EUM-320S150LG
EUM-320S150LG
    INVENTRONICS(英飞特)
EUM-320S150LG 数据手册
EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Features • Full Power at Wide Output Current Range (Constant Power) • Adjustable Output Current (AOC) with NFC • Isolated 0-10V/PWM/3-Timer-Modes Dimmable • INV Digital Dimming, UART Based Communication Protocol Compliant with T/CSA-051 • Dim-to-Off with Standby Power ≤ 0.5 W • Always-on Auxiliary Power: 12Vdc, 250mA, 3W (Transient Peak Power up to 10W) • Low Inrush Current • Integrated Power Monitoring with High Accuracy up to ±1% • Output Lumen Compensation • End-of-Life Indicator • Thermal Sensing and Protection for LED Module • Input Surge Protection: DM 6kV, CM 10kV • All-Around Protection: IUVP, IOVP, OVP, SCP, OTP • IP66 / IP67 and UL Dry / Damp / Wet Location • TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location • 7 Years Warranty Description The EUM-320SxxxLx series is a 320W, constant-current, NFC programmable and IP66/IP67 rated LED driver that operates from 90-305Vac input with excellent power factor. Created for smart lighting and health monitoring applications, this family provides integrated AC power monitoring with an auxiliary voltage and dim-to-off functionality for powering low voltage, wireless controls. The dimming control supports 0-10V dimming as well as two-way communication via Digital Dimming, a UART based communication protocol that complies with T/CSA051. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, input over voltage, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range(1) Default Output Current 70-1050mA 700-1050mA 700 mA 105-1500mA 1050-1500mA 1400 mA 175-2500mA 1750-2500mA 2100 mA 285-5000mA 2850-5000mA 4900 mA 535-7600mA 5350-7600mA 6700 mA Input Voltage Range(2) 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc 90~305 Vac/ 127~300 Vdc Output Voltage Range Typical Max. Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac Model Number (5) 153~457Vdc 320 W 94.5% 0.99 0.96 EUM-320S105Lx 107~305Vdc 320 W 94.0% 0.99 0.96 EUM-320S150Lx 64~183 Vdc 320 W 94.0% 0.99 0.96 EUM-320S250Lx 32~112 Vdc 320 W 93.5% 0.99 0.96 EUM-320S500Lx 21 ~ 60 Vdc 320 W 92.5% 0.99 0.96 EUM-320S760Lx (4) (4) 1 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Notes: (1) Output current range with constant power at 320W (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac. (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output. (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models; x = B are BIS models. I-V Operation Area EUM-320S105Lx EUM-320S150Lx 360 (105,305) (630,305) (1050,305) 300 (10%Ioset,320/Ioset) (Ioset,320/Ioset) 10 240 % 60 0% Lo ad Lo 180 ad (1500,213) (1500,128) 120 (Ioset,107) (150,107) 60 Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 300 600 (1500,107) 900 1200 1500 1800 Output Current (mA) Note: 1050mA Ioset 1500mA EUM-320S500Lx % 60 Output Voltage(V) EUM-320S250Lx a Lo d 2 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B EUM-320S760Lx 66 (535,60) 55 (3210,60) (5350,60) (10%Ioset,320/Ioset) (Ioset,320/Ioset) 10 44 % 60 0% ad Lo 33 Lo ad (7600,42) (7600,25) 22 (760,21) 11 (Ioset,21) Programmed Operating Area Good Performance Area Allowed Operating Area 0 0 1500 3000 (7600,21) 6000 4500 7500 9000 Output Current (mA) Note: 5350mA Ioset 7600mA Input Specifications Parameter Min. Typ. Max. Notes Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 3.35 A Measured at 100% load and 120 Vac input. - - 1.80 A Measured at 100% load and 220 Vac input. - - 1.09 A s 0.9 - - THD - - 20% THD - - 10% Min. Typ. Max. -5%Ioset - 5%Ioset 70 mA 105 mA 175 mA 285 mA 535 mA - 1050 mA 1500 mA 2500 mA 5000 mA 7600 mA Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 At 220Vac input, 25°C cold start, duration=7.84 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 60%-100% Load (192-320W) At 220-240Vac, 50-60Hz, 75%-100% Load (240-320W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUM-320S105Lx EUM-320S150Lx EUM-320S250Lx EUM-320S500Lx EUM-320S760Lx Notes At 100% load condition 3 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Output Specifications (Continued) Parameter Min. Typ. Max. Output Current Setting Range with Constant Power EUM-320S105Lx EUM-320S150Lx EUM-320S250Lx EUM-320S500Lx EUM-320S760Lx Total Output Current Ripple (pk-pk) 700 mA 1050 mA 1750 mA 2850 mA 5350 mA - 1050 mA 1500 mA 2500 mA 5000 mA 7600 mA - 5%Iomax 10%Iomax Output Current Ripple at < 200 Hz (pk-pk) - 2%Iomax - Startup Overshoot Current - - 10%Iomax No Load Output Voltage EUM-320S105Lx EUM-320S150Lx EUM-320S250Lx EUM-320S500Lx EUM-320S760Lx - - 550 V 380 V 230 V 120 V 70 V Line Regulation - - ±0.5% Load Regulation - - ±3.0% Turn-on Delay Time - - 0.5 s Temperature Coefficient of Ioset - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA Min. Typ. Max. 90.0% 90.0% 92.0% 92.0% - 90.0% 90.0% 92.0% 92.0% - 90.0% 90.0% 92.0% 92.0% - 89.5% 88.0% 91.5% 90.0% - 88.5% 88.0% 90.5% 90.0% - Notes At 100% load condition. 20 MHz BW At 100% load condition. Only this component of ripple is associated with visible flicker. At 100% load condition Measured at 100% load 120-277Vac input, 60%-100% Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 250mA. 850mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 250mA. General Specifications Parameter Efficiency at 120 Vac input: EUM-320S105Lx Io= 700 mA Io=1050 mA EUM-320S150Lx Io=1050 mA Io=1500 mA EUM-320S250Lx Io=1750 mA Io=2500 mA EUM-320S500Lx Io=2850 mA Io=5000 mA EUM-320S760Lx Io=5350 mA Io=7600 mA Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 4 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B General Specifications (Continued) Parameter Min. Typ. Max. 92.5% 92.5% 94.5% 94.5% - 92.0% 92.0% 94.0% 94.0% - 92.0% 92.0% 94.0% 94.0% - 91.5% 90.0% 93.5% 92.0% - 90.5% 90.0% 92.5% 92.0% - 92.5% 92.5% 94.5% 94.5% - 92.5% 92.5% 94.5% 94.5% - 92.5% 92.5% 94.5% 94.5% - 92.0% 90.5% 94.0% 92.5% - 91.0% 90.0% 93.0% 92.0% - -1% - 1% Measured at 220Vac input and 100%load Standby Power - - 0.5 W Measured at 230Vac/50Hz; Dimming off MTBF - 231,000 Hours - Lifetime - 112,000 Hours - -40°C - +90°C -40°C - +75°C Case temperature for 7 years warranty Humidity: 10% RH to 95% RH; -40°C - +85°C Humidity: 5%RH to 95%RH Efficiency at 220 Vac input: EUM-320S105Lx Io= 700 mA Io=1050 mA EUM-320S150Lx Io=1050 mA Io=1500 mA EUM-320S250Lx Io=1750 mA Io=2500 mA EUM-320S500Lx Io=2850 mA Io=5000 mA EUM-320S760Lx Io=5350 mA Io=7600 mA Efficiency at 277 Vac input: EUM-320S105Lx Io= 700 mA Io=1050 mA EUM-320S150Lx Io=1050 mA Io=1500 mA EUM-320S250Lx Io=1750 mA Io=2500 mA EUM-320S500Lx Io=2850 mA Io=5000 mA EUM-320S760Lx Io=5350 mA Io=7600 mA Power Monitoring Accuracy Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 1520 g Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.57 × 3.15 × 1.75 243 × 80 × 44.5 8.82 × 3.15 × 1.75 224 × 80 × 44.5 - Notes - 5 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Dimming Specifications Parameter Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 uA 300 uA 450 uA EUM-320S105Lx EUM-320S150Lx EUM-320S250Lx EUM-320S500Lx EUM-320S760Lx 10%Ioset - Ioset EUM-320S105Lx EUM-320S150Lx EUM-320S250Lx EUM-320S500Lx EUM-320S760Lx 70 mA 105 mA 175 mA 285 mA 535 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 700 mA ≤ Ioset ≤ 1050 mA 1050 mA ≤ Ioset ≤ 1500 mA 1750 mA ≤ Ioset ≤ 2500 mA 2850 mA ≤ Ioset ≤ 5000 mA 5350 mA ≤ Ioset ≤ 7600 mA 70 mA ≤ Ioset < 700 mA 105 mA ≤ Ioset < 1050 mA 175 mA ≤ Ioset < 1750 mA 285 mA ≤ Ioset < 2850 mA 535 mA ≤ Ioset < 5350 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety & EMC Compliance Safety Category UL/CUL Standard UL8750, CAN/CSA-C22.2 No. 250.13 ENEC & CE EN 61347-1, EN 61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 BIS IS 15885(Part2/Sec13) 6 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Safety & EMC Compliance (Continued) Safety Category Standard KC K 61347-1, K 61347-2-13 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 7 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUM-320S105Lx(Io=700mA) EUM-320S105Lx(Io=1050mA) 8 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B EUM-320S150Lx(Io=1050mA) EUM-320S150Lx(Io=1500mA) EUM-320S250Lx(Io=1750mA) EUM-320S250Lx(Io=2500mA) EUM-320S500Lx(Io=2850mA) EUM-320S500Lx(Io=5000mA) 9 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B EUM-320S760Lx(Io=5350mA) EUM-320S760Lx(Io=7600mA) Power Factor Total Harmonic Distortion 10 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B Protection Functions Parameter External Thermal Protection Min. Typ. Max. R1 (Start derating) - 1.67 kΩ - R2 (Stop derating) - 1.27 kΩ - 10%Ioset 20%Ioset 100%Ioset 10%Ioset > Iomin (default setting is 20%) Iomin 20%Ioset 100%Ioset 10%Ioset ≤ Iomin (default setting is 20%) Protection Current Floor Notes The output current starts to decrease linearly when the actual NTC resistance value is lower than R1, until R2 is reached. When the actual NTC resistance value is lower than R2, the output current will stay at the programmed Protection Current Floor. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP) Input Under Voltage Protection Input Under Voltage Recovery Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 70 Vac 80 Vac 90 Vac Turn off the output when the input voltage falls below protection voltage. 75 Vac 85 Vac 95 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive stabilized input over voltage conditions up to 350Vac for a total of 8 hours. Note: (1) The recommended NTC type is 10kΩ NTC, Murata NCP18XH103J03RB.  Input Under Voltage Protection Diagram 11 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx  320W NFC Driver with INV Digital Dimming Rev. B Input Over Voltage Protection Diagram Io Recovery Protection Vin 320 Vac 310 Vac Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 12 / 18 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-320SxxxLx 320W NFC Driver with INV Digital Dimming Rev. B 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 3: Positive logic Implementation 4: Negative logic Note: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-320S150LG 价格&库存
很抱歉,暂时无法提供与“EUM-320S150LG”相匹配的价格&库存,您可以联系我们找货
EUM-320S150LG
    EUM-320S150LG
