ESD-096S090DT
ESD-096S090DT
    INVENTRONICS(英飞特)
    ESD Series 96 W 700 mA 214 Vdc Out Max Programmable Outdoor LED Driver Module
ESD-096S090DT 数据手册
ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Features  High Efficiency (Up to 90.5%)  Full Power at Wide Output Current Range (Constant Power)  0-10V/PWM/3-Timer-Modes Dimmable  Dim-to-Off with Standby Power ≤1.5 W  Output Lumen Compensation  Input Surge Protection: 4kV line-line, 6kV line-earth  All-Around Protection: OVP, SCP, OTP  Waterproof (IP67) and UL Dry / Damp / Wet Location  Class 2 & SELV Output  TYPE HL, for use in a Class I, Division 2 hazardous (Classified) location  5 Years Warranty Description The ESD-096SxxxDT series is a 96W, constant-current, programmable LED driver that operates from 249-528 Vac input with excellent power factor. Created for many lighting applications including low bay, area and street, it provides a dim-to-off mode with low standby power. The high efficiency of these drivers and compact metal case enables them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, output over voltage, short circuit, and over temperature. Models Adjustable Output Current Range Full-Power Current Range (1) Default Output Current Input Voltage Range(2) Output Voltage Range Max. Typical Power Factor Output Efficiency 277Vac 480Vac Power (3) 249~528 Vac 64~214Vdc 96 W 352~500 Vdc 249~528 Vac 90-1800mA 900-1800mA 1050 mA 32~107Vdc 96 W 352~500 Vdc 249~528 Vac 180-3600mA 1800-3600mA 2100 mA 16 ~ 53Vdc 96 W 352~500 Vdc 45-900mA 450-900mA 700 mA Model Number 90.5% 0.98 0.95 ESD-096S090DT 90.5% 0.98 0.95 ESD-096S180DT (4) 89.5% 0.98 0.95 ESD-096S360DT (5) Notes: (1) Output current range with constant power at 96W (2) Certified voltage range: 277-480Vac or 352-500Vdc. (3) Measured at 100% load and 480Vac input (see below “General Specifications” for details). (4) SELV Output (5) Class 2 & SELV Output 1 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E I-V Operating Area ESD-096S090DT ESD-096S180DT ESD-096S360DT Input Specifications Parameter Input Voltage Input Frequency Min. Typ. Max. 249 Vac - 528 Vac 47 Hz - 63 Hz - - 0.75 MIU UL8750; 480Vac/ 60Hz; Grounding effectively. - - 0.70 mA IEC60598-1; 480Vac/ 60Hz; Grounding effectively. - - 0.48A Measured at 100% load and 277 Vac input. - - 0.30A Measured at 100% load and 480 Vac input. - - 2.17 A s Leakage Current Notes 352-500Vdc Input AC Current 2 Inrush Current(I t) 2 At 480Vac input, 25°C Cold Start, Duration=500 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 2 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Input Specifications (Continued) Parameter Min. Typ. Max. 0.90 - - - - 20% Min. Typ. Max. -5%Ioset - 5%Ioset 45 mA 90 mA 180 mA - 900 mA 1800 mA 3600 mA 450 mA 900 mA 1800 mA - 900 mA 1800 mA 3600 mA - 5%Iomax 10%Iomax At 100% load condition - 1%Iomax - At 100% load condition. Startup Overshoot Current - - 10%Iomax At 100% load condition No-load Output Voltage ESD-096S090DT ESD-096S180DT ESD-096S360DT - - 240V 119V 59.5V Line Regulation - - ±0.5% Load Regulation - - ±1.5% Turn-on Delay Time - 0.5 s 0.75 s Temperature Coefficient of Ioset - 0.03%/°C - 12V Auxiliary Output Voltage 10.8 V 12 V 13.2 V 12V Auxiliary Output Source Current 0 mA - 200 mA PF THD Notes At 277-480Vac, 50-60Hz, 65%-100% Load (63-96W) Output Specifications Parameter Output Current Tolerance Output Current Setting(Ioset) Range ESD-096S090DT ESD-096S180DT ESD-096S360DT Output Current Setting Range with Constant Power ESD-096S090DT ESD-096S180DT ESD-096S360DT Total Output Current Ripple (pk-pk) Output Current Ripple at < 200 Hz (pk-pk) Notes At 100% load condition Measured at 100% load Measured at 277Vac and 480Vac input , 65%-100%Load Case temperature = 0°C ~Tc max Return terminal is “Dim−“ 3 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E General Specifications Parameter Min. Typ. Max. 87.5% 87.5% 89.5% 89.5% - 87.5% 87.0% 89.5% 89.0% - 86.0% 85.0% 88.0% 87.0% - 88.0% 88.0% 90.0% 90.0% - 88.0% 87.5% 90.0% 89.5% - 87.0% 86.0% 89.0% 88.0% - 88.5% 88.5% 90.5% 90.5% - 88.5% 88.0% 90.5% 90.0% - 87.5% 86.0% 89.5% 88.0% - Standby power - - 1.5 W MTBF - 211,000 Hours - Lifetime - 108,000 Hours - -40°C - +90°C -40°C - +75°C Case temperature for 5 years warranty -40°C - +85°C Humidity: 5%RH to 100%RH Efficiency at 277 Vac input: ESD-096S090DT Io=450 mA Io=900 mA ESD-096S180DT Io=900 mA Io=1800mA ESD-096S360DT Io=1800mA Io=3600mA Efficiency at 347 Vac input: ESD-096S090DT Io=450 mA Io=900 mA ESD-096S180DT Io=900 mA Io=1800mA ESD-096S360DT Io=1800mA Io=3600mA Efficiency at 480 Vac input: ESD-096S090DT Io=450 mA Io=900 mA ESD-096S180DT Io=900 mA Io=1800mA ESD-096S360DT Io=1800mA Io=3600mA Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Net Weight 1090 g Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 100% load and steady-state temperature in 25°C ambient; (Efficiency will be about 2.0% lower if measured immediately after startup.) Measured at 480Vac/60Hz; Dimming off Measured at 480Vac input, 80%Load and 25°C ambient temperature (MIL-HDBK217F) Measured at 480Vac input, 80%Load and 70°C case temperature; See lifetime vs. Tc curve for the details With mounting ear 9.41 × 2.66 × 1.44 239 × 67.5 × 36.5 8.35 × 2.66 × 1.44 212 × 67.5 × 36.5 - Notes - 4 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Dimming Specifications Parameter Min. Typ. Max. -20 V - 20 V 200 uA 300 uA 450 uA 10%Ioset - Ioset 45 mA 90 mA 180 mA - Ioset 0V - 10 V Dim off Voltage 0.4 V 0.55V 0.7 V Dim on Voltage 0.6 V 0.75 V 0.9 V - 0.2 V - PWM_in High Level 3V - 10 V PWM_in Low Level -0.3 V - 0.6 V PWM_in Frequency Range 200 Hz - 3 KHz 1% - 99% 3% 5% 8% 5% 7% 10% 92% 95% 97% 90% 93% 95% - 2% - Absolute Maximum Voltage on the Vdim (+) Pin Source Current on Vdim (+) Pin ESD-096S090DT ESD-096S180DT Dimming ESD-096S360DT Output ESD-096S090DT Range ESD-096S180DT ESD-096S360DT Recommended Dimming Input Range Hysteresis PWM_in Duty Cycle PWM Dimming off (Positive Logic) PWM Dimming on (Positive Logic) PWM Dimming off ( Negative Logic) PWM Dimming on ( Negative Logic) Hysteresis Notes Vdim(+) = 0 V 450mA ≤ Ioset ≤ 900mA 900mA ≤ Ioset ≤ 1800mA 1800mA ≤ Ioset ≤ 3600mA 45mA ≤ Ioset < 450mA 90mA ≤ Ioset < 900mA 180mA ≤ Ioset < 1800mA Default 0-10V dimming mode. Dimming mode set to PWM in PC interface. Safety & EMC Compliance Safety Category UL/CUL Standard UL 8750,UL1310,CAN/CSA-C22.2 No. 250.13,CAN/CSA-C22.2 No. 223-M91 CE EN 61347-1, EN61347-2-13 EMI Standards (1) EN 55015 Notes Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 5 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Safety & EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV(2) EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. (2) To perform electric strength (hi-pot) testing, the “GDT ground disconnect” (nut and metal lock sheet) on the driver end-cap should be removed temporarily to prevent the internal gas discharge tube from conducting (as allowed by IEC 60598-1 Clause 10.2). After testing is completed, these items must be reinstalled to restore line-to-earth surge protection and secure the end cap. Lifetime vs. Case Temperature 6 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Inrush Current Waveform Efficiency vs. Load ESD-096S090DT(Io=450mA) ESD-096S090DT(Io=900mA) ESD-096S180DT(Io=900mA) ESD-096S180DT(Io=1800mA) 7 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E ESD-096S360DT(Io=1800mA) ESD-096S360DT(Io=3600mA) Power Factor Total Harmonic Distortion 8 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Protection Functions Parameter Over Temperature Protection Short Circuit Protection Over Voltage Protection Notes Decreases output current, returning to normal after over temperature is removed. Auto Recovery. No damage will occur when any output is short circuited. The output shall return to normal within 60±5s after the fault condition is removed. Auto Recovery. The power supply shall be self-recovered within 60±5s after the fault condition is removed. Dimming  0-10V Dimming The recommended implementation of the dimming control is provided below. Implementation 1: DC Input Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. Do not connect the GND of dimming to the output; otherwise, the LED driver cannot work normally. 3. If 0-10V dimming is not used, Dim + should be open.  PWM Dimming The recommended implementation of the dimming control is provided below. Implementation 2: Positive logic 9 / 13 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25°C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com ESD-096SxxxDT 96W Programmable IP67 Driver Rev. E Implementation 3: Negative logic Notes: 1. Do NOT connect Dim− to the output V− or V+, otherwise the driver will not work properly. 2. If PWM dimming is not used, Dim + should be open. 3. When PWM negative logic dimming mode and Dim+ is open, the driver will output minimum current.   Time Dimming Time dimming control includes 3 kinds of modes, they are Self Adapting-Midnight, Self AdaptingPercentage and Traditional Timer. • Self Adapting-Midnight: Automatically adjusts the dimming curve based on the on-time of past two days (if difference
ESD-096S090DT 价格&库存
很抱歉,暂时无法提供与“ESD-096S090DT”相匹配的价格&库存,您可以联系我们找货
