EUC-160Q140DT
EUC-160Q140DT
    INVENTRONICS(英飞特)
    160W 14V 1400mA constant current led driver
EUC-160Q140DT 数据手册
EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Features  Ultra High Efficiency (Up to 92%)  Four Channels Output  Active Power Factor Correction (0.99 Typical)  Constant Current Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: SCP, OTP, OVP  IP67 and UL Dry / Damp / Wet Location Description The EUC-160QxxxDT(ST) series is a 160W, four-channel, constant-current LED driver that operates from 90305 Vac input with excellent power factor. It is created for many lighting applications including flood, tunnel and street, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Output Current (1) Input Voltage Range 350 mA 90 ~ 305 Vac 450 mA Output Voltage Range Max. Output Power Typical Efficiency (2) 120Vac 220Vac 57~114Vdc 160 W 92.0% 0.99 0.95 EUC-160Q035DT(ST) ) 90 ~ 305 Vac 45~90 Vdc 160 W 92.0% 0.99 0.95 EUC-160Q045DT(ST) (3)(6) 600 mA 90 ~ 305 Vac 40~70 Vdc 168 W 91.5% 0.99 0.95 EUC-160Q060DT(ST) (3)(6) 700 mA 90 ~ 305 Vac 29~57 Vdc 160 W 91.5% 0.99 0.95 EUC-160Q070DT(ST) (3)(6) 1050 mA 90 ~ 305 Vac 19~38 Vdc 160 W 90.0% 0.99 0.95 EUC-160Q105DT(ST) (4)(6) 1400 mA 90 ~ 305 Vac 14~29 Vdc 160 W 90.0% 0.99 0.95 EUC-160Q140DT(ST) (5)(6) Power Factor Model Number (3 Notes: (1) The output current is adjustable at factory from 50% to 100%. (2) Measured at 100% load and 220 Vac input. (3) Non-Class2 output (USR & CNR). (4) Class 2 output (USR), Non-Class 2 output (CNR). (5) Class 2 output (USR), Class 2 output (CNR) for Wet location. (6) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz , grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively Leakage Current 1/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Input Specifications (Continued) Parameter Min. Typ. Max. Notes - - 2.1 A Measured at 100% load and 100 Vac input. - - 0.9 A Measured at 100% load and 220 Vac input. - - 65 A - - 1.7 A s 0.90 - - - - 20% Min. Typ. Max. - 4 - -5% - 5% - - 120V 97V 77V 64V 51V 50.5V - 10% Io 15% IO - - 10% Line Regulation - - ±1% Load Regulation - - ±3% - 1.0 s 2.0 s Measured at 120Vac input, 75%load-100%load - 0.5 s 1.5 s Measured at 220Vac input, 75%load-100%load - 0.02%/C - Input AC Current Inrush current 2 Inrush Current(I t) Power Factor 2 At 220Vac input, 25℃ cold start, duration=1 ms, 10%Ipk-10%Ipk. At 100Vac-277Vac, 50-60Hz, 75%-100%load THD Output Specifications Parameter Output channels Output Current Tolerance No-load Output Voltage Io= 350 mA Io= 450 mA Io= 600 mA Io= 700 mA Io=1050 mA Io=1400 mA Output Current Ripple (pk-pk) Output Overshoot / Undershoot Notes Hiccup mode. When power on or off. Turn-on Delay Time Temperature coefficient Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. Protection Functions Parameter Over Temperature Protection Short Circuit Protection Min. Typ. Max. Notes When OTP occurs, the output current decreases down to the half of the normal output current. The output shall be auto recovery when case temperature becomes normal. Single or dual channel short does not affect the normal work of other channels. The driver recovers after short is removed and AC input recycled. Three or four channel short latches the driver and it recovers after the short is removed. - 120 C - 2/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N General Specifications Parameter Min. Typ. Max. Io =350 mA Io =450 mA Io =600 mA Io =700 mA Io=1050 mA Io=1400 mA 88.0% 88.0% 87.5% 87.5% 86.0% 86.0% 89.0% 89.0% 88.5% 88.5% 87.0% 87.0% - Measured at 100% load, 120Vac input, 25℃ ambient temperature, after the unit is thermally stabilized. It will be about 1.5% lower, if measured immediately after startup. Io= 350 mA Io= 450 mA Io= 600 mA Io= 700 mA Io=1050 mA Io=1400 mA 91.0% 91.0% 90.5% 90.5% 89.0% 89.0% 92.0% 92.0% 91.5% 91.5% 90.0% 90.0% 306,000 Hours - Measured at 100% load, 220Vac input, 25℃ ambient temperature, after the unit is thermally stabilized. It will be about 1.5% lower, if measured immediately after startup. Efficiency Notes Efficiency Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%Load; Case temperature=60℃ @ Tc point. See lifetime vs. Tc curve for the details MTBF - Lifetime - 94,800 Hours - -40°C - +90 ℃ -40°C - +70 ℃ -40°C - +85 ℃ Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight - With mounting ear 8.35 × 3.46 × 1.50 212 × 88 × 38 7.40 × 3.46 × 1.50 188 × 88 × 38 - 1340 g Humidity: 5% RH to 100% RH - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, UL 1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. 3/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 15 kV air discharge, 8 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Curve Efficiency vs. Load EUC-160Q035DT(ST) EUC-160Q045DT(ST) 4/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N EUC-160Q060DT(ST) EUC-160Q070DT(ST) EUC-160Q105DT(ST) EUC-160Q140DT(ST) Power Factor Characteristics 5/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Total Harmonic Distortion Dimming Control (On secondary side) Parameter Min. Typ. Max. Notes 12V output voltage (Vc) 10.8 V 12 V 13.2 V 12V Output source current 0 mA - 20 mA Absolute maximum voltage on the 1~10V input pin 0V - 12 V Source current on 1~10V input pin 0 μA - 200 μA The dimmer control may be operated from either a potentiometer or from an input signal of 1 – 10 Vdc. Two recommended implementations are provided below. Implementation: DC input Notes: 1. Io is actual output current and Ir is rated current without dimming control. 2. For the driver to operate properly, the load voltage must be maintained above the minimum voltage threshold (approx. 50% of the max. output voltage for any given model). 3. If the output voltage is maintained above 50% of the maximum output voltage, the dimming control may be operated over the entire 1-10V range with output current varying from 10% to 100% of Ir. 4. The dimming signal is allowed to be less than 1V, however, when it for 0-1V, the output current is 10%Io. 5. Do not connect the GND of dimming to the output; otherwise, the LED driver cannot work normally. 6. If 0-10V dimming is not used, Dim + can be either open or connected to Vaux. 6/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Mechanical Outline EUC-160QxxxDT INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL SJTW 2*18AWG 7.3) AC/L (BLACK) AC/N (WHITE) GND (GREEN) V+ (RED) V- (BLUE) Tc GRAY PULPLE BLACK/WHITE DIMMING WIRE (UL21996 3*22AWG 5.0) PROJ: Unspecified tolerance:±1 EUC-160QxxxST OUTPUT (UL SJTW 2*18AWG 7.3) INPUT (UL SJTW 3*18AWG 7.8) AC/L (BLACK) AC/N (WHITE) GND (GREEN) V+ (RED) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Revision History Description of Change Change Date Rev. 2012-3-6 A 2012-05-02 2012-5-14 2012-05-22 Item From To Datasheets Release / / 450 mA Model / Added 1400 mA Model / Added Output Power---600mA Updated 160W 168W No Load Output Voltage / Updated Class 2 Corrected / / Efficiency, PF Curve / Corrected Operating Temperature -35℃ -40℃ Max of No Load Voltage Added / / Output Current Ripple (pk-pk) Max 30% Io 15% Io Inrush Current 50 A 65 A B C D 2012-07-09 E Derating Curve / Updated 2012-07-17 F Max Case Temperature / Updated Derating Curve / Updated Life time Curve / Updated Turn-on delay time @120Vac Type 1.0s, max 3.0s Type 1.0s, max 2.0s Turn-on delay time @220Vac Type 1.0s, max 3.0s Type 0.5s, max 1.5s PF Min / Added / Added Inrush Current(I t) / Added Temperature co-efficient / Added Over Temperature Protection-Tc 115 C 120 C Wet location of models corrected / / Other models of efficiency curve except 350mA / Added THD Curve / Added Mechanical Outline / Updated Life time 90,400hrs@60C 94,800hrs@60C Life time curve / Updated MTBF 200,400hrs@60C 306,000hrs@60C 2012-09-05 G THD Max 2 2012-11-07 2013-03-14 2013-05-21 H I J 8/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-160QxxxDT(ST) 160W Four-channel Constant Current IP67 Driver  Rev. N Revision History (Continued) Description of Change Change Date Rev. 2013-10-10 K 2017-10-25 2019-09-09 2019-12-31 Item L From No-load Output Voltage / Updated KS / Added Features / Updated Description / Updated Models Notes Updated Input Specifications Power Factor/THD Updated Output Specifications Turn-on Delay Time Updated Output Specifications Temperature Coefficient Updated Output Specifications No-load Output Voltage Updated General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature Added for Warranty Tc_w General Specifications Storage Temperature Added General Specifications With mounting ear Added Environmental Specifications / Deleted Safety &EMC Compliance / Added Mechanical Outline / Updated Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof(IP67) IP67 Description Application environment Updated Safety &EMC Compliance UL/CUL Updated Safety &EMC Compliance KS Added Safety &EMC Compliance EN 61000-4-5 Updated Safety &EMC Compliance Note Added RoHS Compliance / Updated Derating Curve / Deleted M N To 9/9 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-160Q140DT 价格&库存
很抱歉,暂时无法提供与“EUC-160Q140DT”相匹配的价格&库存,您可以联系我们找货
