EUD-240S670DTL
EUD-240S670DTL
    INVENTRONICS(英飞特)
EUD-240S670DTL 数据手册
` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B Features  Innovative Design with No Electrolytic Capacitors  Ultra Long Lifetime: Greater than 100,000 hrs at 85C Case Temperature  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/Timer Dimmable (3 Timer Modes )  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation  Input Surge Protection: 6kV line-line, 10kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  10 Years Warranty Description The EUD-240SxxxDTL series is a novel 240W design that has removed the use of Electrolytic capacitors to extend lifetime at elevated temperatures. It is a constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, sports and roadway, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature of both the driver and the external LED array. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) 90~305Vac 127~300Vdc 90~305Vac 140-2100mA 1400-2100mA 1400 mA 127~300Vdc 90~305Vac 280-4200mA 2800-4200mA 4200 mA 127~300Vdc 90~305Vac 445-6700mA 4450-6700mA 6700 mA 127~300Vdc 70-1050mA 700-1050mA 1050 mA Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number (5) 114~343Vdc 240W 93.5% 0.98 0.96 EUD-240S105DTL 57~171Vdc 240W 93.5% 0.98 0.96 EUD-240S210DTL 29 ~ 86Vdc 240W 92.5% 0.98 0.96 EUD-240S420DTL 18 ~ 54Vdc 240W 92.5% 0.98 0.96 EUD-240S670DTL (4) (4) Notes: (1) Output current range with constant power at 240W (2) UL, FCC certified input voltage range: 100-277Vac or 127-300Vdc; otherwise: 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100%load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) All the models are certificated to KS,except EUD-240S105DTL 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B I-V Operating Area EUD-240S105DTL EUD-240S210DTL EUD-240S420DTL EUD-240S670DTL Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 2.85 A Measured at 100%load and 100 Vac input. - - 1.22 A Measured at 100%load and 220 Vac input. - - 1.72 A s 127~300 Vdc Leakage Current Input AC Current 2 Inrush Current(I t) 2 At 220Vac input, 25C Cold Start, Duration=128 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (180-240W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 140 mA 280 mA 445 mA - 1050 mA 2100 mA 4200 mA 6700 mA 700 mA 1400 mA 2800 mA 4450 mA - 1050 mA 2100 mA 4200 mA 6700 mA - 8%Iomax 15%Iomax - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUD-240S105DTL EUD-240S210DTL EUD-240S420DTL EUD-240S670DTL - - 360 V 190 V 96 V 61 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA PF Notes At 100-277Vac, 50-60Hz, 70%-100% Load (168-240W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUD-240S105DTL EUD-240S210DTL EUD-240S420DTL EUD-240S670DTL Output Current Setting Range with Constant Power EUD-240S105DTL EUD-240S210DTL EUD-240S420DTL EUD-240S670DTL Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 100%load, 20 MHz BW 100%load. Only this component of ripple is associated with visible flicker. Turn-on Delay Time Temperature Coefficient of Ioset 100%load 100%load Measured at 100%load Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B General Specifications Parameter Min. Typ. Max. 89.0% 88.0% 91.0% 90.0% - 89.0% 88.0% 91.0% 90.0% - 88.0% 86.0% 90.0% 88.0% - 88.5% 86.5% 90.5% 88.5% - 91.5% 90.5% 93.5% 92.5% - 91.5% 90.0% 93.5% 92.0% - 90.5% 88.5% 92.5% 90.5% - 90.5% 88.5% 92.5% 90.5% - 92.0% 91.0% 94.0% 93.0% - 92.0% 90.5% 94.0% 92.5% - 90.5% 88.5% 92.5% 90.5% - 91.0% 89.0% 93.0% 91.0% - Standby power - - 0.5 W MTBF - 256,000 Hours - Lifetime - 100,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 10 years warranty. Please see Inventronics EUD-DTL Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 120 Vac input: EUD-240S105DTL Io= 700 mA Io= 1050 mA EUD-240S210DTL Io= 1400 mA Io= 2100 mA EUD-240S420DTL Io= 2800 mA Io= 4200 mA EUD-240S670DTL Io= 4450 mA Io= 6700 mA Efficiency at 220 Vac input: EUD-240S105DTL Io= 700 mA Io= 1050 mA EUD-240S210DTL Io= 1400 mA Io= 2100 mA EUD-240S420DTL Io= 2800 mA Io= 4200 mA EUD-240S670DTL Io= 4450 mA Io= 6700 mA Efficiency at 277 Vac input: EUD-240S105DTL Io= 700 mA Io= 1050 mA EUD-240S210DTL Io= 1400 mA Io= 2100 mA EUD-240S420DTL Io= 2800 mA Io= 4200 mA EUD-240S670DTL Io= 4450 mA Io= 6700 mA Notes Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100%load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 85C case temperature; See lifetime vs. Tc curve for the details 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B General Specifications (Continued) Parameter Min. Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Typ. Max. With mounting ear 9.68 × 2.66 × 1.56 246 × 67.5 × 39.7 8.86 × 2.66 × 1.56 225 × 67.5 × 39.7 - Notes 1300 g - Note: All specifications are typical at 25C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+) Pin Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA EUD-240S105DTL EUD-240S210DTL EUD-240S420DTL EUD-240S670DTL 10%Ioset - Ioset EUD-240S105DTL EUD-240S210DTL EUD-240S420DTL EUD-240S670DTL 70 mA 140 mA 280 mA 445 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz PWM_in Duty Cycle 1% - 99% PWM Dimming off (Positive Logic) 2% 5% 8% PWM Dimming on (Positive Logic) 4% 7% 10% 92% 95% 98% 90% 93% 96% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1400 mA ≤ Ioset ≤ 2100 mA 2800 mA ≤ Ioset ≤ 4200 mA 4450 mA ≤ Ioset ≤ 6700 mA 70 mA ≤ Ioset < 700 mA 140 mA ≤ Ioset < 1400 mA 280 mA ≤ Ioset < 2800 mA 445 mA ≤ Ioset < 4450 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25C unless otherwise stated. 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B Safety & EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge(ESD): 8kV air discharge, 4kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient/Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6kV, line to earth 10kV EN 61000-4-6 Conducted Radio Frequency Disturbances test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment (2) Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2)To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUD-240S105DTL(Io=700mA) EUD-240S105DTL(Io=1050mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL Rev. B 240W Programmable Driver with Ultra Long Lifetime EUD-240S210DTL(Io=1400mA) EUD-240S210DTL(Io=2100mA) EUD-240S420DTL(Io=2800mA) EUD-240S420DTL(Io=4200mA) EUD-240S670DTL(Io=4450mA) EUD-240S670DTL(Io=6700mA) 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. R2 - 4.16 kOhm - When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. V+(RED) L V-(BLU) Vac N Inventronics LED Driver OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) G 0 (1)-10V Dimmer Dim-(GRY) Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 2: Positive logic 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com ` EUD-240SxxxDTL 240W Programmable Driver with Ultra Long Lifetime Rev. B V+(RED) L V-(BLU) Vac N Inventronics LED Driver G OTP+(PINK) OTP-(BLU/WHT) Vaux(BLK/WHT) Dim+(PUR) Dim-(GRY) PWM Signal Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-240S670DTL 价格&库存
很抱歉,暂时无法提供与“EUD-240S670DTL”相匹配的价格&库存,您可以联系我们找货
EUD-240S670DTL
