EUD-600S12ADV
EUD-600S12ADV
    INVENTRONICS(英飞特)
    600W Programmable IP67 Driver
EUD-600S12ADV 数据手册
EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Features  Ultra High Efficiency (Up to 95.0%)  Full Power at Wide Output Current Range (Constant Power)  Thermal Sensing and Protection for LED Module  0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 200mA  Output Lumen Compensation   Input Surge Protection: DM 6kV, CM 10kV All-Around Protection: OVP, SCP, OTP  IP67  SELV Output  7 Years Warranty Description The EUD-600SxxxDV series is a 600W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high bay, high mast, aquaculture and sports, etc, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range 0.11–1.40A 1.10–1.40A 1.4 A 0.136-1.70A 1.36–1.70A 1.7A 0.168–2.10A 1.68–2.10A 2.1A 0.224-2.80A 2.24–2.80A 2.8 A 0.336-4.20A 3.36–4.20A 4.2 A 0.448-5.60A 4.48–5.60A 5.6 A 0.592-7.40A 5.92–7.40A 7.0 A 0.784-9.80A 7.84–9.80A 9.8 A 1.0 – 12.5 A 10 – 12.5 A 12.5 A Input Voltage Range(2) 90~305Vac/ 127~250Vdc 90~305Vac/ 127~300Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc 90~305Vac/ 127~250Vdc Output Voltage Range Max. Typical Power Factor Output Efficiency 120Vac 220Vac Power (3) Model Number (4)(5)(7) 214 ~ 545Vdc 600 W 95.0% 0.99 0.96 EUD-600S140DV 176 ~ 441Vdc 600 W 94.0% 0.96 0.95 EUD-600S170DV 143 ~ 357Vdc 600 W 94.5% 0.99 0.96 EUD-600S210DV 108 ~ 268Vdc 600 W 95.0% 0.99 0.96 EUD-600S280DV 72 ~ 178Vdc 600 W 94.5% 0.99 0.96 EUD-600S420DV 54 ~ 134Vdc 600 W 94.5% 0.99 0.96 EUD-600S560DV 41 ~ 101Vdc 600 W 94.0% 0.99 0.96 EUD-600S740DV 31 ~ 76Vdc 600 W 94.0% 0.99 0.96 EUD-600S980DV 24 ~ 60Vdc 600 W 94.0% 0.99 0.96 EUD-600S12ADV (6) (6) (6) Notes: (1) Output current range with constant power at 600W. (2) Certified input voltage range: 100-240Vac or 127-250Vdc (except CCC, PSE, BIS and KCC). (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) All the models are certificated to BIS and PSE, except EUD-600S140/170/210/12ADV. 1 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G (5) All the models are certificated to EAC except EUD-600S280/420/560/740/980DV. (6) SELV Output. (7) For BIS models add suffix -3000. I-V Operating Area EUD-600S140DV EUD-600S170DV EUD-600S210DV EUD-600S280DV 330 (10%Ioset,600/Ioset) 220 oa d (2800,214) (Ioset,600/Ioset) ad Lo % 60 Output Voltage(V) (2240,268) 10 0% L (1344,268) 275 (224,268) 165 (2800,129) 110 (280,108) 55 (Ioset,108) (2800,108) Good Performance Area Allowed Operating Area Programmed Operating Area 550 2200 0 0 1100 1650 2750 3300 Output Current (mA) Note: 2240mA EUD-600S420DV Ioset 2800mA EUD-600S560DV 2 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G EUD-600S740DV EUD-600S980DV EUD-600S12ADV 60 % a Lo d Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 6.0 A Measured at 100% load and 120 Vac input. - - 3.5 A Measured at 100% load and 220 Vac input. - - 4.70 A s 0.90 - - THD - - 20% THD - - 10% 127-250Vdc IEC60598-1; 240Vac/ 60Hz, grounding effectively Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25℃ cold start, duration=7.64 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-240Vac, 50-60Hz, 60%-100% Load (360 - 600W) At 220-240Vac, 50-60Hz, 75%-100% Load (450 - 600W) 3 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 110 mA 136 mA 168mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - 1400 mA 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA 1100 mA 1360 mA 1680 mA 2240 mA 3360 mA 4480 mA 5920 mA 7840 mA 10000 mA - 1400 mA 1700 mA 2100 mA 2800 mA 4200 mA 5600 mA 7400 mA 9800 mA 12500 mA - 5%Iomax 10%Iomax - 2%Iomax - 100% load. Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUD-600S140DV EUD-600S170DV EUD-600S210DV EUD-600S280DV EUD-600S420DV EUD-600S560DV EUD-600S740DV EUD-600S980DV EUD-600S12ADV - 600 V 475 V 410 V 290 V 190 V 150 V 118 V 87 V 70 V 605V 480 V 415 V 295 V 200 V 155 V 120 V 95 V 80 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% - - 1.0 s - - 0.5 s - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA Output Current Tolerance Output Current Setting(Ioset) Range EUD-600S140DV EUD-600S170DV EUD-600S210DV EUD-600S280DV EUD-600S420DV EUD-600S560DV EUD-600S740DV EUD-600S980DV EUD-600S12ADV Output Current Setting Range with Constant Power EUD-600S140DV EUD-600S170DV EUD-600S210DV EUD-600S280DV EUD-600S420DV EUD-600S560DV EUD-600S740DV EUD-600S980DV EUD-600S12ADV Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Turn-on Delay Time Temperature Coefficient of Ioset Notes 100% load 100% load, 20 MHz BW 100% load Measured at 120Vac input, 60%-100% Load Measured at 220Vac input, 60%-100% Load Case temperature = 0C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25C unless otherwise stated. 4 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G General Specifications Parameter Efficiency at 120 Vac input: EUD-600S140DV lo= 1100 mA lo= 1400 mA EUD-600S170DV Io= 1360 mA Io= 1700 mA EUD-600S210DV lo= 1680 mA lo= 2100 mA EUD-600S280DV Io= 2240 mA Io= 2800 mA EUD-600S420DV Io= 3360 mA Io= 4200 mA EUD-600S560DV Io= 4480 mA Io= 5600 mA EUD-600S740DV Io= 5920 mA Io= 7400 mA EUD-600S980DV Io= 7840 mA Io= 9800 mA EUD-600S12ADV lo= 10000 mA lo= 12500 mA Efficiency at 220 Vac input: EUD-600S140DV lo= 1100 mA lo= 1400 mA EUD-600S170DV Io= 1360 mA Io= 1700 mA EUD-600S210DV lo= 1680 mA lo= 2100 mA EUD-600S280DV Io= 2240 mA Io= 2800 mA EUD-600S420DV Io= 3360 mA Io= 4200 mA EUD-600S560DV Io= 4480 mA Io= 5600 mA EUD-600S740DV Io= 5920 mA Io= 7400 mA EUD-600S980DV Io= 7840 mA Io= 9800 mA EUD-600S12ADV lo= 10000 mA lo= 12500 mA Min. Typ. Max. 90.5% 90.0% 92.5% 92.0% - 90.0% 89.5% 92.0% 91.5% - 90.0% 89.5% 92.0% 91.5% - 91.0% 90.0% 93.0% 92.0% - 90.5% 89.5% 92.5% 91.5% - 90.0% 89.5% 92.0% 91.5% - 89.5% 89.0% 91.5% 91.0% - 90.0% 89.5% 92.0% 91.5% - 89.5% 89.0% 91.5% 91.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 92.0% 94.0% 94.0% - 92.5% 92.0% 94.5% 94.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.5% 94.0% 93.5% - 92.0% 91.0% 94.0% 93.0% - 91.5% 91.0% 93.5% 93.0% - Notes Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 5 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G General Specifications (Continued) Parameter Min. Typ. Max. 93.0% 92.5% 95.0% 94.5% - 92.5% 92.0% 94.5% 94.0% - 92.5% 92.0% 94.5% 94.0% - 93.0% 92.5% 95.0% 94.5% - 93.0% 92.0% 95.0% 94.0% - 93.0% 92.5% 95.0% 94.5% - 92.5% 91.5% 94.5% 93.5% - 92.5% 91.5% 94.5% 93.5% - 92.0% 91.5% 94.0% 93.5% - Standby power - - 0.5 W MTBF - 200,000 Hours - Lifetime - 90,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +89C Operating Case Temperature for Warranty Tc_w -40°C - +75C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUD-600S140DV lo= 1100 mA lo= 1400 mA EUD-600S170DV Io= 1360 mA Io= 1700 mA EUD-600S210DV lo= 1680 mA lo= 2100 mA EUD-600S280DV Io= 2240 mA Io= 2800 mA EUD-600S420DV Io= 3360 mA Io= 4200 mA EUD-600S560DV Io= 4480 mA Io= 5600 mA EUD-600S740DV Io= 5920 mA Io= 7400 mA EUD-600S980DV Io= 7840 mA Io= 9800 mA EUD-600S12ADV lo= 10000 mA lo= 12500 mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 10.83× 5.67 × 1.91 275 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 - Notes 3515 g - Note: All specifications are typical at 25C unless otherwise stated. 6 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 μA 300 μA 450 μA EUD-600S140DV EUD-600S170DV EUD-600S210DV EUD-600S280DV EUD-600S420DV EUD-600S560DV EUD-600S740DV EUD-600S980DV EUD-600S12ADV 10%Ioset - Ioset EUD-600S140DV EUD-600S170DV EUD-600S210DV EUD-600S280DV EUD-600S420DV EUD-600S560DV EUD-600S740DV EUD-600S980DV EUD-600S12ADV 110 mA 136 mA 168 mA 224 mA 336 mA 448 mA 592 mA 784 mA 1000 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 1100 mA ≤ Ioset ≤ 1400 mA 1360 mA ≤ Ioset ≤ 1700 mA 1680 mA ≤ Ioset ≤ 2100 mA 2240 mA ≤ Ioset ≤ 2800 mA 3360 mA ≤ Ioset ≤ 4200 mA 4480 mA ≤ Ioset ≤ 5600 mA 5920 mA ≤ Ioset ≤7400 mA 7840 mA ≤ Ioset ≤ 9800 mA 10000 mA ≤ Ioset ≤ 12500 mA 110 mA ≤ Ioset < 1100 mA 136 mA ≤ Ioset < 1360 mA 168 mA ≤ Ioset <1680 mA 224 mA ≤ Ioset< 2240 mA 336 mA ≤ Ioset < 3360 mA 448 mA ≤ Ioset < 4480 mA 592 mA ≤ Ioset < 5920 mA 784 mA ≤ Ioset < 7840 mA 1000 mA ≤ Ioset < 10000 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Note: All specifications are typical at 25 C unless stated otherwise. 7 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Safety &EMC Compliance Safety Category Standard ENEC & TUV & CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KC K 61347-1, K 61347-2-13 BIS IS 15885(Part2/Sec13) EAC ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 Global Mark AS/NZS 61347.1, AS/NZS 61347.2.13 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test & Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV(2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. 8 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Derating Lifetime vs. Case Temperature Inrush Current Waveform 9 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Efficiency vs. Load EUD-600S140DV(Io=1100mA) EUD-600S140DV(Io=1400mA) EUD-600S170DV(Io=1360mA) EUD-600S170DV(Io=1700mA) EUD-600S210DV(Io=1680mA) EUD-600S210DV(Io=2100mA) 10 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G EUD-600S280DV(Io=2240mA) EUD-600S280DV(Io=2800mA) EUD-600S420DV(Io=3360mA) EUD-600S420DV(Io=4200mA) EUD-600S560DV(Io=4480mA) EUD-600S560DV(Io=5600mA) 11 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G EUD-600S740DV(Io=5920mA) EUD-600S740DV(Io=7400mA) EUD-600S980DV(Io=7840mA) EUD-600S980DV(Io=9800mA) EUD-600S12ADV(Io=10000mA) EUD-600S12ADV(Io=12500mA) 12 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Power Factor Total Harmonic Distortion Protection Functions Parameter External Thermal Protection NTC Min. Typ. Max. R1 - 7.81 kOhm - R2 - 4.16 kOhm - 10%Ioset 60%Ioset 100%Ioset 10%Ioset>Iomin (default setting is 60%) Iomin 60%Ioset 100%Ioset 10%Ioset≤Iomin (default setting is 60%) Protection Current Floor Notes When R_NTC falls below R1, External Thermal Protection is triggered, reducing output current until R2 is reached. When R_NTC is less than R2, output current is reduced to the programmed “Protection Current Floor.” Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 13 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV 600W Programmable IP67 Driver Rev. G Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming Implementation 2: Positive logic Implementation 3: Negative logic 14 / 20 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUD-600SxxxDV   600W Programmable IP67 Driver Rev. G Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUD-600S12ADV 价格&库存
很抱歉,暂时无法提供与“EUD-600S12ADV”相匹配的价格&库存,您可以联系我们找货
