EUP-150S350ST
EUP-150S350ST
    INVENTRONICS(英飞特)
    EUC Series 150 W 3150 mA 61 Vdc Out Max Constant Current LED AOC IP67 Driver
EUP-150S350ST 数据手册
EUP-150SxxxST 150W AOC IP67 Driver Rev. C Features  High Efficiency (Up to 93.0%)  Full Power at Wide Output Current Range (Constant Power)  Adjustable Output Current (AOC) with Dip-switch  Non-dimming Control  Input Surge Protection: 6 kV line-line, 10 kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 years warranty Description The EUP-150SxxxST series is a 150W, constant-current, AOC LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including street, tunnel and bay. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Power Factor Max. Typical Output Efficiency 120Vac 220Vac Power (3) Output Voltage Range 90~305 Vac/ 117~333Vdc 127~300 Vdc 90~305 Vac/ 700-1050mA 700-1050mA 700 mA 75~214 Vdc 127~300 Vdc 90~305 Vac/ 850-1500mA 1050-1500mA 1050 mA 50~143 Vdc 127~250 Vdc 90~305 Vac/ 1000-2100mA 1400-2100mA 1400 mA 38~107 Vdc 127~300 Vdc 90~305 Vac/ 2100-3500mA 2450-3500mA 3150 mA 22 ~ 61 Vdc 127~300 Vdc 90~305 Vac/ 3500-5600mA 4200-5600mA 4200 mA 14 ~ 36 Vdc 127~300 Vdc 350-700mA 450-700mA 550 mA Model Number 150 W 93.0% 0.99 0.96 EUP-150S070ST 150 W 93.0% 0.99 0.96 EUP-150S105ST 150 W 92.5% 0.99 0.96 EUP-150S150ST 150 W 93.0% 0.99 0.96 EUP-150S210ST (4) 150 W 92.5% 0.99 0.96 EUP-150S350ST (4) 150 W 92.0% 0.99 0.96 EUP-150S560ST(4) Notes: (1) Output current range with constant power at 150W (2) Certified input voltage range: UL, FCC 100-277Vac or 127-300Vdc; otherwise 100-240Vac or 127-250Vdc (except KS) (3) Measured at 100% load and 220Vac input (see below “General Specifications” for details). (4) SELV Output. 1 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz - - 0.75 MIU UL8750; 277Vac/ 60Hz - - 0.70 mA IEC60598-1; 240Vac/ 60Hz, - - 1.60 A - - 0.90 A Leakage Current Input AC Current 2 Inrush Current(I t) 2 Notes 127~300 Vdc Measured at 100% load and 120 Vac input. Measured at 100% load and 220 Vac input. At 220Vac input, 25°C cold start, duration=740 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. - - 2.10 A s 0.9 - - THD - - 20% THD - - 10% At 220-240Vac, 50-60Hz, 75%-100% Load (112.5-150W) Min. Typ. Max. Notes -5%Ioset - 5%Ioset 350 mA 700 mA 850 mA 1000 mA 2100 mA 3500 mA - 700 mA 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA 450 mA 700 mA 1050 mA 1400 mA 2450 mA 4200 mA - 700 mA 1050 mA 1500 mA 2100 mA 3500 mA 5600 mA - 5%Iomax 10%Iomax 100% load. 20 MHz BW Startup Overshoot Current - - 10%Iomax 100% load No Load Output Voltage EUP-150S070ST EUP-150S105ST EUP-150S150ST EUP-150S210ST EUP-150S350ST EUP-150S560ST - 350 V 230 V 160 V 118 V 70 V 40 V 360 V 240 V 170 V 120 V 80 V 50 V Line Regulation - - ±0.5% Load Regulation - - ±1.5% PF At 100-277Vac, 50-60Hz, 70%-100% Load (105-150W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range EUP-150S070ST EUP-150S105ST EUP-150S150ST EUP-150S210ST EUP-150S350ST EUP-150S560ST Output Current Setting Range with Constant Power EUP-150S070ST EUP-150S105ST EUP-150S150ST EUP-150S210ST EUP-150S350ST EUP-150S560ST Total Output Current Ripple (pk-pk) 100% load 100% load 2 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Output Specifications (continued) Parameter Min. Typ. Max. - - 1.0 s - - 0.5 s - 0.03%/°C - Turn-on Delay Time Temperature Coefficient of Ioset Notes Measured at 120Vac input, 70%-100% Load Measured at 220Vac input, 70%-100% Load Case temperature = 0°C ~Tc max Note: All specifications are typical at 25°C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUP-150S070ST Io= 450 mA Io= 700 mA EUP-150S105ST Io= 700 mA Io=1050 mA EUP-150S150ST Io=1050 mA Io=1500 mA EUP-150S210ST Io=1400 mA Io=2100 mA EUP-150S350ST Io=2450 mA Io=3500 mA EUP-150S560ST Io=4200 mA Io=5600 mA Efficiency at 220 Vac input: EUP-150S070ST Io= 450 mA Io= 700 mA EUP-150S105ST Io= 700 mA Io=1050 mA EUP-150S150ST Io=1050 mA Io=1500 mA EUP-150S210ST Io=1400 mA Io=2100 mA EUP-150S350ST Io=2450 mA Io=3500 mA EUP-150S560ST Io=4200 mA Io=5600 mA Min. Typ. Max. 88.0% 87.5% 90.0% 89.5% - 88.5% 87.0% 90.5% 89.0% - 88.0% 87.0% 90.0% 89.0% - 88.5% 87.0% 90.5% 89.0% - 88.0% 86.0% 90.0% 88.0% - 88.0% 86.0% 90.0% 88.0% - 91.0% 90.0% 93.0% 92.0% - 91.0% 90.0% 93.0% 92.0% - 90.5% 90.0% 92.5% 92.0% - 91.0% 89.5% 93.0% 91.5% - 90.5% 88.5% 92.5% 90.5% - 90.0% 88.0% 92.0% 90.0% - Notes Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) 3 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C General Specifications (Continued) Parameter Min. Typ. Max. 91.0% 90.5% 93.0% 92.5% - 91.5% 90.0% 93.5% 92.0% - 91.0% 90.0% 93.0% 92.0% - 91.5% 90.0% 93.5% 92.0% - 91.0% 89.0% 93.0% 91.0% - 90.0% 88.0% 92.0% 90.0% - MTBF - 210,000 Hours - Lifetime - 114,000 Hours - -40°C - +90°C -40°C - +75°C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: EUP-150S070ST Io= 450 mA Io= 700 mA EUP-150S105ST Io= 700 mA Io=1050 mA EUP-150S150ST Io=1050 mA Io=1500 mA EUP-150S210ST Io=1400 mA Io=2100 mA EUP-150S350ST Io=2450 mA Io=3500 mA EUP-150S560ST Io=4200 mA Io=5600 mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) - Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 220Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 220Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 7.56 × 2.37 × 1.44 192 × 60 × 36.5 6.74 × 2.37 × 1.44 171 × 60 × 36.5 Net Weight Notes 810 g - Note: All specifications are typical at 25°C unless otherwise stated. Safety &EMC Compliance Safety Category UL/CUL Standard UL8750,CAN/CSA-C22.2 No. 250.13 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards EN 55015 (1) Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 4 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Safety &EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B FCC Part 15 (1) This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired Operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 6 kV, line to earth 10 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 (2) Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Derating 5 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUP-150S070ST(Io=450mA) EUP-150S070ST(Io=700mA) 6 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C EUP-150S105ST(Io=700mA) EUP-150S105ST(Io=1050mA) EUP-150S150ST(Io=1050mA) EUP-150S150ST(Io=1500mA) EUP-150S210ST(Io=1400mA) EUP-150S210ST(Io=2100mA) 7 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C EUP-150S350ST(Io=2450mA) EUP-150S350ST(Io=3500mA) EUP-150S560ST(Io=4200mA) EUP-150S560ST(Io=5600mA) Power Factor 8 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Total Harmonic Distortion Protection Functions Parameter Notes Over Temperature Protection Decreases output current, returning to normal after over temperature is removed. Short Circuit Protection Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Output Current vs. Dip Switch Setting  EUP-150S070ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. OFF ON ON ON 700mA 117V 214V OFF ON ON OFF 650mA 116V 231V OFF ON OFF ON 600mA 125V 250V OFF ON OFF OFF 550mA 137V 273V OFF OFF ON ON 500mA 150V 300V OFF OFF ON OFF 450mA 167V 333V OFF OFF OFF ON 400mA 188V 333V OFF OFF OFF OFF 350mA 214V 333V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 9 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST  150W AOC IP67 Driver Rev. C EUP-150S105ST Output Current Setting(Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1050mA 75V 143V ON ON ON OFF 1000mA 75V 150V ON ON OFF ON 950mA 79V 158V ON ON OFF OFF 900mA 83V 166V ON OFF ON ON 850mA 88V 176V ON OFF ON OFF 800mA 94V 187V ON OFF OFF ON 750mA 100V 200V ON OFF OFF OFF 700mA 107V 214V Notes / Output Current Setting with Constant Power. EUP-150S150ST Output Current Setting (Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 1500mA 50V 100V ON ON ON OFF 1450mA 52V 104V ON ON OFF ON 1400mA 54V 107V ON ON OFF OFF 1350mA 56V 111V ON OFF ON ON 1300mA 58V 116V ON OFF ON OFF 1250mA 60V 120V ON OFF OFF ON 1200mA 63V 125V ON OFF OFF OFF 1150mA 66V 131V OFF ON ON ON 1100mA 69V 137V OFF ON ON OFF 1050mA 72V 143V OFF ON OFF ON 1000mA 75V 143V OFF ON OFF OFF 950mA 79V 143V OFF OFF ON ON 900mA 84V 143V OFF OFF ON OFF 850mA 89V 143V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 10 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST  150W AOC IP67 Driver Rev. C EUP-150S210ST Output Current Setting(Ioset) Dip Switch Setting  Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 2100mA 38V 71V ON ON ON OFF 2000mA 38V 75V ON ON OFF ON 1900mA 40V 79V ON ON OFF OFF 1800mA 42V 83V ON OFF ON ON 1700mA 44V 88V ON OFF ON OFF 1600mA 47V 94V ON OFF OFF ON 1500mA 50V 100V ON OFF OFF OFF 1400mA 54V 107V OFF ON ON ON 1300mA 58V 107V OFF ON ON OFF 1200mA 63V 107V OFF ON OFF ON 1100mA 68V 107V OFF ON OFF OFF 1000mA 75V 107V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. EUP-150S350ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. ON ON ON ON 3500mA 22V 43V ON ON ON OFF 3325mA 23V 45V ON ON OFF ON 3150mA 24V 47.5V ON ON OFF OFF 2975mA 26V 50.5V ON OFF ON ON 2800mA 27V 53.5V ON OFF ON OFF 2625mA 29V 57V ON OFF OFF ON 2450mA 32V 61V ON OFF OFF OFF 2275mA 33V 61V OFF ON ON ON 2100mA 36V 61V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. 11 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST  150W AOC IP67 Driver Rev. C EUP-150S560ST Output Current Setting(Ioset) Dip Switch Setting Output Voltage Range 1 2 3 4 Typ. Min. Max. OFF ON ON ON 5600mA 14V 26.5V OFF ON ON OFF 5250mA 15V 28.5V OFF ON OFF ON 4900mA 16V 30.5V OFF ON OFF OFF 4550mA 17V 33V OFF OFF ON ON 4200mA 18V 36V OFF OFF ON OFF 3850mA 20V 36V OFF OFF OFF ON 3500mA 22V 36V Notes / Output Current Setting with Constant Power. Output Current Setting with Power Derating. Mechanical Outline EUP-150S070ST INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL STW 2* 18AWG 8.9) V+(RED) V-(BLUE) AC/L(BLACK) AC/N(WHITE) GND(GREEN) Tc PROJ: Unspecified tolerance:±1 12 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Others INPUT (UL SJTW 3*18AWG 7.8) OUTPUT (UL SJTW 2*18AWG 7.3) V+(RED) V-(BLUE) AC/L(BLACK) AC/N(WHITE) GND(GREEN) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 13 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUP-150SxxxST 150W AOC IP67 Driver Rev. C Revision History Description of Change Change Date Rev. 2016-08-11 A 2018-04-23 Item To Datasheets Release / / Features / Updated Description / Updated Models / Updated Input Specifications PF/THD Updated Output Specifications Temperature Coefficient Updated Updated B Operating Case Warranty Tc_w 2018-08-30 From C Temperature for Case temperature for 5 Added years warranty Safety &EMC Compliance / Updated Mechanical Outline / Updated Models EUP-150S150ST Updated Output Current Setting(Ioset) Range EUP-150S150ST Updated Output Current Setting Range with Constant Power EUP-150S150ST Updated No Load Output Voltage EUP-150S150ST Updated Efficiency at 120 Vac input: EUP-150S150ST Updated Efficiency at 220 Vac input: EUP-150S150ST Updated Efficiency at 270 Vac input: EUP-150S150ST Updated Efficiency vs. Load EUP-150S150ST Updated Output Current vs. Dip Switch Setting EUP-150S150ST Updated 14 / 14 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUP-150S350ST 价格&库存
很抱歉,暂时无法提供与“EUP-150S350ST”相匹配的价格&库存,您可以联系我们找货
