EUP-075S280ST
EUP-075S280ST
    INVENTRONICS(英飞特)
    EUC Series 75 W 2100 mA 39 Vdc Out Max Constant Current LED AOC IP67 Driver
EUP-075S280ST 数据手册
EUP-075SxxxST 75W AOC IP67 Driver Rev.E Features  High Efficiency (Up to 91.0%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Dip-switch  Non-dimming Control  Input Surge Protection: 6 kV line-line, 10 kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location   Class 2 & SELV Output TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location 5 years warranty  Description The EUP-075SxxxST series is a 75W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including street, tunnel and bay. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) 350-700mA 450-700mA 700-1050mA 700-1050mA 1050-1750mA 1190-1750mA 1080-1800mA 1400-1800mA 1700-2800mA 1900-2800mA Default Output Current Input Voltage Range(2) Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range 90~305 Vac/ 54~167Vdc 127~300 Vdc 90~305 Vac/ 700 mA 36~107Vdc 127~300 Vdc 90~305 Vac/ 1400 mA 22 ~ 63Vdc 127~300 Vdc 90~305 Vac/ 1400 mA 22 ~ 54Vdc 127~300 Vdc 90~305 Vac/ 2100 mA 14 ~ 39Vdc 127~300 Vdc 550 mA Model Number 75 W 91.0% 0.98 0.96 EUP-075S070ST 75 W 91.0% 0.98 0.96 EUP-075S105ST (4) 75 W 90.5% 0.98 0.96 EUP-075S175ST (4) 75 W 90.5% 0.98 0.96 EUP-075S180ST (5) 75 W 89.5% 0.98 0.96 EUP-075S280ST (5) Notes: (1) Output current range with constant power at 75W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. (5) Class 2 & SELV Output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz 127~300 Vdc 1 / 12 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-075SxxxST 75W AOC IP67 Driver Rev.E Input Specifications Parameter Min. Typ. Max. Notes - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz - - 1.05 A Measured at 100% load and 100 Vac input. - - 0.45 A Measured at 100% load and 220 Vac input. Leakage Current Input AC Current 2 Inrush Current(I t) PF 2 - 0.54 A s At 220Vac input, 25C cold start, duration=164 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 0.9 - - THD - - 20% THD - 8% - At 220-240Vac, 50-60Hz, 80%-100% Load Please evaluate with LEDs to insure THD
EUP-075S280ST 价格&库存
很抱歉,暂时无法提供与“EUP-075S280ST”相匹配的价格&库存,您可以联系我们找货
