EUV-200S024SV
EUV-200S024SV
    INVENTRONICS(英飞特)
EUV-200S024SV 数据手册
EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Features  High Efficiency (Up to 92.5%)  Constant Voltage Output  Input Surge Protection: DM 4kV, CM 6kV  All-Around Protection: OVP, OCP, SCP, OTP  IP67  SELV Output  5 Years Warranty Description The EUV-200SxxxSV series is a 200W, constant-voltage LED driver that operates from 90-305 Vac input with excellent power factor. It is created for many lighting applications including high bay, high mast, sports and roadway, etc. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, over current, short circuit, and over temperature. Models Power Factor Typical Efficiency (2) 120Vac 220Vac Output Voltage Input Voltage Range(1) Output Current Range Max. Output Power 12 Vdc 90 ~ 305 Vac 0~15.0 A 180 W 91.0% 0.99 0.97 EUV-200S012SV 24 Vdc 90 ~ 305 Vac 0~8.33 A 200 W 92.0% 0.99 0.97 EUV-200S024SV 36 Vdc 90 ~ 305 Vac 0~5.56 A 200 W 92.0% 0.99 0.97 EUV-200S036SV 42 Vdc 90 ~ 305 Vac 0~4.76 A 200 W 92.5% 0.99 0.97 EUV-200S042SV 48 Vdc 90 ~ 305 Vac 0~4.17 A 200 W 92.5% 0.99 0.97 EUV-200S048SV 54 Vdc 90 ~ 305 Vac 0~3.70 A 200 W 92.5% 0.99 0.97 EUV-200S054SV Notes: Model Number (3)(4) (1) Certified Voltage range 100-240Vac. (2) Measured at 100% load and 220 Vac input. (3) All the models are certificated to CB, CCC and ENEC, except EUV-200S012SV. (4) SELV output. Input Specifications Parameter Min. Typ. Max. Notes Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA - - 2.5 A Measured at 100% load and 100 Vac input. - - 1.1 A Measured at 100% load and 220 Vac input. IEC60598-1; 240Vac/ 60Hz, grounding effectively Input AC Current 1 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q  Input Specifications (Continued) Parameter Min. Typ. Max. - - 1.5 A s 0.90 - - - - 20% Min. Typ. Max. -2.5% - 2.5% -5% - 5% Ripple and Noise (pk-pk) - - 2% VO Output Overshoot / Undershoot - - 10% When power on or off. Line Regulation - - ±1% At 100% load condition. Load Regulation - - ±2% - 0.9 s 1.5 s Measured at 110Vac input, 100% Load - 0.5 s 1.0 s Measured at 220Vac input, 100% Load Output Deviation - - 5% VO Settling Time - - 10 mS - 0.05%/C - 2 Inrush Current(I t) PF 2 Notes At 220Vac input 25℃ Cold Start, duration=1.2 ms, 10%Ipk-10%Ipk At 100-240 Vac, 50-60Hz, 100% Load THD   Output Specifications Parameter Notes EUV-200S042SV. At 100% load condition. Output Voltage Tolerance Others. At 100 % load condition. Measured by 20 MHz bandwidth oscilloscope and the output paralleled a 0.1 uF ceramic capacitor and a 10 uF electrolytic capacitor. Turn-on Delay Time Load Dynamic Response Temperature coefficient R/S: 1 A/uS Load: 25% ~ 75% 100% load. Case temperature = 0C ~Tc max Note: All specifications are typical at 25 C unless otherwise stated. General Specifications Parameter Efficiency at 110 Vac input: VO = 12 V VO = 24 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V Efficiency at 220 Vac input: VO = 12 V VO = 24 V VO = 36 V VO = 42 V VO = 48 V VO = 54 V No Load Power Dissipation Min. Typ. Max. Notes 88.0% 89.0% 89.0% 89.5% 89.5% 89.5% 89.0% 90.0% 90.0% 90.5% 90.5% 90.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) 90.0% 91.0% 91.0% 91.5% 91.5% 91.5% 91.0% 92.0% 92.0% 92.5% 92.5% 92.5% - Measured at 100% load and steady-state temperature in 25C ambient; (Efficiency will be about 1.0% lower if measured immediately after startup.) - - 3W 2 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q General Specifications (Continued) Parameter Min. Typ. Max. MTBF - 276,000 hours - Lifetime - 95,200 hours - -35 C - +90 C @90-305 Vac -40 C - +90 C @198-305 Vac -35 C - +70 C -40 C - +70 C @90-305 Vac, Case temperature for 5 years warranty @198-305 Vac, Case temperature for 5 years warranty -40 C - +85 C Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Measured at 110Vac input, 80%Load and 25C ambient temperature (MIL-HDBK-217F) Measured at 220Vac input, 80%Load and 60C case temperature; See life time vs. Tc curve for the details Dimensions Inches (L × W × H) Millimeters (L × W × H) - 1150 g Humidity: 5% RH to 100% RH With mounting ear 8.90 × 2.66 × 1.56 226 × 67.5 × 39.5 7.83 × 2.66 × 1.56 199 × 67.5 × 39.5 Net Weight Notes - Note: All specifications are typical at 25 C unless otherwise stated. Safety & EMC Compliance Safety Category Standard ENEC & CE EN 61347-1, EN61347-2-13 CB IEC 61347-1, IEC 61347-2-13 CCC GB 19510.1, GB 19510.14 KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743/KN 15 Conducted emission Test & Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment 3 / 10 Specifications are subject to changes without notice. www.inventronics-co.com (2) Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore lineto-earth surge protection and secure the end cap. Lifetime vs. Case Temperature Curve Efficiency vs. Load 4 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Power Factor Characteristics 5 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Total Harmonic Distortion Curve (24V) Protection Functions Parameter Over Current Protection Min. 120% IO Typ. 140% IO Max. Notes 200% IO Hiccup mode. The power supply shall be selfrecovery when the fault condition is removed. Over Temperature Protection Auto Recovery, returning to normal after over temperature is removed. Short Circuit Protection No damage will occur when any output is short circuited. The output shall return to normal when the fault condition is removed. Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. 6 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Mechanical Outline EUV-200S012SV INPUT (VDE H05RN-F 3*1.0mm2 OUTPUT (VDE H05RN-F 2*1.0mm2 6.8) 7.2) Tc AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN ) V+ (BROWN) V- (BLUE) V+ (BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 Note: The 2 DC output cables are connected in parallel internally because one 1.0mm2 wire can only carry 10A. Please connect the 2 brown wires together and 2 blue wires together in application, or ensure each cable carries same current. Others INPUT (VDE H05RN-F 3C*1.0mm 2 OUTPUT (VDE H05RN-F 2C*1.0mm 2 6.8) 7.2) Tc AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) V+ (BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Revision History Change Date Description of Change Rev. Item From To 2009-12-03 A Change the Max. output current/power and efficiency of 12V. Update the Ambient Temperature Derating Curve 2009-12-16 B Add note for mechanical outline. / ☆: Popular model. C Add star rank for recommended models Add Leakage Current in Input Specifications Standardize the tolerance in Mechanical Outline / Max. 0.75 Ma At 277Vac 50Hz input / / 42V,50V,52V, 81V, 105V Models / Deleted 2010-05-31 0.7 s 1.0 s 0.9 s 1.5 s 0.3 s 0.5 s 0.5 s 1.0 s Turn-on delay time 2012-06-12 2012-7-17 2012-8-14 D E Efficiency of EUV-200S054SV @ 110 Vac / 1 % lower Life Time Curve / Added Mechanical Outline / Updated Max Case Temperature / Updated Efficiency of 54V Model @220 Vac / 0.5% Lower Efficiency of 36V Model / 0.5% Lower OCP Typ 1.3Io Min PF / Added Max THD / Added Temperature coefficient / Added Life time Curve / Updated MTBF, life time Typical / Added EN61000-4-5 line to line 2 Kv, line to earth 4 Kv line to line 4 Kv, line to earth 6 Kv Inrush Current(I t) / Added No Load Power Dissipation 2W 3W Derating Curve / Updated 2012-12-28 Efficiency Curve of all models / Added PF Curve of all models / Added THD Curve of 24V Model / Added Typ 1.4Io Max 1.8Io F 2 2012-12-06 Max 1.7Io G H 2013-11-26 I Input Specifications--Load Range of 75%load-100%load PF & THD 100%load 2015-09-11 M Format Update / 8 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Revision History (Continued) Change Date Description of Change Rev. Item From External Grounding Screw Solution / 2015-09-11 2016-03-31 2017-11-14 M N / Features / Update Description / Update Models EUV-200S042SV Added General Specifications Case Temperature Operating Case Temperature for Safety Tc_s General Specifications Operating Case Temperature for Warranty Tc_w Added General Specifications Storage Temperature Added Environmental Specifications / Deleted Safety & EMC Compliance / Updated Protection Functions / Updated Mechanical Outline / Updated KS / Addedd Models / Updated General Specifications With mounting ear Added General Specifications Net Weight Updated Safety & EMC Compliance / Updated CCC / Added Features 5 years warranty Added Models Notes(3) Updated Input Specifications Leakage Current Updated PF/THD Notes Updated Turn-on Delay Time Notes Updated Temperature coefficient Max 0.05%/C Typ 0.05%/C O Operating Case Temperature Updated for Safety Tc_s Operating Case Temperature Updated for Warranty Tc_w General Specifications General Specifications 2019-03-12 To P Mechanical Outline / Updated CCC / Updated ENEC / Added Description / Updated 9 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com EUV-200SxxxSV 200W Constant Voltage IP67 Driver  Rev. Q Revision History (Continued) Change Date Description of Change Rev. Item From Models 2019-03-12 2020-01-06 P Q To Notes(3) Updated General Specifications - Net Weight 1080g 1150g Safety & EMC Compliance / Updated KCC Logo / Added Independent Logo / Added Features 4kV line-line, 6kV line-earth DM 4kV, CM 6kV Features Waterproof (IP67) IP67 Features Suitable for Independent Use Deleted Safety &EMC Compliance CB Added Safety &EMC Compliance EN 55015/GB 17743 Safety &EMC Compliance EN 61000-4-5 Updated Derating Curve / Deleted RoHS Compliance / Updated Format Page footer Updated (1) 10 / 10 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 EN 55015/GB 17743/KN 15(1) All specifications are typical at 25C unless otherwise stated Fax: 86-571-86601139 sales@inventronics-co.com
EUV-200S024SV
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
EUV-200S024SV 价格&库存
很抱歉,暂时无法提供与“EUV-200S024SV”相匹配的价格&库存,您可以联系我们找货
EUV-200S024SV
