EUV-096S024SV
EUV-096S024SV
    INVENTRONICS(英飞特)
EUV-096S024SV 数据手册
EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Features  Ultra High Efficiency (Up to 90%)  High Power Factor (0.99 Typical)  Constant Voltage Output  Lightning Protection  All-Round Protection: OVP, OCP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The EUV-096SxxxSV series is a 96W, constant-voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including architectural, decorative and signage, etc. The high efficiency of the driver and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, over current, output over voltage, short circuit, and over temperature. Models Output Voltage Input Voltage Range Output Current Range Max. Output Power Typical Power Factor Efficiency 120Vac 220Vac (1) 24 Vdc 90 ~ 305 Vac 0~4.00 A 96 W 87% 0.99 0.96 EUV-096S024SV 36 Vdc 90 ~ 305 Vac 0~2.66 A 96 W 88% 0.99 0.96 EUV-096S036SV 48 Vdc 90 ~ 305 Vac 0~2.00 A 96 W 88% 0.99 0.96 EUV-096S048SV 54 Vdc 90 ~ 305 Vac 0~1.77 A 96 W 90% 0.99 0.96 EUV-096S054SV Model Number (2) Note: (1) Measured at 25C, 100% load and 220 Vac input. (2) SELV output Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 1 mA At 277Vac 60Hz input - - 1.2 A Measured at 100% load and 100 Vac input. - - 0.6 A Measured at 100% load and 220 Vac input. - - 69 A - - 2.8 A s Input AC Current Inrush Current 2 Inrush Current(I t) At 220Vac input, 25℃ Cold start, Duration= 2 mS, 10%Ipk-10%Ipk 2 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - - - 20% Parameter Min. Typ. Max. Output Voltage Tolerance -5% - 5% Ripple and Noise (pk-pk) - - 3% VO Line Regulation - - ±1% Load Regulation - - ±2% - 1.0 s 2.0 s Measured at 120Vac input, 75%-100%load - 1.0 s 2.0 s Measured at 220Vac input, 75%-100%load - - 10% When power on or off. - - 5% VO - - 10 mS - 0.03%/C - PF THD Notes At 100-277Vac, 50-60Hz, 75%-100%load. (72W-96W) Output Specifications Notes Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Output Overshoot / Undershoot Output Load Deviation Dynamic Response Settling Time Temperature coefficient R/S: 1 A/uS Load: 25% ~ 75% full load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. Protection Functions Parameter Min. Typ. Max. Over Voltage Protection VO = 24 V VO = 36 V VO = 48 V VO = 54 V - 30 V 45 V 55 V 65 V 35 V 50 V 60 V 75 V Over Current Protection Over Temperature Protection-Tc Short Circuit Protection Notes Hiccup mode. The power supply shall be self-recovery when the fault condition is removed. Maximum temperature of the case. The power supply shall be self-recovery when the fault condition is 110 C removed. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. 100% IO 110% IO 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K General Specifications Parameter Min. Typ. Max. Notes Efficiency VO = 24 V VO = 36 V VO = 48 V VO = 54 V 83% 84% 84% 85% 85% 86% 86% 87% - VO = 24 V VO = 36 V VO = 48 V VO = 54 V 85% 86% 86% 88% 87% 88% 88% 90% 202,000 Hours - Measured at 100% load, 120 Vac input, 25℃ ambient temperature, after the unit is thermally stabilized. It will be about 2.5% lower, if measured immediately after startup. Efficiency Measured at 100% load, 220 Vac input, 25℃ ambient temperature, after the unit is thermally stabilized. It will be about 2.5% lower, if measured immediately after startup. Measured at 120Vac input,80% Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 120Vac input, 80%load; Case temperature=60℃ @ Tc point. See the lifetime vs. Tc curve for the details MTBF - Lifetime - 56,600 Hours - -40°C - +89 °C -40°C - +70 °C Case temperature for 5 years warranty -40°C - +85 °C Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight - With mounting ear 6.85 × 2.66 × 1.44 174 × 67.5 × 36.5 - 925 g 7.91× 2.66 × 1.44 201× 67.5 × 36.5 - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category Standard CE EN 61347-1, EN61347-2-13 CCC GB 19510.1, GB 19510.14 PSE J 61347-1, J 61347-2-13 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 15 kV air discharge, 8 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Safety & EMC Compliance (Continued) EMS Standards Notes EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Lifetime vs. Case Temperature Curve 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Mechanical Outline OUTPUT (VDE H05RN-F 2*1.0mm 2 INPUT (VDE H05RN-F 3*1.0mm 2 7.2) AC/L(BROWN) AC/N(BLUE) GND/(YELLOW/GREEN) 6.8) V+(BROWN) V- (BLUE) Tc PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Revision History Change Date 2010-12-21 Description of Change Rev. Item A From Change PF at 220Vac 0.95 0.96 Change the notes for models / / Change Ripple and Noise (pk-pk) 2% Vo 3% Vo Delete Derating Curve / / Add Max. Case Temperature / tc: 89 ℃ Update safety standards / / Add FCC Part15 Class B / FCC Part 15 Class B, ANSI C63.4:2009. Update mechanical Outline / / Models-TE 88%,89%,89%,90% 87%,88%,88%,90% Input Specifications-Input AC Current 1.2A 1.3A Inrush Current 50A 69A Output SpecificationsTurn-on Delay Time Protection Functions 2011-07-08 To 0.8S 1S 1S 3S 0.8S 1S 0.8S 2S / 86% 86% 87% 87% 87% 87% 88% 88% 88% 87% 89% 88& 89% 88% 90% 90% General Specifications-Notes 1% 2-3% B General Specifications-Typ. 2012-01-18 C Input AC Current 1.3 A 1.2 A 2012-05-17 D All Models-Min Efficiency / 1% Lower Derating Curve / Updated 2012-06-08 E Life time vs. Tc Curve / Added 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Revision History (Continued) Description of Change Change Date Rev. 2012-7-17 F 2012-8-6 2012-10-16 2013-1-10 2018-10-26 Item G H I J From To Max Case Temperature / Updated EN61000-4-5 line to line 2 kV, line to line to line 4 kV, line to earth earth 4 kV 6 kV SELV Output / Added Duration of Inrush Current 140 μs 2 mS Operating Temperature/Derating Curve / Updated MTBF & Life time Typical / Added Life time Curve / Updated Min PF, Max THD, Temperature Coefficient / Added 1s 3s 1s 2s 0.8s 2s 1s 2s Turn-on delay time CQC CCC Updated PSE / Added Features 5 Years Warranty Added Description / Updated Models / Updated Input Specifications PF/THD Updated Output Specifications Turn-on Delay Time Updated Temperature coefficient Max 0.03%/℃ Typ 0.03%/℃ Operating Case Temperature for Safety Updated Tc_s Operating Case Temperature for Warranty Updated Tc_w General Specifications General Specifications General Specifications Storage Temperature Updated Environmental Specifications / Deleted Dimensions With mounting ear Added Net Weight 850g 925g Safety & EMC Compliance / Updated Max. Case Temperature / Deleted Lifetime vs. Case Temperature Curve / Updated 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUV-096SxxxSV 96W Constant Voltage IP67 Driver Rev. K Revision History (Continued) Description of Change Change Date Rev. 2018-10-26 J 2019-09-20 Item K From To Mechanical Outline / Updated KS Logo / Added Features Waterproof (IP67) IP67 Input Specifications (Power Factor / THD) (72W-96W) Added Safety &EMC Compliance KS Added Safety &EMC Compliance J 55015 Deleted Safety &EMC Compliance EN 61000-4-5 Updated Safety &EMC Compliance Note Added Derating Curve / Deleted RoHS Compliance / Updated 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUV-096S024SV 价格&库存
很抱歉,暂时无法提供与“EUV-096S024SV”相匹配的价格&库存,您可以联系我们找货
EUV-096S024SV
