EUG-075S070DT
EUG-075S070DT
    INVENTRONICS(英飞特)
EUG-075S070DT 数据手册
EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Features • High Efficiency (Up to 91.0%) • Full Power at Wide Output Current Range (Constant Power) • 0-5V/0-10V/PWM/Timer Dimmable • Input Surge Protection: 6 kV line-line, 10 kV line-earth • All-Around Protection: OVP, SCP, OTP • Waterproof (IP67) and UL Dry / Damp / Wet Location • Class 2 & SELV Output • TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location • UL Type TL (Temperature Limited) • Class P, UL Listed Versions Available (See Note 6) • 7 Years Warranty Description The EUG-075SxxxDT series is a 75W, constant-current, programmable LED driver that operates from 90-305 Vac input with excellent power factor. It is created for low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current 45-700mA 450-700mA 530 mA 70-1050mA 700-1050mA 700 mA 119-1750mA 1190-1750mA 1400 mA 140-1800mA 1400-1800mA 1400 mA 192-2800mA 1920-2800mA 2100 mA Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc Output Voltage Range Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Model Number 54~167Vdc 75 W 91.0% 0.99 0.96 EUG-075S070DT 36~107Vdc 75 W 90.5% 0.99 0.96 EUG-075S105DT (4) 22 ~ 63Vdc 75 W 90.0% 0.99 0.96 EUG-075S175DT (4) 22 ~ 54Vdc 75 W 90.0% 0.99 0.96 EUG-075S180DT (5) 14 ~ 39Vdc 75 W 89.0% 0.99 0.96 EUG-075S280DT (5) Notes: (1) Output current range with constant power at 75W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127250Vdc (except KS) (3) Measured at full load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV Output. (6) Standard part UL Type TL. For UL Listed Class P models add suffix -00C0. 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E I-V Operating Area EUG-075S070DT EUG-075S105DT EUG-075S175DT EUG-075S180DT 60 (140,54) 50 (980,54) (1400,54) (Ioset,75/Ioset) (10%Ioset,75/Ioset) 10 0% Lo a d (1800,42) % 70 ad Lo 40 (1800,30) 30 (1800,22) 20 (180,22) 10 (Ioset,22) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 350 700 1050 1400 1750 2100 Output Current (mA) Note: 1400mA Ioset 1800mA EUG-075S280DT 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz, grounding effectively - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, grounding effectively - - 1.05 A Measured at full load and 100 Vac input. - - 0.48 A Measured at full load and 220 Vac input. - - 1.3 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (56.25-75W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 45 mA 70 mA 119 mA 140 mA 192 mA - 700 mA 1050 mA 1750 mA 1800 mA 2800 mA 450 mA 700 mA 1190 mA 1400 mA 1920 mA - 700 mA 1050 mA 1750 mA 1800 mA 2800 mA - 5%Iomax 10%Iomax - 1%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUG-075S070DT EUG-075S105DT EUG-075S175DT EUG-075S180DT EUG-075S280DT - - 180 V 118 V 67 V 59 V 48 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 Notes 127~300 Vdc At 220Vac input, 25°C cold start, duration=456 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 70%-100% Load (52.5-75W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUG-075S070DT EUG-075S105DT EUG-075S175DT EUG-075S180DT EUG-075S280DT Output Current Setting Range with Constant Power EUG-075S070DT EUG-075S105DT EUG-075S175DT EUG-075S180DT EUG-075S280DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) At full load condition At full load condition. 20 MHz BW At full load condition. Only this component of ripple is associated with visible flicker. At full load condition Measured at full load 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Output Specifications (Continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 20 mA Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUG-075S070DT Io= 450mA Io= 700mA EUG-075S105DT Io= 700mA Io=1050mA EUG-075S175DT Io=1190mA Io=1750mA EUG-075S180DT Io=1400mA Io=1800mA EUG-075S280DT Io=1920mA Io=2800mA Efficiency at 220 Vac input: EUG-075S070DT Io= 450mA Io= 700mA EUG-075S105DT Io= 700mA Io=1050mA EUG-075S175DT Io=1190mA Io=1750mA EUG-075S180DT Io=1400mA Io=1800mA EUG-075S280DT Io=1920mA Io=2800mA Min. Typ. Max. 86.0% 87.0% 88.0% 89.0% - 86.0% 86.5% 88.0% 88.5% - 85.5% 86.0% 87.5% 88.0% - 85.5% 86.0% 87.5% 88.0% - 85.5% 84.5% 87.5% 86.5% - 88.5% 89.0% 90.5% 91.0% - 88.0% 88.5% 90.0% 90.5% - 87.5% 88.0% 89.5% 90.0% - 87.5% 88.0% 89.5% 90.0% - 87.5% 87.0% 89.5% 89.0% - Notes Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E General Specifications (Continued) Parameter Min. Typ. Max. 89.0% 89.0% 91.0% 91.0% - 88.0% 88.5% 90.0% 90.5% - 88.0% 88.5% 90.0% 90.5% - 88.0% 88.5% 90.0% 90.5% - 88.0% 87.0% 90.0% 89.0% - MTBF - 328,000 Hours - Lifetime - 99,000 Hours - Operating Case Temperature for Safety Tc_s -40°C - +90°C Operating Case Temperature for Warranty Tc_w -40°C - +75°C Case temperature for 7 years warranty. Please see Inventronics Warranty Statement for complete details. Operating Case Temperature for Type TL Tc_TL -40°C - +67°C Only UL Type TL models Storage Temperature -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUG-075S070DT Io= 450mA Io= 700mA EUG-075S105DT Io= 700mA Io=1050mA EUG-075S175DT Io=1190mA Io=1750mA EUG-075S180DT Io=1400mA Io=1800mA EUG-075S280DT Io=1920mA Io=2800mA Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight Measured at full load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 6.97 × 2.66 × 1.44 177 × 67.5 × 36.5 5.91 × 2.66 × 1.44 150 × 67.5 × 36.5 - 790 g Notes - Note: All specifications are typical at 25°C unless otherwise stated. Dimming Specifications Parameter Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+)Pin Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA Notes Vdim(+) = 0 V 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Dimming Specifications (Continued) Parameter Min. Typ. Max. Notes 450 mA ≤ Ioset ≤ 700 mA 700 mA ≤ Ioset ≤ 1050 mA 1190 mA ≤ Ioset ≤ 1750 mA 1400 mA ≤ Ioset ≤ 1800 mA 1920 mA ≤ Ioset ≤ 2800 mA 45 mA ≤ Ioset < 450 mA 70 mA ≤ Ioset < 700 mA 119 mA ≤ Ioset < 1190 mA 140 mA ≤ Ioset < 1400 mA 192 mA ≤ Ioset < 1920 mA EUG-075S070DT EUG-075S105DT EUG-075S175DT EUG-075S180DT EUG-075S280DT 10%Ioset - Ioset EUG-075S070DT EUG-075S105DT EUG-075S175DT EUG-075S180DT EUG-075S280DT 45 mA 70 mA 119 mA 140 mA 192 mA - Ioset Recommended Dimming Range for 0-5V 0V - 5V Dimming mode set to 0-5V in PC interface. Recommended Dimming Range for 0-10V 0V - 10 V Default 0-10V dimming mode with positive logic. PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 2 KHz 1% - 99% Dimming Output Range PWM_in Duty Cycle Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750, UL1310, CAN/CSA-C22.2 No. 250.13, CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV (2) 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Safety &EMC Compliance (Continued) EMS Standards Notes EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Inrush Current Waveform 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Efficiency vs. Load EUG-075S070DT(Io=450mA) EUG-075S070DT(Io=700mA) EUG-075S105DT(Io=700mA) EUG-075S105DT(Io=1050mA) EUG-075S175DT(Io=1190mA) EUG-075S175DT(Io=1750mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E EUG-075S180DT(Io=1400mA) EUG-075S180DT(Io=1800mA) EUG-075S280DT(Io=1920mA) EUG-075S280DT(Io=2800mA) Power Factor 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Dimming  0-5V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Implementation 2: Negative logic Notes: 1. The dimmer can also be replaced by an active 0-5V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-5V dimming is not used, Dim + should be open. 4. When 0-5V negative logic dimming mode and Dim+ is open, the driver will output maximum current.  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 3. If 0-10V dimming is not used, Dim + should be open. 4. When 0-10V negative logic dimming mode and Dim+ is open, the driver will output minimum current.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 5: Positive logic Implementation 6: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current. 12 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E  Time Dimming Set the timing curve by pulling the sliders. Programming Connection Diagram Note: The driver does not need to be powered on during the programming process. 13 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT  75W Programmable IP67 Driver Rev. E Please refer to PRG-MUL2 (Programmer) datasheet for details. Mechanical Outline INPUT (UL SJTW 3*18AWG 7.8) AC/L (BLACK) AC/N (WHITE) GND (GREEN) Dimming Wire(UL21996 3*22AWG Tc 5.0) V+ (RED) V- (BLUE) OUTPUT (UL SJTW 2*18AWG GRAY PURPLE BLACK/WHITE 7.3) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 14 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUG-075SxxxDT 75W Programmable IP67 Driver Rev. E Revision History Description of Change Change Date Rev. 2015-12-28 A 2016-04-12 2017-03-28 2017-07-26 2017-10-25 Item B C D E From To Datasheets Release / / Features / Updated General Specifications Operating Case Temperature for Type TL Tc_TL Added General Specifications Net Weight Updated General Specifications With mounting ear Added Safety &EMC Compliance / Updated Mechanical Outline / Updated EUG-075S180DT / Added I-V Operation Area EUG-075S180DT Added Output Specifications Output Current Setting(Ioset) Range Updated Output Specifications Output Current Setting Range with Constant Power Updated Output Specifications No Load Output Voltage Updated General Specifications Efficiency at 120 Vac input Updated General Specifications Efficiency at 220 Vac input Updated General Specifications Efficiency at 277 Vac input Updated Dimming Specifications Dimming Output Range Updated Safety & EMC Compliance / Updated Efficiency vs. Load EUG-075S180DT Added Mechanical Outline / Updated Input Specifications PF/THD Updated Features Class P, UL Listed Versions Available (See Note 6) Added Features 7 Years Warranty Added Models (6) Standard part UL Type TL. For UL Listed Class P models add suffix Added -00C0. Operating Case Temperature for / Warranty Tc_w Operating Case Temperature for Only UL Type TL models Type TL Tc_TL Updated Added 15 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUG-075S070DT 价格&库存
很抱歉,暂时无法提供与“EUG-075S070DT”相匹配的价格&库存,您可以联系我们找货
