EUM-100S150MT
EUM-100S150MT
    INVENTRONICS(英飞特)
EUM-100S150MT 数据手册
EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B Features  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Programmability  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  INV Digital Dimming, UART Based Communication Protocol  Dim-to-Off with Standby Power ≤ 0.5 W  Always-on Auxiliary Power: 12Vdc, 250mA, 3W (Transient Peak Power up to 10W)  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IUVP, IOVP, OVP, SCP, OTP  IP66 / IP67 and UL Dry / Damp / Wet Location  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The EUM-100SxxxMx series is a 100W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 90-305Vac input with excellent power factor. Created for smart lighting application, this family provides an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current Input Voltage Range(2) Output Voltage Range Typical Max. Typical Output Efficiency Power Factor Power (3) 120Vac 220Vac 90~305 Vac/ 48~143 Vdc 100W 127~300 Vdc 90~305 Vac/ 105-1500mA 1050-1500mA 1050 mA 34~95 Vdc 100W 127~300 Vdc 90~305 Vac/ 175-2800mA 1750-2800mA 2100 mA 17~54 Vdc 96W 127~300 Vdc 70-1050mA 700-1050mA 700 mA Model Number (6) 92.5% 0.99 0.96 EUM-100S105Mx 92.5% 0.99 0.96 EUM-100S150Mx(4) 91.0% 0.99 0.96 EUM-100S280Mx(5) Notes: (1) Output current range with constant power at 100W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) Class 2 & SELV output. (6) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models; 1 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B I-V Operation Area EUM-100S105Mx EUM-100S150Mx 114 174 (70, 143) (455 , 143 ) (700 , 143 ) (Ioset,100/Ioset) (10%Ioset,100/Ioset) 116 (1050 , 95 ) 87 (1050 , 62 ) 58 (1050, 48) (Ioset, 48) (105, 48) 29 Good Performance Area Allowed Operating Area 0 0 210 420 (105, 95) 95 Output Voltage(V) Output Voltage(V) 145 (10%Ioset,100/Ioset) 76 (1500 , 67 ) (1500 , 43 ) 38 840 1050 (1500, 34) (Ioset, 34) (150, 34) 19 Good Performance Area Allowed Operating Area 0 630 (Ioset,100/Ioset) 57 Programmed Operating Area Output Current (mA) (1050 , 95 ) (683 , 95 ) 0 1260 300 Note: 700mA≤Ioset≤1050mA 600 Programmed Operating Area 900 1200 Output Current (mA) 1500 1800 Note: 1050mA≤Ioset≤1500mA EUM-100S280Mx 66 Output Voltage(V) 55 (175, 54) (1138 , 54 ) (1750 , 54 ) (10%Ioset,100/Ioset) 44 (Ioset,100/Ioset) (2800 , 36 ) 33 (2800 , 23 ) 22 (Ioset, 17) (280, 17) 11 Good Performance Area Allowed Operating Area 0 0 560 1120 (2800, 17) Programmed Operating Area 1680 2240 Output Current (mA) 2800 3360 Note: 1750mA≤Ioset≤2800mA Input Specifications Parameter Min. Typ. Max. Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 1.02 A - - 0.54 A Leakage Current Input AC Current Inrush Current(I2t) - 3.45 A2s - 2 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25C cold start, duration=314 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B Input Specifications (Continued) Parameter Min. Typ. Max. 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% load (75-100W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 70 mA 105 mA 175 mA - 1050 mA 1500 mA 2800 mA 700 mA 1050 mA 1750 mA - 1050 mA 1500 mA 2800 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUM-100S105Mx EUM-100S150Mx EUM-100S280Mx - - 170 V 120 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA PF Notes At 100-277Vac, 50-60Hz, 65%-100% load (65-100W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUM-100S105Mx EUM-100S150Mx EUM-100S280Mx Output Current Setting Range with Constant Power EUM-100S105Mx EUM-100S150Mx EUM-100S280Mx Total Output Current Ripple (pk-pk) 3 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 At 100% load condition At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load Measured at 120-277Vac input, 65%-100%load Case temperature = 0C ~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2. 2ms in a 6.0ms period during which time t he average should not exceed 250mA. 850mA peak for a maximum duration of 1. 3ms in a 5.2ms period during which time t he average should not exceed 250mA. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B General Specifications Parameter Min. Typ. Max. 87.5% 88.5% 89.5% 90.5% - 87.5% 88.5% 89.5% 90.5% - 87.0% 87.0% 89.0% 89.0% - 89.5% 90.5% 91.5% 92.5% - 89.5% 90.5% 91.5% 92.5% - 89.0% 89.0% 91.0% 91.0% - 90.0% 91.0% 92.0% 93.0% - 90.0% 90.5% 92.0% 92.5% - 89.0% 89.5% 91.0% 91.5% - Standby Power - - 0.5 W MTBF - 262,000 Hours - Lifetime - 112,000 Hours - -40°C - +90°C -40°C - +80°C Case temperature for 5 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 120 Vac input: EUM-100S105Mx Io= 700 mA Io=1050 mA EUM-100S150Mx Io=1050 mA Io=1500 mA EUM-100S280Mx Io=1750 mA Io=2800 mA Efficiency at 220 Vac input: EUM-100S105Mx Io= 700 mA Io=1050 mA EUM-100S150Mx Io=1050 mA Io=1500 mA EUM-100S280Mx Io=1750 mA Io=2800 mA Efficiency at 277 Vac input: EUM-100S105Mx Io= 700 mA Io=1050 mA EUM-100S150Mx Io=1050 mA Io=1500 mA EUM-100S280Mx Io=1750 mA Io=2800 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 705 g 4 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 5.83 × 2.66 × 1.44 148 × 67.5 × 36.5 5.16 × 2.66 × 1.44 131 × 67.5 × 36.5 - Notes - All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 μA 300 μA 450 μA 10%Ioset - Ioset EUM-100S105Mx EUM-100S150Mx EUM-100S280Mx Recommended Dimming Input Range 70 mA 105 mA 175 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range EUM-100S105Mx EUM-100S150Mx EUM-100S280Mx Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1750 mA ≤ Ioset ≤ 2800 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 175 mA ≤ Ioset < 1750 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety & EMC Compliance Safety Category UL/CUL ENEC & CE UKCA CB Standard UL8750,CAN/CSA-C22.2 No. 250.13 EN 61347-1, EN 61347-2-13 BS EN 61347-1, BS EN 61347-2-13 IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 5 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx Rev. B 100W Programmable Driver with INV Digital Dimming Safety & EMC Compliance (Continued) Safety Category KS EAC Standard KS C 7655 ГОСТ Р МЭК 61347-1, ГОСТ IEC 61347-2-13 EMI Standards EN 55015/GB 17743/KN 15(1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. 6 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx Rev. B 100W Programmable Driver with INV Digital Dimming Derating Lifetime vs. Case Temperature Inrush Current Waveform 7 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx Rev. B 100W Programmable Driver with INV Digital Dimming Efficiency vs. Load EUM-100S105Mx(Io=700mA) EUM-100S105Mx(Io=1050mA) EUM-100S150Mx(Io=1050mA) EUM-100S150Mx(Io=1500mA) EUM-100S280Mx(Io=1750mA) EUM-100S280Mx(Io=2800mA) 8 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B Power Factor Total Harmonic Distortion Protection Functions Parameter Min. Typ. Max. Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection (IUVP) Input Under Voltage Protection Input Under Voltage Recovery 70 Vac 80 Vac 90 Vac Turn off the output when the input voltage falls below protection voltage. 75 Vac 85 Vac 95 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 9 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B Protection Functions (Continued) Parameter Input Over Voltage Protection Input Over Voltage Recovery Input Over Voltage Protection (IOVP) Max. of Input Over Voltage  Min. Typ. Max. Notes 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive stabilized input over voltage conditions up to 350Vac for a total of 8 hours. Input Under Voltage Protection Diagram Io Recovery Protection Vin 80 Vac  85 Vac Input Over Voltage Protection Diagram Io Recovery Protection 320 Vac 310 Vac Vin Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. 10 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx 100W Programmable Driver with INV Digital Dimming Rev. B V+ L Vac N Inventronics LED Driver VVaux Dim+ G Dimmer Dim- Implementation 1: Positive logic V+ L Vac N Inventronics LED Driver VVaux Dim+ G Dimmer Dim- Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby..  PWM Dimming The recommended implementation of the dimming control is provided below. V+ L Vac N Inventronics LED Driver G VVaux Dim+ PWM Signal Dim- Implementation 3: Positive logic 11 / 15 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-100SxxxMx V+ L Vac N 100W Programmable Driver with INV Digital Dimming Rev. B Inventronics LED Driver G VVaux Dim+ Dim- PWM Signal Implementation 4: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-100S150MT 价格&库存
很抱歉,暂时无法提供与“EUM-100S150MT”相匹配的价格&库存,您可以联系我们找货
