EUC-026S070STM0002
EUC-026S070STM0002
    INVENTRONICS(英飞特)
    EUC-026S070STM0002
EUC-026S070STM0002 数据手册
EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F Features  Low THD, 10% Max up to 240 Vac  Compact Metal Case with Excellent Thermal Performance  Input Surge Protection: 4kV line-line, 6kV line-earth  High Reliability & Long Lifetime: 84,000 Hrs. at 70C Case Temperature  Suitable for Built-in Use and Class I Luminaires  Input UVP  Waterproof (IP66) and UL Dry / Damp Location  SELV Output  TYPE HL, for Use in a Class I, Division 2 Hazardous (Classified) Location  5 Years Warranty Description The EUC-026SxxxSTM000x series is a 26W, constant-current IP66 LED driver that operates from 90-305 Vac input with excellent power factor and THD feature. It is created for low bay, tunnel and street lights. The high efficiency of these drivers and compact metal case enable them to run cooler, significantly improving reliability and extending product life. To ensure trouble-free operation, protection is provided against input surge, input under voltage, output over voltage, short circuit, and over temperature. Models Output Current Input Voltage Range(1) Output Voltage Range Max. Output Power Typical Efficiency (2) 120 Vac 220 Vac 350 mA 90 ~ 305 Vac 37 ~ 74 Vdc 26 W 88.5% 0.99 0.96 EUC-026S050STM0003 500 mA 90 ~ 305 Vac 26 ~ 52 Vdc 26 W 88.0% 0.99 0.96 EUC-026S070STM0004 600 mA 90 ~ 305 Vac 22 ~ 43 Vdc 26 W 88.0% 0.99 0.96 EUC-026S070STM0002 700 mA 90 ~ 305 Vac 20 ~ 37 Vdc 26 W 87.0% 0.99 0.96 EUC-026S070STM Power Factor Model Number(3) Notes: (1) UL, FCC certified input voltage range: 120-277Vac; other certified input voltage range except UL & FCC: 120-240Vac. (2) Measured at full load and 220 Vac input. (3) SELV Output. Input Specifications Parameter Min. Typ. Max. Input Voltage 90 Vac - 305 Vac Input Frequency 47 Hz - 63 Hz Leakage Current - - 0.75 MIU Notes UL8750; 277Vac/ 60Hz 1/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F Input Specifications (Continued) Parameter Min. Typ. Max. - - 0.70 mA - - 0.35 A Measured at full load and 120 Vac input. - - 0.25 A Measured at full load and 220 Vac input. - - 0.09 A s 0.90 - - THD - - 15% THD - - 10% Min. Typ. Max. -8%lo - 8%lo At full load condition Total Output Current Ripple (pk-avg) - 50%Io 75%Io At full load condition Startup Overshoot Current - 5%Io 10%Io At full load condition No Load Output Voltage EUC-026S050STM0003 EUC-026S070STM0004 EUC-026S070STM0002 EUC-026S070STM - - 100 V 67 V 67 V 67 V Line Regulation - - ±5.0% Load Regulation - - ±5.0% - 1.5 s 2.0 s Measured at 120Vac input, 75%-100%Load. - 1.0 s 1.5 s Measured at 220Vac input, 75%-100%Load. - 0.08%/C - Leakage Current Notes IEC60598-1; 240Vac/ 60Hz Input AC Current At 220Vac input, 25℃ cold start, duration= 2 Inrush Current(I t) Power Factor 2 296 μs, 10%Ipk-10%Ipk. See Inrush Current Waveform for the details. 120-277Vac,75%-100%Load(19.5~26W) 120-240Vac,75%-100%Load(19.5~26W) Output Specifications Parameter Output Current Tolerance Turn-on Delay Time Temperature Coefficient of Iomax Notes Measured at full load Case temperature = 0C ~Tc max Note: All specifications are tested by Cree XLamp XP-G and typical measured at 220Vac and 25C unless otherwise stated. General Specifications Parameter Efficiency at 120 Vac input: EUC-026S050STM0003 EUC-026S070STM0004 EUC-026S070STM0002 EUC-026S070STM Min. Typ. Max. 87.0% 86.0% 86.0% 85.5% 88.0% 87.0% 87.0% 86.5% - Notes Measured at full load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) 2/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F General Specifications (Continued) Parameter Min. Typ. Max. Efficiency at 220 Vac input: EUC-026S050STM0003 EUC-026S070STM0004 EUC-026S070STM0002 EUC-026S070STM 87.5% 87.0% 87.0% 86.0% 88.5% 88.0% 88.0% 87.0% - Measured at full load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) Efficiency at 277 Vac input: EUC-026S050STM0003 EUC-026S070STM0004 EUC-026S070STM0002 EUC-026S070STM 86.5% 86.0% 86.0% 85.5% 87.5% 87.0% 87.0% 86.5% - Measured at full load and steady-state temperature in 25C ambient. (Efficiency will be about 1.0% lower if measured immediately after startup.) MTBF - 1610,000 Hours - Lifetime - 84,000 Hours - -40 C - +85 C -40 C - +75 C Case temperature for 5 years warranty. Humidity: 10% RH to 100% RH. -40 C - +85 C Humidity: 5% RH to 100% RH Operating Case Temperature for Safety Tc_s Operating Case Temperature for Warranty Tc_w Storage Temperature Dimensions Inches (L × W × H) Millimeters (L × W × H) Notes Measured at 220Vac input, 80%Load and 25C ambient temperature (MIL-HDBK217F) Measured at 120Vac input, 80%Load and 70C case temperature; See lifetime vs. Tc curve for the details With mounting ear 3.82 x 2.52 x 1.26 97 x 64 x 32 3.15 x 2.52 x 1.26 80 x 64 x 32 Net Weight - 330 g - Note: All specifications are tested by Cree XLamp XP-G and typical at 25C unless otherwise stated. Safety &EMC Compliance Safety Category UL/CUL Standard UL 8750, CAN/CSA-C22.2 No. 250.13-12 CE EN 61347-1, EN61347-2-13 KS KS C 7655 EMI Standards (1) EN 55015 Notes Conducted emission Test &Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker 3/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F Safety &EMC Compliance (Continued) EMI Standards Notes ANSI C63.4 Class B (1) FCC Part 15 This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: [1] this device may not cause harmful interference, and [2] this device must accept any interference received, including interference that may cause undesired operation. EMS Standards Notes EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: (1) This LED driver meets the EMI specifications above, but EMI performance of a luminaire that contains it depends also on the other devices connected to the driver and on the fixture itself. Derating 4/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F Lifetime vs. Case Temperature Inrush Current Waveform Efficiency vs. Load EUC-026S050STM0003(Io=350mA) EUC-026S070STM(Io=700mA) 5/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F EUC-026S070STM0002(Io=600mA) EUC-026S070STM0004(Io=500mA) Power Factor Total Harmonic Distortion 6/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F Protection Functions Parameter Notes Over Voltage Protection Limits output voltage at no load and in case the normal voltage limit fails. Short Circuit Protection Auto Recovery. No damage shall occur when any output operating in a short circuit condition. The power supply shall be self-recovery when the fault condition is removed. Over Temperature Protection Decreases output current. Returning to normal after over temperature is removed. Input Under Voltage Protection Auto Recovery. Turn off the output when the input voltage falls below 80±10V. And the driver will restart when the input voltage exceeds 85±10V. G W A 8 1 5 1 0 1 L U T U P N I Mechanical Outline ( OUTPUT (UL1015 18AWG) ) Tc N E E R G AC/L (BLACK) AC/N (WHITE) GND ( ) V+ (RED) V- (BLUE) PROJ: Unspecified tolerance:±1 RoHS Compliance Our products comply with the European Directive 2011/65/EC, calling for the elimination of lead and other hazardous substances from electronic products. 7/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com EUC-026SxxxSTM000x 26W Constant Current IP66 Driver Rev. F Revision History Description of Change Change Date Rev. 2015-07-30 A Item From Datasheet Release / / KS Certificate / Added Models-EUC-026S050STM / Added Max Input AC Current at full load and 120 Vac input 0.3 A 0.35 A Max Input AC Current at full load and 220 Vac input 0.2 A 0.25 A 2 2016-01-28 To 2 2 Inrush Current(I t) 0.08 A s 0.09 A s Load Regulation ±3.0% ±5.0% Temperature Coefficient of Iomax 0.06%/C 0.08%/C Lifetime Min.=120,000 Hours at Typ.=84,000 Hours at Tc=60C Tc=70C Net Weight 300 g 330 g Note of EMI Standard / Added Inrush Current Waveform / Updated PF Curve / Updated THD Curve / Updated Mechanical Outline / Updated B 2016-04-18 C KS Certificate Regulation / Added 2016-05-23 D Mechanical Outline / Updated Input Voltage Range(Vac) 108 ~ 305 Vac 90 ~ 305 Vac Input Voltage Range(Vdc) 127 ~ 300 Vdc Deleted Model Number - EUC-026S070STM(Io=700mA) EUC026S070STM0000 EUC-026S070STM Total Output Current Ripple Total Output Current Ripple (pk-pk) Max.= 150%lo Total Output Current Ripple (pk-avg) Max.= 75%Io FCC Certificate Regulation / Added Derating Curve / Added Features / Updated Description / Updated MTBF Min.=600,000Hours Typ.=1610,000 Hours Protection Functions - Input Under Voltage Protection / Added 2016-12-26 2017-03-21 E F 8/8 Specifications are subject to changes without notice. www.inventronics-co.com Tel: 86-571-56565800 Fax: 86-571-86601139 sales@inventronics-co.com
EUC-026S070STM0002 价格&库存
很抱歉,暂时无法提供与“EUC-026S070STM0002”相匹配的价格&库存,您可以联系我们找货
