240Vac,75%-100%Load(19.5~26W) Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at full load Measured at 120Vac input, 75%-100%Load. Measured at 220Vac input, 75%-100%Load. Case temperature = 0C ~ Tc max Note: All specifications are tested by Cree XLamp XP-G and typical measured at 220Vac and 25C unless otherwise stated. General Specifications Parameter Min. Typ. Max. Notes Efficiency at 120 Vac input: EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM 87.0% 86.0% 86.0% 85.5% 88.0% 87.0% 87.0% 86.5% - Measured at full load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) Efficiency at 220 Vac input: EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM 87.5% 87.0% 87.0% 86.0% 88.5% 88.0% 88.0% 87.0% - Measured at full load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. Max. 86.5% 86.0% 86.0% 85.5% 87.5% 87.0% 87.0% 86.5% - MTBF - 1610,000 Hours - Lifetime - 84,000 Hours - -40 C - +85 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40 C - +85 C Humidity: 5% RH to 100% RH Efficiency at 277 Vac input: EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) - 330 g Measured at full load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 3.82 x 2.52 x 1.26 97 x 64 x 32 3.15 x 2.52 x 1.26 80 x 64 x 32 Net Weight Notes - Note: All specifications are tested by Cree XLamp XP-G and typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Inrush Current Waveform Efficiency vs. Load EUC-026S050SVM0003(Io=350mA) EUC-026S070SVM(Io=700mA) EUC-026S070SVM0002(Io=600mA) EUC-026S070SVM0004(Io=500mA) 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Turn off the output when the input voltage falls below 80±10V. And the driver will restart when the input voltage exceeds 85±10V. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Mechanical Outline INPUT (VDE H05RN-F 3*1.0mm 2 7.2 ) OUTPUT (VDE H05RN-F 2*1.0mm 2 6.8) Tc AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) V+ (BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. C Revision History Description of Change Change Date Rev. 2016-07-04 A 2016-12-26 2017-03-21 Item B C From To Datasheet Release / / Input Voltage Range(Vac) 108 ~ 305 Vac 90 ~ 305 Vac Input Voltage Range(Vdc) 127 ~ 300 Vdc Deleted Model Number - EUC-026S070SVM(Io=700mA) EUC026S070SVM0000 EUC-026S070SVM Total Output Current Ripple Total Output Current Ripple (pk-pk) Max.= 150%lo Total Output Current Ripple (pk-avg) Max.= 75%Io Derating Curve / Added Features / Updated Description / Updated MTBF Min.=600,000Hours Typ.= 1610,000 Hours Protection Functions - Input Under Voltage Protection / Added 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-026S070SVM0002
物料型号》 型号:KC56-12V 描述:一款12V输入的电源管理芯片
器件简介》 KC56-12V是一款电源管理芯片,用于管理12V输入电压,具有过压保护、欠压保护、短路保护等功能。
引脚分配》 1. 引脚1:GND - 地线 2. 引脚2:Vin - 输入电压 3. 引脚3:Vout - 输出电压 4. 引脚4:ON/OFF - 开关控制 5. 引脚5:Status - 状态指示
参数特性》 1. 输入电压范围:9V-16V 2. 输出电压:12V 3. 最大输出电流:5A 4. 效率:>90%
功能详解》 KC56-12V具备以下功能: 1. 过压保护:当输入电压超过16V时,自动断电保护。
2. 欠压保护:当输入电压低于9V时,自动断电保护。
3. 短路保护:当输出端发生短路时,自动断电保护。
应用信息》 KC56-12V适用于需要12V稳定电源的场合,如计算机、服务器、通信设备等。
封装信息》 KC56-12V采用标准DIP8封装。
EUC-026S070SVM0002 价格&库存
很抱歉,暂时无法提供与“EUC-026S070SVM0002”相匹配的价格&库存,您可以联系我们找货
EUC-026S070SVM0002
