EUC-026S050SVM0003
EUC-026S050SVM0003
    INVENTRONICS(英飞特)
EUC-026S050SVM0003 数据手册
EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Features  Low THD, 10% Max up to 240 Vac  Compact Metal Case with Excellent Thermal Performance  Input Surge Protection: DM 4kV, CM 6kV  High Reliability & Long Lifetime: 84,000 Hrs. at 70C Case Temperature  Input UVP  IP67  SELV Output  5 Year Warranty Description The EUC-026SxxxSVM000x series is a 26W, constant-current IP67 LED driver that operates from 90-305 Vac input with excellent power factor and THD feature. It is created for many lighting applications including low bay, tunnel and street. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, output over voltage, short circuit, and over temperature. Models Typical Power Factor Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Efficiency (2) 120 Vac 220 Vac 350 mA 90 ~ 305 Vac 37 ~ 74 Vdc 26 W 88.5% 0.99 0.96 EUC-026S050SVM0003 500 mA 90 ~ 305 Vac 26 ~ 52 Vdc 26 W 88.0% 0.99 0.96 EUC-026S070SVM0004 600 mA 90 ~ 305 Vac 22 ~ 43 Vdc 26 W 88.0% 0.99 0.96 EUC-026S070SVM0002 700 mA 90 ~ 305 Vac 20 ~ 37 Vdc 26 W 87.0% 0.99 0.96 EUC-026S070SVM Model Number(3)(4) Notes: (1) Certified input voltage range: 120-240Vac. (2) Measured at 100% load and 220 Vac input. (3) SELV output. (4) For BIS models please click here see the: BIS Models List. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.70 mA Input AC Current - - 0.35 A 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes IEC60598-1; 240Vac/ 60Hz Measured at 100% load and 120 Vac input. All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Input Specifications (Continued) Parameter Min. Typ. Max. Notes Input AC Current - - 0.25 A Measured at 100%load and 220 Vac input. 2 - - 0.09 A s 0.90 - - THD - - 15% THD - - 10% Min. Typ. Max. -8%lo - 8%lo At 100%load condition Total Output Current Ripple (pk-avg) - 50%Io 75%Io At 100%load condition Startup Overshoot Current - 5%Io 10%Io At 100%load condition No Load Output Voltage EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM - - 100 V 67 V 67 V 67 V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s - 1.0 s 1.5 s - 0.08%/C - Min. Typ. Max. 87.0% 86.0% 86.0% 85.5% 88.0% 87.0% 87.0% 86.5% - Measured at 100%load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) 87.5% 87.0% 87.0% 86.0% 88.5% 88.0% 88.0% 87.0% - Measured at 100%load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) 86.5% 86.0% 86.0% 85.5% 87.5% 87.0% 87.0% 86.5% - At 220Vac input, 25℃ cold start, duration= Inrush Current(I t) Power Factor 2 296 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 120-277Vac,50-60Hz,75%-100%Load (19.5~26W) 120-240Vac,50-60Hz,75%-100%Load (19.5~26W) Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at 100%load Measured at 120Vac input, 75%-100%Load. Measured at 220Vac input, 75%-100%Load. Case temperature = 0C ~ Tc max General Specifications Parameter Efficiency at 120 Vac input: EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM Efficiency at 220 Vac input: EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM Efficiency at 277 Vac input: EUC-026S050SVM0003 EUC-026S070SVM0004 EUC-026S070SVM0002 EUC-026S070SVM 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Notes Measured at 100%load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E General Specifications (Continued) Parameter Min. Typ. Max. MTBF - 1610,000 Hours - Lifetime - 84,000 Hours - -40 C - +85 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 95% RH. -40 C - +85 C Humidity: 5% RH to 95% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) - 330 g Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 3.82 x 2.52 x 1.26 97 x 64 x 32 3.15 x 2.52 x 1.26 80 x 64 x 32 Net Weight Notes - Safety &EMC Compliance Safety Category Standard ENEC & TUV & CE CCC EN 61347-1, EN61347-2-13 GB 19510.1, GB 19510.14 CB IEC 61347-1, IEC 61347-2-13 BIS IS 15885(PART2/SEC13) NOM NOM-058-SCFI KS KS C 7655 EMI Standards Notes (1) EN 55015/GB 17743 Conducted emission Test &Radiated emission Test EN 61000-3-2/GB 17625.1 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: Differential Mode 4 kV, Common Mode 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Safety &EMC Compliance (Continued) EMS Standards EN 61547 Notes Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating Lifetime vs. Case Temperature 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Inrush Current Waveform Efficiency vs. Load EUC-026S050SVM0003(Io=350mA) EUC-026S070SVM(Io=700mA) EUC-026S070SVM0002(Io=600mA) EUC-026S070SVM0004(Io=500mA) 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Power Factor Total Harmonic Distortion Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Turn off the output when the input voltage falls below 80±10V. And the driver will restart when the input voltage exceeds 85±10V. 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Mechanical Outline EUC-026SxxxSVM000x INPUT (VDE H05RN-F 3*1.0mm 2 OUTPUT (VDE H05RN-F 2*1.0mm 2 7.2 ) 6.8) Tc AC/L (BROWN) AC/N (BLUE) GND (YELLOW/GREEN) V+ (BROWN) V- (BLUE) PROJ: Unspecified tolerance:±1 EUC-026SxxxSVM300x INPUT(BIS 3*1.0mm 2 7.25) OUTPUT(BIS 2*1.0mm 2 6.85) Tc K C DA EL RB +VV AC/L (RED) AC/N (BLACK) GND (YELLOW/GREEN) ︵ ︵ ︶ ︶ PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with reference to RoHS Directive (EU) 2015/863 amending 2011/65/EU, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSVM000x 26W Constant Current IP67 Driver Rev. E Revision History Description of Change Change Date Rev. 2016-07-04 A 2016-12-26 Item B From Datasheet Release / / Input Voltage Range(Vac) 108 ~ 305 Vac 90 ~ 305 Vac Input Voltage Range(Vdc) 127 ~ 300 Vdc Deleted Model Number - EUC-026S070SVM(Io=700mA) Total Output Current Ripple 2017-03-21 2019-03-19 EUC026S070SVM0000 Total Output Current Ripple (pk-pk) Max.= 150%lo EUC-026S070SVM Total Output Current Ripple (pk-avg) Max.= 75%Io Derating Curve / Added Features / Updated Description / Updated MTBF Min.=600,000Hours Typ.= 1610,000 Hours Protection Functions - Input Under Voltage Protection / Added ENEC / Added Description / Updated Input Specifications- Power Factor/THD 50-60Hz Added / Updated C D Safety &EMC Compliance Input Surge Protection: Input Surge Protection: 4kV line-line, 6kV lineDM 4kV, CM 6kV earth Suitable for Independent Use and Deleted Class I Luminaires Features Features 2020-09-18 To E Features Waterproof(IP67) IP67 BIS certificate / Added NOM certificate / Added Independent symbol / Added Notes of models - (4) For BIS models please click here see the: BIS Models List. / Added General Specifications - Humidity / Updated Safety &EMC Compliance BIS Added Safety &EMC Compliance NOM Added Mechanical Outline - EUC-026SxxxSVM300x / Added RoHS Compliance / Updated Format / Updated 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 All specifications are typical at 25C unless otherwise stated. Fax: 86-571-86601139 sales@inventronics-co.com
EUC-026S050SVM0003 价格&库存
很抱歉,暂时无法提供与“EUC-026S050SVM0003”相匹配的价格&库存,您可以联系我们找货
EUC-026S050SVM0003
