EUM-880S420MT
EUM-880S420MT
    INVENTRONICS(英飞特)
EUM-880S420MT 数据手册
EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Features  Ultra High Efficiency (Up to 96.0%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC)with Programmability  Isolated 0-10V/PWM/3-Timer-Modes Dimmable  INV Digital Dimming, UART Based Communication Protocol  Dim-to-Off with Standby Power ≤ 0.5 W  Minimum Dimming Level with 5% or 10% Selectable  Maximum Dimming Level with 9V or 10V Selectable  Fade Time Adjustable  Always-on Auxiliary Power: 12Vdc, 250mA  Low inrush current  Output Lumen Compensation  End-of-Life Indicator  Input Surge Protection: DM 6kV, CM 10kV  All-Around Protection: IOVP, IUVP, OVP, SCP, OTP   IP66 / IP67 and UL Dry / Damp / Wet Location TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location 5 Years Warranty  Description The EUM-880SxxxMx series is an 880W, constant-current, programmable and IP66/IP67 rated LED driver that operates from 90-305 Vac input with excellent power factor. Created for many lighting applications including high mast, sports, UV-LED, aquaculture and horticulture, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Full-Power Default Output Current Output Current Range(1) Current Range Input Voltage Range(2) Typical Max Typical Power Factor Output Efficiency Power (3) 120Vac 220Vac Output Voltage Range Model Number 0.195-2.8A 1.95-2.8A 2.1 A 90~305Vac 157 ~ 452Vdc 880 W 127~300Vdc 95.0% 0.99 0.96 EUM-880S280Mx 0.300-4.2A 3.0-4.2A 4.2 A 90~305Vac 104 ~ 294Vdc 880 W 127~300Vdc 95.5% 0.99 0.96 EUM-880S420Mx 0.490-7.0A 4.9-7.0A 5.6 A 90~305Vac 63.0 ~ 180Vdc 880 W 127~300Vdc 96.0% 0.99 0.96 EUM-880S700Mx 0.800-11.5A 8.0-11.5A 8.4 A 90~305Vac 38.0 ~ 110Vdc 880 W 127~300Vdc 94.5% 0.99 0.96 EUM-880S11AMx(4) 90~305Vac 22.0 ~ 54Vdc 127~300Vdc 95.5% 0.99 0.96 EUM-880S20AMx(4) 1.630-20.0A 16.3-20.0A 20.0 A 880 W Notes: (1) Output current range with constant power at 880W. (2) Certified input voltage range: UL, FCC 100-277Vac; otherwise 100-240Vac (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV output (5) x = G are UL Recognized, ENEC and CCC, etc. models; x = T are UL Class P models. 1 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A I-V Operating Area EUM-880S280Mx EUM-880S420Mx 546 354 Output Voltage(V) (1,170, 452) (1,950, 452) (10%Ioset,880/Ioset) 364 (2,800, 314) 273 (2,800, 189) 182 (2800, 157) (Ioset, 157) (1,800, 294) (Ioset,880/Ioset) 236 (4,200, 210) 177 (4,200, 126) 118 91 (Ioset, 104) (420, 104) (4200, 104) 59 Good Performance Area Programmed Operating Area Good Performance Area Allowed Operating Area Programmed Operating Area Allowed Operating Area 0 0 0 560 1120 1680 2240 2800 3360 0 840 1680 2520 3360 4200 Output Current (mA) Output Current (mA) Note: 1950mA≤Ioset≤2800mA Note: 3000mA≤Ioset≤4200mA EUM-880S700Mx 5040 EUM-880S11AMx 132 216 (2,940, 180) (4,900, 180) (10%Ioset,880/Ioset) (Ioset,880/Ioset) 144 (7,000, 126) 108 (7,000, 75) 72 (7000, 63) (Ioset, 63) (700, 63) (800, 110) 110 Output Voltage(V) (490, 180) 180 Output Voltage(V) (3,000, 294) (10%Ioset,880/Ioset) (Ioset,880/Ioset) (280, 157) (300, 294) 295 Output Voltage(V) (195, 452) 455 (4,800, 110) (8,000, 110) (10%Ioset,880/Ioset) 88 (Ioset,880/Ioset) (11,500, 77) 66 (11,500, 46) 44 (11500, 38) (Ioset, 38) (1150, 38) 22 36 Good Performance Area Programmed Operating Area Good Performance Area Allowed Operating Area Programmed Operating Area Allowed Operating Area 0 0 0 1400 2800 4200 5600 7000 0 8400 2300 4600 6900 9200 11500 Output Current (mA) Output Current (mA) Note: 4900mA≤Ioset≤7000mA Note: 8000mA≤Ioset≤11500mA 13800 EUM-880S20AMx 66 (1630, 54) 55 (16,300, 54) (9,780, 54) Output Voltage(V) (10%Ioset,880/Ioset) (Ioset,880/Ioset) 44 (20,000, 44) 33 (20,000, 26) 22 (Ioset, 22) (2000, 22) (20000, 22) 11 Good Performance Area Programmed Operating Area Allowed Operating Area 0 0 4000 8000 12000 16000 20000 24000 Output Current (mA) Note: 16300mA≤Ioset≤20000mA 2 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Input Specifications Parameter Min. Typ. Max. Notes Input AC Voltage 90 Vac - 305 Vac Input DC Voltage 127 Vdc - 300 Vdc Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz 0.70 mA IEC60598-1; 240Vac/ 60Hz Leakage Current - - 7.80 A Measured at 90% load and 120 Vac input. - - 4.72 A Measured at 100% load and 220 Vac input. - - 2.11 A2s 0.90 - - - - 20% Input AC Current At 220Vac input, 25℃ cold start, Inrush Current(I2t) PF THD 10% duration=15.2 ms, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. At 100-277Vac, 50-60Hz, 60%%-100% Load (528 - 880W) At 220-240Vac, 50-60Hz, 75%-100% Load (660 - 880W) Output Specifications Parameter Min. Typ. Max. -5%Ioset - 5%Ioset 195 mA 300 mA 490 mA 800 mA 1630 mA - 2800 mA 4200 mA 7000 mA 11500 mA 20000 mA 1950 mA 3000 mA 4900 mA 8000 mA 16300 mA - 2800 mA 4200 mA 7000 mA 11500 mA 20000 mA - 5%Iomax 10%Iomax 100% load, 20 MHz BW - - 2%Iomax 70%-100% load Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx - - 500 V 350 V 210 V 120 V 60 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Output Current Tolerance Output Current Setting(Ioset) Range EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx Output Current Setting Range with Constant Power EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) 3 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes 100% load 100% load All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Output Specifications (Continued) Parameter Min. Typ. Max. Notes Turn-on Delay Time - - 0.5 s Measured at 120-277Vac input, 60%-100% Load Temperature Coefficient of Ioset - 0.03%/C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 250 mA 12V Auxiliary Output Transient Peak Current@6W - - 500 mA 12V Auxiliary Output Transient Peak Current@10W - - 850 mA Case temperature = 0C ~Tc max Return terminal is “Dim−“ 500mA peak for a maximum duration of 2.2 ms in a 6.0ms period during which time the average should not exceed 250mA. 850mA peak for a maximum duration of 1.3 ms in a 5.2ms period during which time the average should not exceed 250mA. General Specifications Parameter Efficiency at 120 Vac input: EUM-880S280Mx Io= 1950 mA Io= 2800 mA EUM-880S420Mx Io= 3000 mA Io= 4200 mA EUM-880S700Mx Io= 4900 mA Io= 7000 mA EUM-880S11AMx Io= 8000 mA Io= 11500 mA EUM-880S20AMx Io= 16300 mA Io= 20000 mA Efficiency at 220 Vac input: EUM-880S280Mx Io= 1950 mA Io= 2800 mA EUM-880S420Mx Io= 3000 mA Io= 4200 mA EUM-880S700Mx Io= 4900 mA Io= 7000 mA EUM-880S11AMx Io= 8000 mA Io= 11500 mA EUM-880S20AMx Io= 16300 mA Io= 20000 mA Min. Typ. Max. 92.0% 91.5% 94.0% 93.5% - 92.0% 91.5% 94.0% 93.5% - 92.5% 92.0% 94.5% 94.0% - 92.0% 91.0% 94.0% 93.0% - 92.0% 91.5% 94.0% 93.5% - 93.0% 93.0% 95.0% 95.0% - 93.5% 93.5% 95.5% 95.5% - 94.0% 93.5% 96.0% 95.5% - 92.5% 92.5% 94.5% 94.5% - 93.5% 93.5% 95.5% 95.5% - 4 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 90% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A General Specifications (Continued) Parameter Min. Typ. Max. 93.5% 93.5% 95.5% 95.5% - 94.0% 93.5% 96.0% 95.5% - 94.0% 94.0% 96.0% 96.0% - 93.0% 93.0% 95.0% 95.0% - 93.5% 93.5% 95.5% 95.5% - Standby Power - - 0.5 W MTBF - 200,000 Hours - - 105,000 Hours - - 83,000 Hours - -40°C - +90°C -40°C - +80°C -40°C - +85°C Efficiency at 277 Vac input: EUM-880S280Mx Io= 1950 mA Io= 2800 mA EUM-880S420Mx Io= 3000 mA Io= 4200 mA EUM-880S700Mx Io= 4900 mA Io= 7000 mA EUM-880S11AMx Io= 8000 mA Io= 11500 mA EUM-880S20AMx Io= 16300 mA Io= 20000 mA Lifetime Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Net Weight Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 230Vac/50Hz; Dimming off Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details Measured at 220Vac input, 100%Load and 40C ambient temperature Case temperature for 5 years warranty Humidity: 10%RH to 95%RH Humidity: 5%RH to 95%RH With mounting ear 10.83 × 5.67 × 1.91 275 × 144 × 48.5 9.84 × 5.67 × 1.91 250 × 144 × 48.5 Inches (L × W × H) Millimeters (L × W × H) Notes - 3500 g - Min. Typ. Max. Absolute Maximum Voltage on the Vdim (+) Pin -20 V - 20 V Source Current on Vdim (+)Pin 200 uA 300 uA 450 uA Dimming Specifications Parameter Dimming Output Range with 10%-100% (Default) EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx 10%Ioset - Ioset EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx 195 mA 300 mA 490 mA 800 mA 1630 mA - Ioset 5 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Vdim(+) = 0 V 1950 mA ≤ Ioset ≤ 2800 mA 3000 mA ≤ Ioset ≤ 4200 mA 4900 mA ≤ Ioset ≤ 7000 mA 8000 mA ≤ Ioset ≤ 11000 mA 16300 mA ≤ Ioset ≤ 20000 mA 195 mA ≤ Ioset <1950 mA 300 mA ≤ Ioset <3000 mA 490 mA ≤ Ioset <4900 mA 800 mA ≤ Ioset <8000 mA 1630 mA ≤ Ioset <16300 mA All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Dimming Specifications (Continued) Parameter Min. Typ. Max. EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx 5%Ioset - Ioset EUM-880S280Mx EUM-880S420Mx EUM-880S700Mx EUM-880S11AMx EUM-880S20AMx 98 mA 150 mA 245 mA 400 mA 815 mA - Ioset 0V - 10 V Dim off Voltage 0.35 V 0.5 V 0.65 V Dim on Voltage 0.55 V 0.7 V 0.85 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Dimming Output Range with 5%-100% (Settable) Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes 1950 mA ≤ Ioset ≤ 2800 mA 3000 mA ≤ Ioset ≤ 4200 mA 4900 mA ≤ Ioset ≤ 7000 mA 8000 mA ≤ Ioset ≤ 11000 mA 16300 mA ≤ Ioset ≤ 20000 mA 195 mA ≤ Ioset <1950 mA 300 mA ≤ Ioset <3000 mA 490 mA ≤ Ioset <4900 mA 800 mA ≤ Ioset <8000 mA 1630 mA ≤ Ioset <16300 mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety &EMC Compliance Safety Category UL/CUL ENEC & CE UKCA CB Standard UL8750,CAN/CSA-C22.2 No. 250.13 EN 61347-1, EN 61347-2-13 BS EN 61347-1, BS EN 61347-2-13 IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 NOM NOM-058-SCFI EMI Standards EN 55015(1) EN 61000-3-2 Notes Conducted emission Test &Radiated emission Test Harmonic current emissions 6 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Safety &EMC Compliance (Continued) EMI Standards EN 61000-3-3 Notes Voltage fluctuations & flicker ANSI C63.4 Class B FCC Part 15(1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 6 kV, Common Mode 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 7 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUM-880S280Mx(lo=1950mA) EUM-880S280Mx(lo=2800mA) 8 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A EUM-880S420Mx(lo=3000mA) EUM-880S420Mx(lo=4200mA) EUM-880S700Mx(lo=4900mA) EUM-880S420Mx(lo=7000mA) EUM-880S11AMx(lo=8000mA) EUM-880S11AMx(lo=11500mA) 9 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A EUM-880S20AMx(lo=16300mA) EUM-880S20AMx(lo=20000mA) Power Factor Total Harmonic Distortion 10 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Protection Functions Parameter Min. Typ. Max. Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Input Under Voltage Protection (IUVP) Input Over Voltage Protection (IOVP)  Input Protection Voltage Input Recovery Voltage Input Over Voltage Protection Input Over Voltage Recovery Max. of Input Over Voltage 70 Vac 80 Vac 90 Vac Turn off the output when the input voltage falls below protection voltage. 75 Vac 85 Vac 95 Vac Auto Recovery. The driver will restart when the input voltage exceeds recovery voltage. 310 Vac 320 Vac 330 Vac Turn off the output when the input voltage exceeds protection voltage. 300 Vac 310 Vac 320 Vac - - 350 Vac Auto Recovery. The driver will restart when the input voltage falls below recovery voltage. The driver can survive for 8 hours with a stable input voltage stress of 350Vac. Input Under Voltage Protection Diagram Io Recovery Protection 80 Vac  Vin 85 Vac Input Over Voltage Protection Diagram Io Recovery Protection 310 Vac 320 Vac 11 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Vin All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: Positive logic 12 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A Implementation 2: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like zener. 3. When 0-10V negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby.  PWM Dimming The recommended implementation of the dimming control is provided below. V+ L V- Vac N Inventronics LED Driver G Vaux Dim+ Dim- PWM Signal Implementation 3: Positive logic 13 / 21 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUM-880SxxxMx 880W Programmable with INV Digital Dimming Rev.A V+ L V- Vac N Inventronics LED Driver Vaux Dim+ G Dim- PWM Signal Implementation 4: Negative logic Notes: 1. 2.  Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. When PWM negative logic dimming mode and Dim+ is open, the driver will dim to off and be standby. Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer.  Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
EUM-880S420MT 价格&库存
很抱歉,暂时无法提供与“EUM-880S420MT”相匹配的价格&库存,您可以联系我们找货
EUM-880S420MT
    EUM-880S420MT
